ADSB.im
Morning All,
I am using the suggested method of feeding multiple aggregators and using ADSB.im which was very easy to get up and running but I am getting a lot of issues and cannot find support to assist me in troubleshooting. I have comprehensive logging of all the aggregators through Dozzle but I don’t really know how to proceed.
This is how things are looking currently but it constantly changes:
Is anyone able to help or point me in the right direction to ask for help? I have lots of log data but unsure how to interpret it to be honest with you.
Thanks in advance
David
Hi David,
Maybe @dirkhh or @wiedehopf are able to assist you with that, Dirk is the creator of the software and Wiedehopf is very knowledgeable about it as well.
Thats handy to know, thanks for that Tom
for FA MLAT issues you can go read the thread “MLAT red” next to this.
Bad MLAT is discussed here regularly.
plane.watch showing bad status is likely on their side (assuming the share key is correct, no extra spaces or something maybe?)
In other words: adsb.im is working fine :slight_smile:
Good Morning,
Looking at the logs in Dozzle I have noticed these constant errors:
FR24
[2026-09-01 10:23:15.808][fr24feed] [reader][i]Connecting to unknown receiver via (tcp://ultrafeeder:30005)
[2026-09-01 10:23:15.808][fr24feed] [reader][e]Could not connect to tcp://ultrafeeder:30005
OpenSky
[2026/09/01 11:23:57][opensky-feeder] [WARN] [INPUT] Could not connect: Connection refused (111)
[2026/09/01 11:23:57][opensky-feeder] [WARN] [INPUT] Tried all addresses of ‘ultrafeeder’: could not connect
pfclient (PlaneFinder)
[2026-09-01 11:24:12.769][pfclient_log] 2026-09-01 10:24:12.768710 [V] Failed to open connection to socket: Connection refused (errno: 111)
[2026-09-01 11:24:12.769][pfclient_log] 2026-09-01 10:24:12.768876 [-] Failed TCP connection to all provided addresses for: ultrafeeder:30005
PlaneWatch
[pw-feeder] 2026-09-01T11:23:57+01:00 ERR error reading from socket error=EOF conn=client-side dst=feed.push.plane.watch:12345 proto=BEAST src=ultrafeeder:30005
[mlat-client] Tue Sep 1 11:23:57 2026 Lost connection to ultrafeeder:30005
[mlat-client] Tue Sep 1 11:23:57 2026 Reconnecting in 30.0 seconds
What’s the log for ultrafeeder then?
  • [2026-09-01 15:54:46.325][readsb] BeastReduce TCP output: Connection established: feed.flyrealtraffic.com (52.42.87.42) port 30004
  • [2026-09-01 15:54:46.330][readsb] BeastReduce TCP output: Connection established: feed1.adsbexchange.com (44.249.176.157) port 30004
  • [2026-09-01 15:54:46.330][mlat-client][feed.airplanes.live] Input format changed to BEAST, 12MHz clock
  • [2026-09-01 15:54:46.403][readsb] BeastReduce TCP output: Connection established: skyfeed.hpradar.com (27.66.248.42) port 30004
  • [2026-09-01 15:54:46.461][readsb] Found Rafael Micro R820T tuner
  • [2026-09-01 15:54:46.722][mlat-client][feed.adsb.lol] Input connected to localhost:30005
  • [2026-09-01 15:54:46.726][mlat-client][feed.adsb.lol] Detected BEAST format input
  • [2026-09-01 15:54:46.727][mlat-client][feed.adsb.lol] Input format changed to BEAST, 12MHz clock
  • [2026-09-01 15:54:46.950][tar1090] Found aircraft.json in /run/readsb, continuing operation as per usual!
  • [2026-09-01 15:54:47.871][readsb] Database update in progress!
  • [2026-09-01 15:54:48.625][readsb] Database update first part took 2.151 seconds!
