I have 1 Lime Single Board Computer, 960MHz Dual core CPU, 512MB RAM.
I installed dump1090-fa as well as piaware and piaware-web, it used to work on the browser. Recently it is unreacheable to the piaware-web as well as the dump1090-fa map.
OS: Armbian Stretch
Dump1090-fa version is 3.7.2, piaware version also 3.7.2.
Any solution to fix this issue? @abcd567 . Thanks in advance.
Best regards.
abcd567
February 18, 2020, 11:59am
2
What does the browser display at pi_ip
Can you ssh to the Lime SBC?
What is output of following commands:
ping -c 3 google.com
sudo journalctl -eu lighttpd --no-pager
Hi @abcd567 ,
Below are the results:-
root@lime-XRANGE-82519:~# ping -c 3 google.com
PING google.com(kul08s10-in-x0e.1e100.net (2404:6800:4001:80e::200e)) 56 data bytes
64 bytes from kul08s10-in-x0e.1e100.net (2404:6800:4001:80e::200e): icmp_seq=1 ttl=54 time=30.4 ms
64 bytes from kul08s10-in-x0e.1e100.net (2404:6800:4001:80e::200e): icmp_seq=2 ttl=54 time=30.0 ms
64 bytes from kul08s10-in-x0e.1e100.net (2404:6800:4001:80e::200e): icmp_seq=3 ttl=54 time=30.2 ms
--- google.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2001ms
rtt min/avg/max/mdev = 30.059/30.250/30.402/0.201 ms
root@lime-XRANGE-82519:~# sudo journalctl -eu lighttpd --no-pager
-- Logs begin at Tue 2020-02-18 19:02:51 +08, end at Tue 2020-02-18 20:19:55 +08. --
Feb 18 19:03:04 lime-XRANGE-82519 systemd[1]: Starting Lighttpd Daemon...
Feb 18 19:03:06 lime-XRANGE-82519 systemd[1]: Started Lighttpd Daemon.
Feb 18 19:03:08 lime-XRANGE-82519 lighttpd[746]: 2020-02-18 19:03:06: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Feb 18 19:03:08 lime-XRANGE-82519 systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Feb 18 19:03:08 lime-XRANGE-82519 systemd[1]: lighttpd.service: Unit entered failed state.
Feb 18 19:03:08 lime-XRANGE-82519 systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 18 19:03:08 lime-XRANGE-82519 systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 18 19:03:08 lime-XRANGE-82519 systemd[1]: Stopped Lighttpd Daemon.
Feb 18 19:03:08 lime-XRANGE-82519 systemd[1]: Starting Lighttpd Daemon...
Feb 18 19:03:09 lime-XRANGE-82519 systemd[1]: Started Lighttpd Daemon.
Feb 18 19:03:11 lime-XRANGE-82519 lighttpd[806]: 2020-02-18 19:03:09: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Feb 18 19:03:11 lime-XRANGE-82519 systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Feb 18 19:03:11 lime-XRANGE-82519 systemd[1]: lighttpd.service: Unit entered failed state.
Feb 18 19:03:11 lime-XRANGE-82519 systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 18 19:03:11 lime-XRANGE-82519 systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 18 19:03:11 lime-XRANGE-82519 systemd[1]: Stopped Lighttpd Daemon.
Feb 18 19:03:11 lime-XRANGE-82519 systemd[1]: Starting Lighttpd Daemon...
Feb 18 19:03:12 lime-XRANGE-82519 systemd[1]: Started Lighttpd Daemon.
Feb 18 19:03:13 lime-XRANGE-82519 lighttpd[960]: 2020-02-18 19:03:12: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Feb 18 19:03:13 lime-XRANGE-82519 systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Feb 18 19:03:13 lime-XRANGE-82519 systemd[1]: lighttpd.service: Unit entered failed state.
Feb 18 19:03:13 lime-XRANGE-82519 systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 18 19:03:13 lime-XRANGE-82519 systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 18 19:03:13 lime-XRANGE-82519 systemd[1]: Stopped Lighttpd Daemon.
Feb 18 19:03:13 lime-XRANGE-82519 systemd[1]: Starting Lighttpd Daemon...
Feb 18 19:03:14 lime-XRANGE-82519 systemd[1]: Started Lighttpd Daemon.
Feb 18 19:03:15 lime-XRANGE-82519 lighttpd[1108]: 2020-02-18 19:03:15: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Feb 18 19:03:16 lime-XRANGE-82519 systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Feb 18 19:03:16 lime-XRANGE-82519 systemd[1]: lighttpd.service: Unit entered failed state.
Feb 18 19:03:16 lime-XRANGE-82519 systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 18 19:03:16 lime-XRANGE-82519 systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 18 19:03:16 lime-XRANGE-82519 systemd[1]: Stopped Lighttpd Daemon.
Feb 18 19:03:16 lime-XRANGE-82519 systemd[1]: Starting Lighttpd Daemon...
Feb 18 19:03:17 lime-XRANGE-82519 systemd[1]: Started Lighttpd Daemon.
Feb 18 19:03:18 lime-XRANGE-82519 lighttpd[1156]: 2020-02-18 19:03:17: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Feb 18 19:03:18 lime-XRANGE-82519 systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Feb 18 19:03:18 lime-XRANGE-82519 systemd[1]: lighttpd.service: Unit entered failed state.
