BUGS
Oops, OK, fixed on the back-end but I think it will take a little time before the system catches up and starts to sort it out.
Looks like you’re winning Dan, 301/2DQ both now only showing B737s for the past 48hrs. :slight_smile:
There’s a big problem with the track logs but this site is bolloxed with ANOTHER problem as it won’t let anyone post track logs to illustrate the problem. It comes back as DEBUG MODE when trying to post. In fact this has been happening for at least 3 years and I posted about it back then and it still hasn’t been fixed. Admin try to copy and paste a track log here and watch what happens. :bulb:
Easy fix Rob…
Post the URL to the track log… and point out the times you have problems with in the text of your posting.
Problem solved. :unamused:
The debug error has been around here forever. The debug issue is not something that FA can really fix. It is an issue with the forum, which FlightAware doesn’t control. The vast majority of us here have either figured out how to work around it or have, as Allen pointed out, just posted the link to show where the issue is. Here’s an idea, EMAIL dbaker or mduell with the track log.
flightaware.com/live/flight/ETH5 … B/tracklog
I was following this flight live. The transatlantic report for 50w briefly appeared in the log at 1959 showing a time of 1931 for 50w but then disappeared and hasn’t reappeared. I’ve noticed this with a lot of oceanic position reports - they appear briefly around 20-25 mins after it’s passed the position, but then they drop out again pretty soon after. Something not working properly…
bump
bump.
Is anyone looking into these issues? :confused:
Another odd one that appears to be a bug are flights
TWN1
TWN2
TWN3
TWN4
These show every day and show a track across the Pond but when your look at the track log there’s nothing there. Also, TWN is a Uzbekistan Antonov operator with no 757s in their fleet and certainly no regular service between Paris and New York! These flights happen to mirror the Open Skies flights BOS1-4 exactly. BOS are not unfiltered in the ASDI feed hence why they don’t show, but what is the reason for these spurious TWN flights that don’t exist? I checked the Eurocontrol CFMU for these TWN flights and no flight plans exist nor have ever existed so they need deleting from the system here. :bulb:
Those are the open skies flights on the wrong identifier.
Flight N5071J
flightaware.com/live/flight/N5071J
somehow “hopped” from Auburn Muni to Palm Springs.