  • [2026-09-01 15:54:48.628][readsb] Database update done! (critical part took 0.002 seconds)
  • [2026-09-01 15:54:52.153][collectd] [warning] <urlopen error [Errno 2] No such file or directory: ‘/usr/share/graphs1090/data-symlink/data/stats.json’>
  • [2026-09-01 15:54:52.275][readsb] BeastReduce TCP output: Remote server disconnected: data.avdelphi.com port 24999 (fd 38, SendQ 0, RecvQ 0)
  • [2026-09-01 15:54:52.384][readsb] BeastReduce TCP output: Connection established: data.avdelphi.com (140.238.220.39) port 24999
  • [2026-09-01 15:54:52.640][mlathub] Beast TCP output: Connection established: localhost (127.0.0.1) port 30004
  • [2026-09-01 15:54:55.942][mlat-client][adsb.dataero.eu] Input connected to localhost:30005
  • [2026-09-01 15:54:55.947][mlat-client][adsb.dataero.eu] Detected BEAST format input
  • [2026-09-01 15:54:55.947][mlat-client][adsb.dataero.eu] Input format changed to BEAST, 12MHz clock
  • [2026-09-01 15:54:55.967][mlat-client][feed.adsbiq.com] Input connected to localhost:30005
  • [2026-09-01 15:54:55.994][mlat-client][feed.adsbiq.com] Detected BEAST format input
  • [2026-09-01 15:54:55.995][mlat-client][feed.adsbiq.com] Input format changed to BEAST, 12MHz clock
  • [2026-09-01 15:54:56.558][mlat-client][feed.adsb.fi] Input connected to localhost:30005
  • [2026-09-01 15:54:56.567][mlat-client][feed.adsb.fi] Detected BEAST format input
  • [2026-09-01 15:54:56.569][mlat-client][feed.adsb.fi] Input format changed to BEAST, 12MHz clock
  • [2026-09-01 15:54:56.685][mlat-client][feed.adsbexchange.com] Input connected to localhost:30005
  • [2026-09-01 15:54:56.702][mlat-client][feed.adsbexchange.com] Detected BEAST format input
  • [2026-09-01 15:54:56.702][mlat-client][feed.adsbexchange.com] Input format changed to BEAST, 12MHz clock
  • [2026-09-01 15:54:57.518][mlat-client][feed.theairtraffic.com] Input connected to localhost:30005
  • [2026-09-01 15:54:57.527][mlat-client][feed.theairtraffic.com] Detected BEAST format input
  • [2026-09-01 15:54:57.528][mlat-client][feed.theairtraffic.com] Input format changed to BEAST, 12MHz clock
you cut off the startup (or rather last crash) … probably constantly restarting …
filtering for readsb helps.
Probably it’s just a bad SDR.
Sorry not sure how to filer the log but this is the most recent mention of READSB
  • [2026-09-02 09:26:33.836][mlathub] Beast TCP output: Connection to localhost port 30004 failed 10 times, suppressing most error messages until connection succeeds
  • [2026-09-02 09:26:33.859][tar1090] No aircraft.json found in /run/readsb during the last 30 seconds! Try restarting dump1090 or reinstalling tar1090 if you switched dump1090 to readsb!
  • [2026-09-02 09:26:38.449][readsb] invoked by: /usr/local/bin/readsb --net --quiet --lat 52.757991 --lon -2.55661 --uuid-file=/run/uuid --write-json=/run/readsb --write-state=/var/globe_history --json-reliable=1 --net-json-port=30047 --net-ri-port=30001 --net-ro-port=30002 --net-sbs-port=30003 --net-sbs-in-port=32006 --net-sbs-jaero-in-port=32009 --jaero-timeout=37 --net-bi-port=30004,30104 --net-bo-port=30005 --net-beast-reduce-out-port=30006 --net-api-port=30152 --heatmap-dir=/var/globe_history --heatmap=15 --net-sbs-reduce --json-location-accuracy=2 --write-state-only-on-exit --max-range=300 --stats-range --net-beast-reduce-interval=0.5 --json-trace-interval=15 --net-connector=adsb.dataero.eu,30005,beast_reduce_plus_out,uuid=ad529f9f-14ab-4ed7-9edf-18c4904d4b5f --net-connector=data.avdelphi.com,24999,beast_reduce_plus_out,uuid=05d99a4e-5f74-4dc5-98c4-a200e4385af9 --net-connector=dati.flyitalyadsb.com,4905,beast_reduce_plus_out,uuid=959b2c77-210c-4720-b0a5-d5eb2afe6c17 --net-connector=feed.adsb.fi,30004,beast_reduce_plus_out,uuid=c9cdec8b-103a-4d7a-80da-6d7d579ea5c3 --net-connector=feed.adsb.lol,30004,beast_reduce_plus_out,uuid=20f37b70-e0c6-4e03-b08f-a318a0191f9a --net-connector=feed.adsbiq.com,30004,beast_reduce_plus_out,uuid=cc6540c8-455b-4315-9612-018998974d08 --net-connector=feed.airplanes.live,30004,beast_reduce_plus_out,uuid=4b8b58cb-58a9-4f7e-87c7-a190b81f3628 --net-connector=feed.flyoverhead.com,30004,beast_reduce_plus_out,uuid=fe28f81f-86f8-4a49-8178-058b32308279 --net-connector=feed.flyrealtraffic.com,30004,beast_reduce_plus_out,uuid=0187ecbc-f131-4672-8ad7-62f355a6e032 --net-connector=feed.planespotters.net,30004,beast_reduce_plus_out,uuid=9e8de0b0-b9a3-443c-8e06-63423b23f65e --net-connector=feed.theairtraffic.com,30004,beast_reduce_plus_out,uuid=223afaae-beab-4777-985c-d3a90118e18b --net-connector=feed.tryflightdeck.com,30004,beast_reduce_plus_out,uuid=6f5d45b1-16ab-44c0-972b-c877b9d1f411 --net-connector=feed1.adsbexchange.com,30004,beast_reduce_plus_out,uuid=eb9d1f25-e5b2-49de-8db6-860d7bc2bed0 --net-connector=skyfeed.hpradar.com,30004,beast_reduce_plus_out,uuid=b8ec93e8-bb0d-4d90-9f02-9237e6aee31e --net-heartbeat=35 --net-ro-interval-beast-reduce=0.12 --db-file=/usr/local/share/tar1090/aircraft.csv.gz --db-file-lt --device-type=rtlsdr --gain=autogain --device=00001000
  • [2026-09-02 09:26:38.450][readsb] [2026-09-02 09:26:38.449 BST] readsb starting up.