Feb 18 19:03:18 lime-XRANGE-82519 systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 18 19:03:18 lime-XRANGE-82519 systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 18 19:03:18 lime-XRANGE-82519 systemd[1]: Stopped Lighttpd Daemon.
Feb 18 19:03:18 lime-XRANGE-82519 systemd[1]: Starting Lighttpd Daemon...
Feb 18 19:03:19 lime-XRANGE-82519 systemd[1]: Started Lighttpd Daemon.
Feb 18 19:03:19 lime-XRANGE-82519 lighttpd[1247]: 2020-02-18 19:03:19: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Feb 18 19:03:19 lime-XRANGE-82519 systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Feb 18 19:03:19 lime-XRANGE-82519 systemd[1]: lighttpd.service: Unit entered failed state.
Feb 18 19:03:19 lime-XRANGE-82519 systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 18 19:03:20 lime-XRANGE-82519 systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 18 19:03:20 lime-XRANGE-82519 systemd[1]: Stopped Lighttpd Daemon.
Feb 18 19:03:20 lime-XRANGE-82519 systemd[1]: Starting Lighttpd Daemon...
Feb 18 19:03:20 lime-XRANGE-82519 systemd[1]: Started Lighttpd Daemon.
Feb 18 19:03:21 lime-XRANGE-82519 lighttpd[1269]: 2020-02-18 19:03:21: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Feb 18 19:03:21 lime-XRANGE-82519 systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Feb 18 19:03:21 lime-XRANGE-82519 systemd[1]: lighttpd.service: Unit entered failed state.
Feb 18 19:03:21 lime-XRANGE-82519 systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 18 19:03:21 lime-XRANGE-82519 systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 18 19:03:21 lime-XRANGE-82519 systemd[1]: Stopped Lighttpd Daemon.
Feb 18 19:03:21 lime-XRANGE-82519 systemd[1]: Starting Lighttpd Daemon...
Feb 18 19:03:22 lime-XRANGE-82519 systemd[1]: Started Lighttpd Daemon.
Feb 18 19:03:23 lime-XRANGE-82519 lighttpd[1319]: 2020-02-18 19:03:22: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Feb 18 19:03:23 lime-XRANGE-82519 systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Feb 18 19:03:23 lime-XRANGE-82519 systemd[1]: lighttpd.service: Unit entered failed state.
Feb 18 19:03:23 lime-XRANGE-82519 systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 18 19:03:23 lime-XRANGE-82519 systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 18 19:03:23 lime-XRANGE-82519 systemd[1]: Stopped Lighttpd Daemon.
Feb 18 19:03:23 lime-XRANGE-82519 systemd[1]: Starting Lighttpd Daemon...
Feb 18 19:03:23 lime-XRANGE-82519 systemd[1]: Started Lighttpd Daemon.
Feb 18 19:03:24 lime-XRANGE-82519 lighttpd[1363]: 2020-02-18 19:03:24: (log.c.171) opening errorlog '/var/log/lighttpd/error.log' failed: Permission denied
Feb 18 19:03:24 lime-XRANGE-82519 systemd[1]: lighttpd.service: Main process exited, code=exited, status=255/n/a
Feb 18 19:03:24 lime-XRANGE-82519 systemd[1]: lighttpd.service: Unit entered failed state.
Feb 18 19:03:24 lime-XRANGE-82519 systemd[1]: lighttpd.service: Failed with result 'exit-code'.
Feb 18 19:03:24 lime-XRANGE-82519 systemd[1]: lighttpd.service: Service hold-off time over, scheduling restart.
Feb 18 19:03:24 lime-XRANGE-82519 systemd[1]: Stopped Lighttpd Daemon.
Feb 18 19:03:24 lime-XRANGE-82519 systemd[1]: lighttpd.service: Start request repeated too quickly.
Feb 18 19:03:24 lime-XRANGE-82519 systemd[1]: Failed to start Lighttpd Daemon.
Thanks again.
sudo chown -R www-data:www-data /var/log/lighttpd/
sudo systemctl restart lighttpd
abcd567
February 18, 2020, 7:53pm
5
Hopefully suggestion by @wiedehopf should solve the problem.
Does this solution survive a reboot?
If not, what is the output of following command?
cat /etc/fstab
Does the output contain a line like below?
tmpfs /var/log tmpfs
I have asked this question because I have experienced this problem on Flightradar24’s Pi24 image couple of years ago , and found that the folder /var/log of Pi24 image was on volatile memory (ram). As a result, the folder /var/log/lighttpd got erased on reboot, and lighttpd was NOT able to recreate it (this folder is created once only at the time of installation of lighttpd). I solved it by adding following lines to /etc/rc.local
mkdir -p /var/log/lighttpd
touch /var/log/lighttpd/error.log
chmod 666 /var/log/lighttpd/error.log
A better way to solve it is adding following lines just above the line starting with ExecStart= in file /usr/lib/systemd/system/lighttpd.service
ExecStartPre=/bin/mkdir -p /var/log/lighttpd
ExecStartPre=/bin/touch /var/log/lighttpd/error.log
ExecStartPre=/bin/chmod 666 /var/log/lighttpd/error.log
@wiedehopf , you have save my piaware installation. Thanks.
I did reboot and it still work. At least I don’t need to format and re-image the OS and re-install again.
Best Regards.
abcd567:
cat /etc/fstab
Hi @abcd567 ,
I’m using the suggestion from @wiedehopf and it works even after reboot, thanks for your guides for the adding of lighttpd.
Best regards.
