Look what I found last night!
That is awesome !!
I have always wondered if the ISS was ADS-B equipped.
Fantastic !!
But why does that entry look āeditedā ??
What day is it again?
It aināt Xmas, I canāt see any presents
Completely forgot about that.
OK - I was had.
Damn !!
Came here to say my traffic is way down and I might have water intrusion again. Went from a high of 534k down to 182k yesterday. I guess itās down for everyone.
I think you can be pretty confident itās not water intrusion.
next to nothingā¦
Damn, you were faster with that
CoVid19 has unloaded my receiver, a good test if an undesired one.
In more normal times my 1090 MHz site peaks at about 2,000 messages / second and about 380 aircraft. Max range peaks about 230 nmi, minimum around zero as helicopters pass overhead.
I suspected even with the Airspy mini and a Pi4 clocked at 1800 MHz signal overlap might be limiting reception of weaker signals.
Now, the site peak traffic is well under half that, and the max range peak is just about as before. So I qualitatively concluded Iām not range limited by traffic density.
Indoor plants growing generate an IR signatureā¦ Plants might be useful against boredom.
I note the same, though I have not changed my gain or anything.
I did notice one other thing, qualitatively and anecdotally. I also feed Planefinder. The stats page reports that I have half of the messages as DF-17 messages. That I think is more than it was a month or so ago. I thought i used to be more like a third of all incoming messages were DF-17. Unfortunately, in the absence of hard data I have to rely on my memory.
Makes sense, DF-17 is in a Mode S ADS-B reply and at least in the USA the deadline for that implementation was the first of this year.
so that would not be a traffic density related change then.
Snapped just now from my VRS (http://essexradar.co.uk). 17:47z (18:47 local time). Thereās normally more traffic than this at 02:00 in the morning!
FlightFeeder station in South Africa. Lockdown started at Midnight on Thursday. Station has been powered and online throughout. Just very little air traffic. It seems today will be the day many loose there āonlineā streaks.
