Change Airport Location
Hello all.
I have just started uploading my planeplotter data to Flightaware (this is fairly new to me)
The data I receive covers a wide area of Western NSW.
How can I change my Airport location.
Flightaware has allocated YWST, which is Westmead Hospital.
The Hospital may have a heliport but it hardly classes as an airport.
How can I change my profile to include YSSY or YSBK.
Thanks all.
I updated this for you.
Thanks for your assistance.
Hi all,
Same problem here. My location is approx. 5 kms northeast of EDDS (Stuttgart, Germany) but in my stats Flightaware indicates ENAL (Alesund, Norway) as the closest airport.
Could you please check on this and update?
Thanks a lot in advance!
Updated flightaware.com/adsb/stats/user/noikonomidis
just a - let´s say - funny request from my side: is it possible to set the airport location to XMUC (old airport Munich Riem) as this is only 1 km from my site? If not possible, please set all my feeder sites to ETSE. Thx very much in advance.
Thanks but still have ENAL as closest airport :frowning:
Unfortunately we don’t support XMUC so I’ve set it to ETSE.
Odd, I’ve flipped it back again.
if you are 1km close to Riem then your closest airport ist EDDM/MUC and not ETSE Erding.
One of my sites is very close to you…in Riem too
@eddmmuc: Nope :slight_smile:, from my very location (Feldkirchen) Erding has an air line distance of 22km, Munich Airport of 26 km.
After PM doesn´t seem to work, again on this way:
Hi dbaker,
unfortunately 3 of my stations do not feed anymore after changing the location, feeds are not seen as live in my feeder stats. These are 2 beaglebones and 1 raspberry, piaware and faup1090 are running on all devices. Just an example:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
11 root rt 0 0 0 0 S 67.2 0.0 6726:08 watchdog/0
24033 root 20 0 25068 6128 896 R 12.2 1.2 18:54.67 dump1090
24034 root 20 0 24260 3864 1244 S 1.3 0.8 3:27.40 fr24feed_arm-rp
24059 root 20 0 24124 8556 2388 S 0.6 1.7 0:19.74 piaware
24314 ubuntu 20 0 4160 1228 832 R 0.6 0.2 0:03.92 top
10 root 20 0 0 0 0 S 0.2 0.0 62:24.61 rcu_sched
5451 root 20 0 0 0 0 D 0.2 0.0 66:56.41 kworker/0:0
24086 root 20 0 2992 1160 780 S 0.2 0.2 1:48.32 faup1090
And, in addition to this, the log for ID 2103:
09/16/2014 18:56:45 ****************************************************
09/16/2014 18:56:45 piaware version 1.8 is running, process ID 1174
09/16/2014 18:56:45 your system info is: Linux arm 3.8.13-bone59 #1 SMP Sat Jul 5 02:59:43 UTC 2014 armv7l armv7l armv7l GNU/Linux
09/16/2014 18:56:45 connecting to FlightAware eyes.flightaware.com/1200
09/16/2014 18:56:46 FlightAware server SSL certificate validated
09/16/2014 18:56:46 encrypted session established with FlightAware
09/16/2014 18:56:46 connect_faup1090: dump1090 is running
09/16/2014 18:56:46 connect_faup1090: faup1090 isn’t running but i’ll try connecting anyway in case you’re running FA dump1090
09/16/2014 18:56:46 connection refused on faup1090 / dump090 port 10001, retrying in 10s…
09/16/2014 18:56:46 faup1090_running_periodic_check: starting faup1090
09/16/2014 18:56:46 start_faup1090: starting faup1090
09/16/2014 18:56:49 logged in to FlightAware as user thomasgraf99
09/16/2014 18:56:57 connect_faup1090: dump1090 is running
09/16/2014 18:56:57 piaware is connected to faup1090 / FA dump1090
09/16/2014 18:56:57 faup1090 is decoding messages from dump1090 and piaware is receiving them!
09/16/2014 18:56:57 piaware has successfully sent several msgs to FlightAware!
09/16/2014 18:57:49 165 msgs recv’d from dump1090; 165 msgs sent to FlightAware
09/16/2014 19:02:49 1195 msgs recv’d from dump1090; 1196 msgs sent to FlightAware
09/16/2014 19:07:49 2183 msgs recv’d from dump1090; 2185 msgs sent to FlightAware
09/16/2014 19:12:49 3090 msgs recv’d from dump1090; 3093 msgs sent to FlightAware
09/16/2014 19:17:49 3981 msgs recv’d from dump1090; 3985 msgs sent to FlightAware
Could you please check if you receive data from IDs 2137, 2103 and 2014? Thanky very much in advance. 2022, which works via Planeplotter, is up and running.
Best regards
Thomas
There was a server problem but all is OK now.
My Nearest Airport is IXC (Chandigarh) in India. But, in my account it shows Oberpfaffenhofen (Munich).
