We should probably start a new thread just for RPIMonitor.
I added GPU temp to the temperature gauge.
Not sure if they are ever very different but it was using
cat /sys/class/thermal/thermal_zone0/temp
so I added the
vcgencmd measure_temp
version which gets the GPU temp, I believe.
This goes in /etc/rpimonitor/template/temperature.conf
# Extract CPU Temperature information
# Page: 1
# Information Status Statistics
# - cpu temperature - yes - yes
# Note: Rounding temperatures to two digits is done with the
# post-processiing formula: sprintf("%.2f", $1/1000)
# It is possible to roud to 1 digit with sprintf("%.1f", $1/1000)
dynamic.12.name=soc_temp
dynamic.12.source=/sys/devices/virtual/thermal/thermal_zone0/temp
dynamic.12.regexp=(.*)
dynamic.12.postprocess=sprintf("%.2f", $1/1000)
dynamic.12.rrd=GAUGE
dynamic.13.name=gpu_temp
dynamic.13.source=vcgencmd measure_temp
dynamic.13.regexp=temp=(.*)'C
dynamic.13.postprocess=sprintf("%.2f", $1)
dynamic.13.rrd=GAUGE
web.status.1.content.4.name=Temperature
web.status.1.content.4.line.1=JustGageBar("CPU Temperature", data.soc_temp+"°C", 30, data.soc_temp, 80, 100, 80)+" "+JustGageBar("GPU Temperature", data.gpu_temp+"°C", 30, data.gpu_temp, 80, 100, 80)
web.statistics.1.content.8.name=Temperature
web.statistics.1.content.8.graph.1=soc_temp
web.statistics.1.content.8.ds_graph_options.soc_temp.label=CPU temperature (°C)
web.statistics.1.content.8.graph.2=gpu_temp
web.statistics.1.content.8.ds_graph_options.gpu_temp.label=GPU temperature (°C)
Please do. I’d like to install it on my Pi4 when I get decent enough weather to lower the mast and it’s a bit of a pain searching through this threadnought.
It got colder so the CPU can run at max frequency instead of what was running before?
It happend to me, because my power supply got hot and had lass than 5.1V (triggered undervoltage limiter of CPU).
PS: I noticed that my Amazon Kindle PS is rated for 5.2V!!! They know something…
The rpi monitor is running airspy -v i suppose to display the version number?
I’m really not sure what happened.
The way i grab the airspy CPU load is not very elegant, but it works and that’s good enough so far.
If it was like my installation, piaware (the application) had stopped communicating with the FlightAware server. The connection between my RPI4 and FlightAware had been closed for many hours. the piaware process was running at 100%.
After rebooting, piaware was communicating normally with FlightAware and was down to using very minimal CPU.
There was nothing useful to see in daemon.log. piaware.log showed the following (between the time I woke up and saw the problem and the time I rebooted shortly thereafter) – pretty much nothing of interest except for:
Oct 24 04:08:48 raspberrypi piaware[825]: 2154016 msgs recv’d from dump1090-fa (1382 in last 5m); 2147682 msgs sent to FlightAware
Oct 24 04:11:19 raspberrypi piaware[825]: Lost connection to adept server at 70.42.6.224/1200: server closed connection
Oct 24 12:53:55 raspberrypi piaware[780]: creating pidfile /run/piaware/piaware.pid
Oct 24 12:53:55 raspberrypi piaware[780]: ****************************************************
During the whole time that my RPI4 was not communicating with FlightAware, the graphs show that the Airspy and dump1090-fa were working and collecting aircraft data the whole time. There is no break in ADSB detection in my local graphs on the PI4. Everything looks completely normal in all of the logs and my local graphs, with the exception of lost communications between piaware and FlightAware servers at midnight EST.
I bet this is a tcltls bug. I thought we distributed packages that worked around it, though.
edit: oh, Pi 4, so not a sdcard image. Did you pick up the packaged version of tcl-tls from the FlightAware repository, or do you have the standard raspbian version?
This is the wrong thread for this discussion, but oh well. If it is a tcl-tls bug, keep in mind that I’m running Raspian Buster Lite on an RPI4 with Flightaware 3.7.2 installed – if that is of any help. Everyone with a feeder didn’t go down, obviously. So it must be unique to a specific platform / version of piaware.
I did not specifically install any tcl-tls stuff. I just installed Raspian Buster Lite and piaware (and Airspy stuff and graphs). So I guess I would have to say “no, I didn’t do that”. Wouldn’t know how.