It’s not hard, there is something like a search box in dozzle.
If you can’t find the error, can only guess.
You could disable all the aggregators you see there … the log becomes simpler then.
Found the search function finally! this is the log for the last 15 minutes or so mentioning readsb
  • [2026-09-03 11:30:32.810][readsb] Database update first part took 2.051 seconds!
  • [2026-09-03 11:30:32.813][readsb] Database update done! (critical part took 0.003 seconds)
  • [2026-09-03 11:32:09.779][readsb] cb transfer status: 1, canceling…
  • [2026-09-03 11:32:09.779][readsb] FATAL: rtlsdr_read_async returned unexpectedly, probably lost the USB device, bailing out
    [2026-09-03 11:32:09.787][readsb] saving state …
  • [2026-09-03 11:32:13.850][readsb] … done, saved 526 aircraft in 4.064 seconds!
  • [2026-09-03 11:32:13.850][readsb] [2026-09-03 11:32:13.850 BST] Abnormal exit. uptime: 0d 0h 1m 43.663s
  • [2026-09-03 11:32:15.282][readsb] delaying restart by 15 seconds
  • [2026-09-03 11:32:26.990][tar1090] No aircraft.json found in /run/readsb during the last 30 seconds! Try restarting dump1090 or reinstalling tar1090 if you switched dump1090 to readsb!
  • [2026-09-03 11:32:30.311][readsb] invoked by: /usr/local/bin/readsb --net --quiet --lat 52.757991 --lon -2.55661 --uuid-file=/run/uuid --write-json=/run/readsb --write-state=/var/globe_history --json-reliable=1 --net-json-port=30047 --net-ri-port=30001 --net-ro-port=30002 --net-sbs-port=30003 --net-sbs-in-port=32006 --net-sbs-jaero-in-port=32009 --jaero-timeout=37 --net-bi-port=30004,30104 --net-bo-port=30005 --net-beast-reduce-out-port=30006 --net-api-port=30152 --heatmap-dir=/var/globe_history --heatmap=15 --net-sbs-reduce --json-location-accuracy=2 --write-state-only-on-exit --max-range=300 --stats-range --net-beast-reduce-interval=0.5 --json-trace-interval=15 --net-connector=adsb.dataero.eu,30005,beast_reduce_plus_out,uuid=ad529f9f-14ab-4ed7-9edf-18c4904d4b5f --net-connector=data.avdelphi.com,24999,beast_reduce_plus_out,uuid=05d99a4e-5f74-4dc5-98c4-a200e4385af9 --net-connector=dati.flyitalyadsb.com,4905,beast_reduce_plus_out,uuid=959b2c77-210c-4720-b0a5-d5eb2afe6c17 --net-connector=feed.adsb.fi,30004,beast_reduce_plus_out,uuid=c9cdec8b-103a-4d7a-80da-6d7d579ea5c3 --net-connector=feed.adsb.lol,30004,beast_reduce_plus_out,uuid=20f37b70-e0c6-4e03-b08f-a318a0191f9a --net-connector=feed.adsbiq.com,30004,beast_reduce_plus_out,uuid=cc6540c8-455b-4315-9612-018998974d08 --net-connector=feed.airplanes.live,30004,beast_reduce_plus_out,uuid=4b8b58cb-58a9-4f7e-87c7-a190b81f3628 --net-connector=feed.flyoverhead.com,30004,beast_reduce_plus_out,uuid=fe28f81f-86f8-4a49-8178-058b32308279 --net-connector=feed.flyrealtraffic.com,30004,beast_reduce_plus_out,uuid=0187ecbc-f131-4672-8ad7-62f355a6e032 --net-connector=feed.planespotters.net,30004,beast_reduce_plus_out,uuid=9e8de0b0-b9a3-443c-8e06-63423b23f65e --net-connector=feed.theairtraffic.com,30004,beast_reduce_plus_out,uuid=223afaae-beab-4777-985c-d3a90118e18b --net-connector=feed.tryflightdeck.com,30004,beast_reduce_plus_out,uuid=6f5d45b1-16ab-44c0-972b-c877b9d1f411 --net-connector=feed1.adsbexchange.com,30004,beast_reduce_plus_out,uuid=eb9d1f25-e5b2-49de-8db6-860d7bc2bed0 --net-connector=skyfeed.hpradar.com,30004,beast_reduce_plus_out,uuid=b8ec93e8-bb0d-4d90-9f02-9237e6aee31e --net-heartbeat=35 --net-ro-interval-beast-reduce=0.12 --db-file=/usr/local/share/tar1090/aircraft.csv.gz --db-file-lt --device-type=rtlsdr --gain=autogain --device=00001000
  • [2026-09-03 11:32:30.312][readsb] [2026-09-03 11:32:30.311 BST] readsb starting up.
