I have tried to configure VRS (Virtual Radar Server) on my Windows Desktop to feed data to Flightaware without need of a data feeder. I followed example of Kinetics SBS3. Aparently it seems to succeed, but I am not sure.
Can any forum member, or Flightaware staff member, answer my following questions:
QUESTION 1: Is my VRS really feeding data to Flightaware?
QUESTION 2: If answer to above question is yes, then what is my station ID on Flightaware?
@abcd567: FlightAware will give you a license for PlanePlotter so you can do as Me109 says and you wonât have to pay for PP. flightaware.com/planeplotter
Hi jepolch!
Thanks for suggestion.
Two years ago I did try planeplotter, but did not like it, particularly itâs graphic display, and quit it after few days trial.
I prefer VRSâs map display over planeplotterâs display. That is why I am trying to use VRS to feed Flightaware.
Pretty sure thatâs not a supported way to try to get data in - itâs for real SBS-3âs.
Where is your data actually coming from? Can you feed it directly from there with piaware? Generally feeding at the point of capture is a better plan, regardless of what you then do to aggregate it for your own use.
Right now I have 2 main systems which are feeding flightaware 24/7 (system 1 & 2 below). In addition I have setup a third system (#3 below) which is Windows based and I am experimenting to feed flightaware from it.
System 1: Coco antenna > short coax > dvb-t > RPi with dump1090 mutability & piaware data feeder.
System 2: Cantenna antenna > short coax > dvb-t > RPi with dump1090 mutability & piaware data feeder.
System 3: Cantenna antenna > amplifier > 50ft rg6 coax > dvb-t > Windows Desktop with RTL1090 and VRS.
If you have to stick with Windows then I think youâre limited to using Planeplotter to feed at the moment. You can always run that in parallel with VRS if you wantâŚ
Or - itâs massive overkill but you could run a debian VM hosted on the windows PC and run piaware there, feeding from rtl1090 over the virtualized network. piaware doesnât support non-local feeds yet so youâd need to have a little netcat/socat tunnel or a --net-only dump1090 on the VM too.
Thanks Oliver for taking your time & providing valuable advise.
I did not know if VRS is capable to feed flightaware. It looked to me that VRS may possibly do the job. What I was trying was actually an experiment. I do not intend to feed data from the windows desktop as my normal setup.
For initial 1½ years, I did not have any RPi and was intermittently feeding data from my windows desktop, which I kept operating when needed for some other work, and shut it down when the other works finished (to reduce electricity bills + computer repair bills). During this period I fed dara to planefinder, fr24 & radarbox24 which had windows data feeder clients and did not need planeplotter. I did not feed data to flightaware during this initial period due to non avalability of their windows based data feeder client.
The very reason I installed RPi and switched data feeding from windows desktop to RPis is that I can leave these running 24/7 (very cost effective & power thrifty). It also gave me advantage of feeding flightaware using piaware data client.
