Hey everyone,
Just wondering if any Canadians on here would like to share their sources for cabling in their ADS-B setups.
Hey everyone,
Sorry, I dont use quality cable. Rather I use the cheapest available cable, which I purchased from Dollarama, 50 ft coil of RG6 for Canadian $6.99 ![]()
Did you just use adapters to make everything work to and from the coax F connectors? If so where did you get your adapters?
I have the Flightaware antenna, so I need the cable to be N male to SMA male.
At FA antenna end, I use N-male to F-female adapter, and at Filter end I use F-female to SMA-male pigtail. The pigtail is better than adapter as it provides flexibility and reduces mechanical pull on the Fiter & Dongle. I purchased the pigtails from Amazon.ca/Ebay.ca. Please see image 1 below.
Please see image 2 below.
Please also see this thread:
Flightaware Coaxial Cables
(3) Be careful when ordering cables/pigtails/connectors for SMA. The SMA connector comes in two verieties:
(a) SMA: male has pin, female has hole
(b) RP-SMA: male has hole, female has pin. Used mainly on WiFi.
Please see image 3 below.
Image 1 of 3
Image 2 of 3
Image 3 of 3
This is FA antenna’s connection using RG6 coax:
N-male to F-female adapter at antenna
F-female to MCX-male pigtail at DVB-T end.
For FA Pro Stick and/or FA filter, pigtail is F-male to SMA-male. The pigtail cable is RG316.
Pgtails & adapters purchased from ebay.ca & amazon.ca
For those of you in Canada looking for an easy way to get high quality cables with the proper terminations on them check out Infinite Cables.
Just look under Antenna Cables & Accessories.
Dang… thank you for that link!! Being in Canada, its huge after my hours of searching.
Thank you as well for all the details in your posts!