  • [2026-09-03 11:32:30.312][readsb] readsb version: 3.16.15 wiedehopf git: b499ecb (committed: Wed May 13 18:11:18 2026 0000)
  • [2026-09-03 11:32:30.312][readsb] autogain enabled, silent mode, suppressing gain changing messages
  • [2026-09-03 11:32:30.312][readsb] lowestGain: 0.0 noiseLowThreshold: 34 noiseHighThreshold: 36 loudThreshold: 243
  • [2026-09-03 11:32:30.312][readsb] Using lat: 52.757991, lon: -2.556610 (location accuracy: exact)
  • [2026-09-03 11:32:30.316][readsb] loading state …
  • [2026-09-03 11:32:30.395][readsb] actual range outline, read bytes: 368644
  • [2026-09-03 11:32:30.398][readsb] … done, loaded 524 aircraft in 0.081 seconds!
  • [2026-09-03 11:32:30.398][readsb] aircraft table fill: 0.0
  • [2026-09-03 11:32:30.405][readsb] 30002: Raw TCP output port
  • [2026-09-03 11:32:30.405][readsb] 30005: Beast TCP output port
  • [2026-09-03 11:32:30.405][readsb] 30006: BeastReduce TCP output port
  • [2026-09-03 11:32:30.405][readsb] 30047: Position json output port
  • [2026-09-03 11:32:30.405][readsb] 30003: SBS TCP output ALL port
  • [2026-09-03 11:32:30.405][readsb] 32006: SBS TCP input MAIN port
  • [2026-09-03 11:32:30.405][readsb] 32009: SBS TCP input JAERO port
  • [2026-09-03 11:32:30.405][readsb] 32007: SBS TCP input MLAT port
  • [2026-09-03 11:32:30.405][readsb] 32008: SBS TCP input PRIO port
  • [2026-09-03 11:32:30.409][readsb] 30001: Raw TCP input port
  • [2026-09-03 11:32:30.409][readsb] 30004: Beast TCP input port
  • [2026-09-03 11:32:30.409][readsb] 30104: Beast TCP input port
  • [2026-09-03 11:32:30.439][readsb] 30152: API output port
  • [2026-09-03 11:32:30.542][readsb] rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 00001000)
  • [2026-09-03 11:32:30.571][readsb] BeastReduce TCP output: Connection established: adsb.dataero.eu (3.78.171.9) port 30005
  • [2026-09-03 11:32:30.571][readsb] BeastReduce TCP output: Connection established: data.avdelphi.com (140.238.220.39) port 24999
  • [2026-09-03 11:32:30.571][readsb] BeastReduce TCP output: Connection established: dati.flyitalyadsb.com (172.65.213.103) port 4905
  • [2026-09-03 11:32:30.571][readsb] BeastReduce TCP output: Connection established: feed.adsb.fi (65.109.2.208) port 30004
  • [2026-09-03 11:32:30.572][readsb] BeastReduce TCP output: Connection established: feed.adsb.lol (89.58.11.153) port 30004
  • [2026-09-03 11:32:30.573][readsb] BeastReduce TCP output: Connection established: feed.airplanes.live (78.46.234.18) port 30004
  • [2026-09-03 11:32:30.575][readsb] BeastReduce TCP output: Connection established: feed.flyoverhead.com (168.220.91.222) port 30004
  • [2026-09-03 11:32:30.576][readsb] BeastReduce TCP output: Connection established: feed.planespotters.net (116.202.102.108) port 30004
  • [2026-09-03 11:32:30.653][readsb] BeastReduce TCP output: Connection established: feed.tryflightdeck.com (45.55.171.19) port 30004
  • [2026-09-03 11:32:30.657][readsb] BeastReduce TCP output: Connection established: feed.adsbiq.com (44.193.85.251) port 30004
  • [2026-09-03 11:32:30.729][readsb] BeastReduce TCP output: Connection established: feed1.adsbexchange.com (44.249.176.157) port 30004
  • [2026-09-03 11:32:30.730][readsb] BeastReduce TCP output: Connection established: feed.flyrealtraffic.com (52.42.87.42) port 30004
  • [2026-09-03 11:32:30.809][readsb] BeastReduce TCP output: Connection established: skyfeed.hpradar.com (27.66.248.42) port 30004
  • [2026-09-03 11:32:30.810][readsb] BeastReduce TCP output: Connection established: feed.theairtraffic.com (23.155.40.90) port 30004
  • [2026-09-03 11:32:30.843][readsb] Found Rafael Micro R820T tuner
  • [2026-09-03 11:32:31.120][tar1090] Found aircraft.json in /run/readsb, continuing operation as per usual!
