News link (Ignore the cookie prompts until after you’ve viewed it, blocking the cookies makes the site go away)
Watch the video above first.
Discuss:
I find it extremely unlikely that it is physically possible for the gear to indicate down when it is not down and locked. That’s the whole point of the indicating system.
If the pilots knew there was a gear issue, why on earth did they drag the belly on the ground, and THEN choose to go around. Sounds extremely unsafe.
If the pilots did not know the gear was unsafe, at what point did they realize? My guess would be another airplane and/or ATC told them to go around. The spool-up time on turbine engines would limit the reaction from the time the belly starts dragging to the time the airplane becomes airborne again.
Referencing #4, how the hell could they not know the gear is unsafe!? Besides the aerodynamics, the gear unsafe warning horn, and the EGPWS yelling “TOO LOW, GEAR…TOO LOW, GEAR!” My guess is they knew there was an issue, but that still leaves question #2.
Since when is the ERJ capable of dumping fuel?
That seemed to be the only major error in this story, so I guess they’re getting batter. At least they didn’t call it a twin engine Cessna.
