Main feeder with Airspy completed as well and not really noticing any difference in ADS-B or overall CPU utilisation.
The CPU difference is in the demodulator … all this posting about changed CPU usage is a bit pointless in regards to the airspy.
With airspy the demodulation is done in the airspy service.
Like a broken pencil ![]()
I’ll get my coat.
" Just a reminder for those with piaware package installs , you’ll need to update dump1090-fa (and dump978-fa if applicable) via the stats page as well to pull in the new dump1090-fa and SkyAware changes."
I don’t have a clue what this means.
A “Package Install” is that what was copied onto the SD card to get my Pi running in the first instance?
So I look for the gear icon and should be able to upgrade there.
How do I upgrade the dump1090?
Your stats page says : Feeder Type: PiAware (Debian Package Add-on) 5.0
which means you took a standard Raspbian Image and installed piaware and dump1090-fa to it using these instructions PiAware - dump1090 ADS-B integration with FlightAware - FlightAware
The alternative way to install PiAware is to take the PiAware SD card image containing all the PiAware/dump1090-fa/dump978-fa software built-in and flash your SD card with it.
To upgrade dump1090-fa, click the gear icon and select “Upgrade and restart dump1090-fa” under Device Commands if you haven’t yet.
I seem to have achieved the step to V5 via the “sudo apt-get upgrade” instruction, so that bit is done. (The process too well over 30 mins!)
I’ll try and find the Device Command.
Thanks for your reply.
Wait, I have a cunning plan!
Yes I see you are on dump1090-fa 5.0 so you’re good to go
@wwshack wasn’t the only one having problems interpreting this advice.
I read it as saying that after doing a package update to v5 using apt upgrade, you also needed to upgrade dump1090-fa via the stats page to make the update “stick”.
I’ve been scratching my head as to why you would need to do this twice!
If you trigger the upgrade from the stats page, on a package install behind the scenes it’s essentially doing an “apt upgrade piaware” which will upgrade specifically the piaware feeder package only (we don’t want to unexpectedly upgrade unrelated packages which you might not be expecting). To also upgrade dump1090 or dump978 from the stats page currently requires a second separate upgrade command.
If you’re on a piaware sdcard install, a stats page upgrade command upgrades the piaware-release metapackage which pulls in updated versions of all the sdcard image components, so there’s no second step.
If you manually do an apt upgrade of all packages, obviously that gets everything at once, as you say.
I have been able to upgrade to PiAware and SkyAware 5.0 although my SkyAware has a strange version number 5.0-bp09+1
I am unable to see the sliders for the filters. Is this a different version? Also is it possible to get the flight numbers to show on the map (next to the aircraft) as per the earlier screenshot.
Mark
Are you running Raspbian Stretch rather than Buster?
You are using Stretch
bp09 = back port version 9 (OS version 9 = Stretch)
Time to re-image to latest image which is Buster.(OS version 10)
Thanks for the advice. Will give that a go!
Better Use a spare microSD card for Buster image and do not reimage existing microSD card. Leave existing one intact as backup till you are satisfied with fresh install of Buster image.
Thanks to @obj for commit 455896e (Fix broken 32-bit x86 test that broke builds on non-x86).
After adding line git reset --hard 455896e in PKGBUILD file, could sucessfully install Piaware ver 5.0 on following:
Machine: Raspberry Pi Model 4
OS:
(1) Arch Linux armv7 (32-bit)
(2) Arch Linux aarch64 (64-bit)
Guide and installation scripts:
(1) - Install dump1090-fa (on armv7 and aarch64 OS)
https://github.com/abcd567a/dump1090-fa-arch/blob/master/README.md
(2) - Install piaware (on armv7 and aarch64 OS):
https://github.com/abcd567a/piaware-arch/blob/main/README.md
NOTE: For Ver 5.0, following lines were added to file PKGBUILD ofdump1090-fa:
In function build() :
In function package():
mkdir -p ${pkgdir}/usr/share/skyaware/html
cp -r ${srcdir}/dump1090/public_html_merged/* ${pkgdir}/usr/share/skyaware/html
mkdir -p ${pkgdir}/usr/lib/dump1090-fa/
cp -r ${srcdir}/dump1090/starch-benchmark ${pkgdir}/usr/lib/dump1090-fa/
cp -r ${srcdir}/dump1090/debian/generate-wisdom ${pkgdir}/usr/share/dump1090-fa/
No lines were added to copy new file 89-skyaware.conf to ${pkgdir}, as following existing command did the job:
cp -r ${srcdir}/dump1090/debian/lighttpd/* ${pkgdir}/etc/lighttpd/conf.d
I selected “Upgrade and restart dump1090” 15 minutes ago. Both dump1090-fa and piaware packages were upgraded to 5.0, and services restarted without a second click. (piaware-web package is also installed.)
Two additional observations:
- “Which version of PiAware are you running?” dropdown on PiAware - Upgrade PiAware to the latest version - FlightAware still only shows up to 3.0
- When I follow abcd567’s instructions to build and install 5.0 including piaware-web on a Debian x86_64 machine, the new Web GUI at the original URI /dump1090-fa/ shows a warning “This version of SkyAware will soon be depcrecated. Visit URL: [local IP Address]/skyaware for the most up-to-date SkyAware interface.” Additionally, the root URI now links to /skyaware/, rather than to /dump1090-fa/ as it did in 4.0. However, after package updates on Raspberry Pi, there is no warning on /dump1090-fa/, and the root URI still links to /dump1090-fa/. This seems strange because I assume that both builds would come from the same source.
What image are you using?
One of my recievers won’t upgrade to 5.0. It’s Buster image with PiAware package add-on.
Pastebin log; Create a new version of paste: - Pastebin.com
Looks like your install has damaged package information (filesystem / sdcard corruption?)