  • [2026-09-03 11:32:33.369][readsb] Database update in progress!
  • [2026-09-03 11:32:34.155][readsb] Database update first part took 2.095 seconds!
  • [2026-09-03 11:32:34.160][readsb] Database update done! (critical part took 0.008 seconds)
  • [2026-09-03 11:32:36.412][readsb] BeastReduce TCP output: Remote server disconnected: data.avdelphi.com port 24999 (fd 36, SendQ 0, RecvQ 0)
  • [2026-09-03 11:32:36.519][readsb] BeastReduce TCP output: Connection established: data.avdelphi.com (140.238.220.39) port 24999
  • [2026-09-03 11:32:42.527][readsb] BeastReduce TCP output: dati.flyitalyadsb.com port 4905: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:32:44.165][readsb] BeastReduce TCP output: Remote server disconnected: data.avdelphi.com port 24999 (fd 36, SendQ 0, RecvQ 0)
  • [2026-09-03 11:32:44.247][readsb] BeastReduce TCP output: Connection established: data.avdelphi.com (140.238.220.39) port 24999
  • [2026-09-03 11:34:10.769][readsb] rtlsdr_demod_write_reg failed with -1
  • [2026-09-03 11:34:11.295][readsb] SDR ppm out of specification (could cause MLAT issues) or local clock jumped / not syncing with ntp or chrony! ppm: -759
  • [2026-09-03 11:35:08.425][readsb] BeastReduce TCP output: feed.flyoverhead.com port 30004: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:35:10.279][readsb] BeastReduce TCP output: feed.adsb.lol port 30004: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:35:10.416][readsb] BeastReduce TCP output: feed1.adsbexchange.com port 30004: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:35:10.443][readsb] BeastReduce TCP output: feed.airplanes.live port 30004: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:35:10.496][readsb] BeastReduce TCP output: feed.adsb.fi port 30004: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:35:12.023][readsb] BeastReduce TCP output: skyfeed.hpradar.com port 30004: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:35:12.023][readsb] BeastReduce TCP output: feed.tryflightdeck.com port 30004: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:35:12.082][readsb] BeastReduce TCP output: feed.flyrealtraffic.com port 30004: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:35:12.142][readsb] BeastReduce TCP output: feed.planespotters.net port 30004: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:35:13.609][readsb] BeastReduce TCP output: data.avdelphi.com port 24999: Bad connection, dropping data (connection lost 0.0% of data) (suppress msg for 300 s)
  • [2026-09-03 11:42:42.042][readsb] BeastReduce TCP output: Remote server disconnected: data.avdelphi.com port 24999 (fd 36, SendQ 0, RecvQ 0)
  • [2026-09-03 11:42:42.070][readsb] Beast TCP output: Send Error: Broken pipe: ::1 port 36192 (fd 126, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.070][readsb] Beast TCP output: Send Error: Broken pipe: ::1 port 36176 (fd 125, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.071][readsb] Beast TCP output: Send Error: Broken pipe: ::1 port 36162 (fd 124, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.071][readsb] Beast TCP output: Send Error: Broken pipe: ::1 port 36146 (fd 123, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.071][readsb] Beast TCP output: Send Error: Broken pipe: ::1 port 36138 (fd 72, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.071][readsb] Beast TCP output: Send Error: Broken pipe: ::1 port 36130 (fd 71, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.071][readsb] Beast TCP output: Send Error: Broken pipe: ::1 port 36126 (fd 55, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.071][readsb] Beast TCP output: Send Error: Broken pipe: ::1 port 36114 (fd 36, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.071][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 41646 (fd 121, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.072][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 45910 (fd 118, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.072][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 47952 (fd 117, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.072][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 39378 (fd 116, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.072][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 53004 (fd 115, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.072][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 59278 (fd 114, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.074][mlat-client][feed.theairtraffic.com] Detected BEAST format input
    [2026-09-03 11:42:42.074][mlat-client][feed.theairtraffic.com] Input format changed to BEAST, 12MHz clock
    [2026-09-03 11:42:42.075][mlat-client][feed.adsbiq.com] Detected BEAST format input
    [2026-09-03 11:42:42.075][mlat-client][feed.adsbiq.com] Input format changed to BEAST, 12MHz clock
    [2026-09-03 11:42:42.076][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 60226 (fd 113, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 40378 (fd 110, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 42920 (fd 108, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 60150 (fd 107, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 33162 (fd 106, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 48256 (fd 105, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 50200 (fd 104, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.6 port 58334 (fd 103, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.9 port 50022 (fd 102, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 51340 (fd 101, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 48570 (fd 100, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 57328 (fd 99, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 49430 (fd 98, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 50936 (fd 97, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 58912 (fd 96, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 60164 (fd 95, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 60754 (fd 94, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 46984 (fd 93, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.10 port 43538 (fd 92, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.12 port 41442 (fd 91, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.9 port 52444 (fd 90, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 43504 (fd 89, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 39396 (fd 88, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 47886 (fd 87, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.6 port 36584 (fd 86, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.9 port 52574 (fd 85, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 51006 (fd 84, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 52736 (fd 83, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 35688 (fd 82, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 41468 (fd 81, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 40476 (fd 80, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 36138 (fd 79, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 33564 (fd 78, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 53308 (fd 77, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 38994 (fd 76, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 57510 (fd 75, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 58864 (fd 74, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.077][readsb] Beast TCP output: Send Error: Broken pipe: 172.18.0.4 port 50602 (fd 63, SendQ 11, RecvQ 0)
    [2026-09-03 11:42:42.080][mlat-client][feed.adsbexchange.com] Detected BEAST format input
    [2026-09-03 11:42:42.080][mlat-client][feed.adsbexchange.com] Input format changed to BEAST, 12MHz clock
    [2026-09-03 11:42:42.082][readsb] <3>High load: modesNetPeriodicWork() elapsed1/2/3/interval 49/0/15/390237 ms, suppressing for 5 seconds!
    [2026-09-03 11:42:42.082][mlat-client][feed.adsb.lol] Detected BEAST format input
    [2026-09-03 11:42:42.082][mlat-client][feed.adsb.lol] Input format changed to BEAST, 12MHz clock
    [2026-09-03 11:42:42.082][mlat-client][skyfeed.hpradar.com] Detected BEAST format input
    [2026-09-03 11:42:42.083][mlat-client][skyfeed.hpradar.com] Input format changed to BEAST, 12MHz clock
  • [2026-09-03 11:42:42.179][readsb] BeastReduce TCP output: Connection established: data.avdelphi.com (140.238.220.39) port 24999
  • [2026-09-03 11:42:49.939][readsb] <3>SDR wedged, exiting! (check power supply / avoid using an USB extension / SDR might be defective)
  • [2026-09-03 11:42:50.881][readsb] rtlsdr_demod_write_reg failed with -4
  • [2026-09-03 11:42:50.881][readsb] rtlsdr_demod_read_reg failed with -4
  • [2026-09-03 11:42:50.881][readsb] r82xx_write: i2c wr failed=-4 reg=06 len=1
  • [2026-09-03 11:42:50.881][readsb] rtlsdr_write_reg failed with -4
  • [2026-09-03 11:42:50.885][readsb] saving state …
  • [2026-09-03 11:42:56.081][readsb] … done, saved 452 aircraft in 5.193 seconds!
  • [2026-09-03 11:42:56.081][readsb] [2026-09-03 11:42:56.078 BST] Abnormal exit. uptime: 0d 0h 10m 25.768s
  • [2026-09-03 11:42:57.486][readsb] delaying restart by 15 seconds
  • [2026-09-03 11:43:06.723][tar1090] No aircraft.json found in /run/readsb during the last 30 seconds! Try restarting dump1090 or reinstalling tar1090 if you switched dump1090 to readsb!
  • [2026-09-03 11:43:12.514][readsb] invoked by: /usr/local/bin/readsb --net --quiet --lat 52.757991 --lon -2.55661 --uuid-file=/run/uuid --write-json=/run/readsb --write-state=/var/globe_history --json-reliable=1 --net-json-port=30047 --net-ri-port=30001 --net-ro-port=30002 --net-sbs-port=30003 --net-sbs-in-port=32006 --net-sbs-jaero-in-port=32009 --jaero-timeout=37 --net-bi-port=30004,30104 --net-bo-port=30005 --net-beast-reduce-out-port=30006 --net-api-port=30152 --heatmap-dir=/var/globe_history --heatmap=15 --net-sbs-reduce --json-location-accuracy=2 --write-state-only-on-exit --max-range=300 --stats-range --net-beast-reduce-interval=0.5 --json-trace-interval=15 --net-connector=adsb.dataero.eu,30005,beast_reduce_plus_out,uuid=ad529f9f-14ab-4ed7-9edf-18c4904d4b5f --net-connector=data.avdelphi.com,24999,beast_reduce_plus_out,uuid=05d99a4e-5f74-4dc5-98c4-a200e4385af9 --net-connector=dati.flyitalyadsb.com,4905,beast_reduce_plus_out,uuid=959b2c77-210c-4720-b0a5-d5eb2afe6c17 --net-connector=feed.adsb.fi,30004,beast_reduce_plus_out,uuid=c9cdec8b-103a-4d7a-80da-6d7d579ea5c3 --net-connector=feed.adsb.lol,30004,beast_reduce_plus_out,uuid=20f37b70-e0c6-4e03-b08f-a318a0191f9a --net-connector=feed.adsbiq.com,30004,beast_reduce_plus_out,uuid=cc6540c8-455b-4315-9612-018998974d08 --net-connector=feed.airplanes.live,30004,beast_reduce_plus_out,uuid=4b8b58cb-58a9-4f7e-87c7-a190b81f3628 --net-connector=feed.flyoverhead.com,30004,beast_reduce_plus_out,uuid=fe28f81f-86f8-4a49-8178-058b32308279 --net-connector=feed.flyrealtraffic.com,30004,beast_reduce_plus_out,uuid=0187ecbc-f131-4672-8ad7-62f355a6e032 --net-connector=feed.planespotters.net,30004,beast_reduce_plus_out,uuid=9e8de0b0-b9a3-443c-8e06-63423b23f65e --net-connector=feed.theairtraffic.com,30004,beast_reduce_plus_out,uuid=223afaae-beab-4777-985c-d3a90118e18b --net-connector=feed.tryflightdeck.com,30004,beast_reduce_plus_out,uuid=6f5d45b1-16ab-44c0-972b-c877b9d1f411 --net-connector=feed1.adsbexchange.com,30004,beast_reduce_plus_out,uuid=eb9d1f25-e5b2-49de-8db6-860d7bc2bed0 --net-connector=skyfeed.hpradar.com,30004,beast_reduce_plus_out,uuid=b8ec93e8-bb0d-4d90-9f02-9237e6aee31e --net-heartbeat=35 --net-ro-interval-beast-reduce=0.12 --db-file=/usr/local/share/tar1090/aircraft.csv.gz --db-file-lt --device-type=rtlsdr --gain=autogain --device=00001000
  • [2026-09-03 11:43:12.514][readsb] [2026-09-03 11:43:12.514 BST] readsb starting up.
  • [2026-09-03 11:43:12.514][readsb] readsb version: 3.16.15 wiedehopf git: b499ecb (committed: Wed May 13 18:11:18 2026 0000)
  • [2026-09-03 11:43:12.514][readsb] autogain enabled, silent mode, suppressing gain changing messages
  • [2026-09-03 11:43:12.514][readsb] lowestGain: 0.0 noiseLowThreshold: 34 noiseHighThreshold: 36 loudThreshold: 243
  • [2026-09-03 11:43:12.516][readsb] Using lat: 52.757991, lon: -2.556610 (location accuracy: exact)
  • [2026-09-03 11:43:12.518][readsb] loading state …
  • [2026-09-03 11:43:12.637][readsb] actual range outline, read bytes: 368644
  • [2026-09-03 11:43:12.642][readsb] … done, loaded 452 aircraft in 0.124 seconds!
  • [2026-09-03 11:43:12.642][readsb] aircraft table fill: 0.0
  • [2026-09-03 11:43:12.644][readsb] 30002: Raw TCP output port
  • [2026-09-03 11:43:12.646][readsb] 30152: API output port
  • [2026-09-03 11:43:12.652][readsb] 30005: Beast TCP output port
  • [2026-09-03 11:43:12.657][readsb] 30006: BeastReduce TCP output port
  • [2026-09-03 11:43:12.659][readsb] 30047: Position json output port
  • [2026-09-03 11:43:12.661][readsb] 30003: SBS TCP output ALL port
  • [2026-09-03 11:43:12.663][readsb] 32006: SBS TCP input MAIN port
  • [2026-09-03 11:43:12.667][readsb] 32009: SBS TCP input JAERO port
  • [2026-09-03 11:43:12.671][readsb] 32007: SBS TCP input MLAT port
  • [2026-09-03 11:43:12.673][readsb] 32008: SBS TCP input PRIO port
  • [2026-09-03 11:43:12.675][readsb] 30001: Raw TCP input port
  • [2026-09-03 11:43:12.677][readsb] 30004: Beast TCP input port
  • [2026-09-03 11:43:12.678][readsb] 30104: Beast TCP input port
  • [2026-09-03 11:43:12.815][readsb] rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 00001000)
  • [2026-09-03 11:43:12.815][tar1090] Found aircraft.json in /run/readsb, continuing operation as per usual!
  • [2026-09-03 11:43:12.839][readsb] BeastReduce TCP output: Connection established: adsb.dataero.eu (3.78.171.9) port 30005
  • [2026-09-03 11:43:12.842][readsb] BeastReduce TCP output: Connection established: data.avdelphi.com (140.238.220.39) port 24999
  • [2026-09-03 11:43:12.843][readsb] BeastReduce TCP output: Connection established: dati.flyitalyadsb.com (172.65.213.103) port 4905
  • [2026-09-03 11:43:12.848][readsb] BeastReduce TCP output: Connection established: feed.adsb.fi (65.109.2.208) port 30004
  • [2026-09-03 11:43:12.848][readsb] BeastReduce TCP output: Connection established: feed.adsb.lol (89.58.11.153) port 30004
  • [2026-09-03 11:43:12.848][readsb] BeastReduce TCP output: Connection established: feed.airplanes.live (78.46.234.18) port 30004
  • [2026-09-03 11:43:12.848][readsb] BeastReduce TCP output: Connection established: feed.flyoverhead.com (168.220.91.222) port 30004
  • [2026-09-03 11:43:12.848][readsb] BeastReduce TCP output: Connection established: feed.planespotters.net (116.202.102.108) port 30004
  • [2026-09-03 11:43:12.920][readsb] BeastReduce TCP output: Connection established: feed.tryflightdeck.com (45.55.171.19) port 30004
  • [2026-09-03 11:43:12.922][readsb] BeastReduce TCP output: Connection established: feed.adsbiq.com (44.193.85.251) port 30004
  • [2026-09-03 11:43:12.924][readsb] BeastReduce TCP output: Connection established: feed.theairtraffic.com (23.155.40.90) port 30004
  • [2026-09-03 11:43:13.000][readsb] BeastReduce TCP output: Connection established: feed.flyrealtraffic.com (52.42.87.42) port 30004
  • [2026-09-03 11:43:13.005][readsb] BeastReduce TCP output: Connection established: feed1.adsbexchange.com (44.249.176.157) port 30004
  • [2026-09-03 11:43:13.007][readsb] BeastReduce TCP output: Connection established: skyfeed.hpradar.com (27.66.248.42) port 30004
  • [2026-09-03 11:43:13.120][readsb] Found Rafael Micro R820T tuner
  • [2026-09-03 11:43:14.348][readsb] Database update in progress!
  • [2026-09-03 11:43:15.087][readsb] Database update first part took 1.969 seconds!
  • [2026-09-03 11:43:15.091][readsb] Database update done! (critical part took 0.002 seconds)
  • [2026-09-03 11:44:15.780][readsb] cb transfer status: 1, canceling…
  • [2026-09-03 11:44:15.780][readsb] FATAL: rtlsdr_read_async returned unexpectedly, probably lost the USB device, bailing out
    [2026-09-03 11:44:15.787][readsb] saving state …
  • [2026-09-03 11:44:31.390][readsb] … done, saved 506 aircraft in 15.602 seconds!
  • [2026-09-03 11:44:31.390][readsb] [2026-09-03 11:44:31.390 BST] Abnormal exit. uptime: 0d 0h 1m 18.878s
  • [2026-09-03 11:44:32.778][readsb] delaying restart by 15 seconds
Even says in plain English, SDR is bad :slight_smile:
(or not getting enough voltage … for example due to an usb extension)
very rarely simply replugging it will fix.
this was a pi4?
It’s an Rpi 3 and the FlightAware dongle is connected directly to it and not through a USB extension
Many thanks for your assistance I will get a new dongle ordered
