How could I access older logs? Ooops, I see /var/log is on tmpfs. So, ultrafeeder dropped it on restarting the container
we only have today 09:11 o’clock.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service libseccomp2: starting
s6-rc: info: service 09-rtlsdr-biastee: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service libseccomp2 successfully started
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service startup: starting
[2025-01-26 09:11:45.831][09-rtlsdr-biastee-init] Device type is rtlsdr, checking for bias tee...
[2025-01-26 09:11:45.838][09-rtlsdr-biastee-init] READSB_ENABLE_BIASTEE is not set to either ON or OFF, skipping...
s6-rc: info: service 09-rtlsdr-biastee successfully started
[2025-01-26 09:11:45.911][01-print-container-version] [2025-01-26 09:11:45.911][01-print-container-version] Container Version: 20250108-124855_ab87f52_main, build date 2025-01-08 13:48:55 +0100
[2025-01-26 09:11:46.124][06-range-outline] Using cached HeyWhatsThat Range Outlines for these altitudes (in meters): 499,2999,9999,19998,29998
s6-rc: info: service startup successfully started
s6-rc: info: service timelapse1090: starting
s6-rc: info: service telegraf: starting
s6-rc: info: service tar1090-update: starting
s6-rc: info: service readsb: starting
s6-rc: info: service nginx: starting
s6-rc: info: service mlathub: starting
s6-rc: info: service mlat-client: starting
s6-rc: info: service graphs1090-writeback: starting
s6-rc: info: service collectd: starting
s6-rc: info: service cleanup_globe_history: starting
s6-rc: info: service aggregator-urls: starting
s6-rc: info: service adsbx-stats: starting
s6-rc: info: service timelapse1090 successfully started
s6-rc: info: service telegraf successfully started
s6-rc: info: service tar1090-update successfully started
s6-rc: info: service readsb successfully started
s6-rc: info: service tar1090: starting
s6-rc: info: service autogain: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service mlathub successfully started
s6-rc: info: service mlat-client successfully started
s6-rc: info: service graphs1090-writeback successfully started
s6-rc: info: service collectd successfully started
s6-rc: info: service graphs1090: starting
s6-rc: info: service cleanup_globe_history successfully started
s6-rc: info: service aggregator-urls successfully started
s6-rc: info: service adsbx-stats successfully started
s6-rc: info: service tar1090 successfully started
s6-rc: info: service graphs1090 successfully started
s6-rc: info: service autogain successfully started
s6-rc: info: service legacy-services: starting
[2025-01-26 09:11:46.755][cleanup_globe_history] MAX_GLOBE_HISTORY not set - we will not expire any globe_history files
[2025-01-26 09:11:46.772][mlathub] No MLAT servers have been defined in MLAT_CONFIG and no external sources have been defined in MLATHUB_NET_CONNECTOR - no need to start MLATHUB
274 (process ID) old priority 0, new priority 5
s6-rc: info: service legacy-services successfully started
[2025-01-26 09:11:46.834][mlat-client] Started as an s6 service
[2025-01-26 09:11:46.841][adsbx-stats] AdsbExchange not configured - no stats package needed
[2025-01-26 09:11:46.901][mlat-client] Warning: MLAT_CONFIG not defined - MLAT will be disabled.
[2025-01-26 09:11:46.959][graphs1090] 458 (process ID) old priority 0, new priority 19
[2025-01-26 09:11:47.056][mlat-client] service stopping
[2025-01-26 09:11:47.090][readsb] invoked by: /usr/local/bin/readsb --net --quiet --lat 52.373577 --lon 9.915554 --uuid-file=/run/uuid --write-json=/run/readsb --write-state=/var/globe_history --json-trace-interval=15 --json-reliable=1 --net-json-port=30047 --net-ri-port=30001 --net-ro-port=30002 --net-sbs-port=30003 --net-sbs-in-port=32006 --net-bi-port=30004,30104 --net-bo-port=30005 --net-beast-reduce-out-port=30006 --net-api-port=30152 --heatmap-dir=/var/globe_history --heatmap=15 --net-sbs-reduce --json-location-accuracy=2 --stats-range --net-beast-reduce-interval=0.5 --net-connector=feed.adsb.fi,30004,beast_reduce_plus_out --net-heartbeat=35 --net-ro-interval-beast-reduce=0.12 --db-file=/var/globe_history/tar1090-update/aircraft.csv.gz --db-file-lt --device-type=rtlsdr --gain=5.9 --device=00000991 --ppm=33
[2025-01-26 09:11:47.090][readsb] [2025-01-26 09:11:47.090 CET] readsb starting up.
[2025-01-26 09:11:47.090][readsb] readsb version: 3.14.1645 wiedehopf git: 3efa2b1 (committed: Mon Jan 6 13:51:38 2025 0000)
[2025-01-26 09:11:47.090][readsb] Using lat: 52.373577, lon: 9.915554
[2025-01-26 09:11:47.097][readsb] loading state .....
[2025-01-26 09:11:47.137][readsb] actual range outline, read bytes: 368644
[2025-01-26 09:11:47.139][readsb] .......... done, loaded 4 aircraft in 0.041 seconds!
[2025-01-26 09:11:47.139][readsb] aircraft table fill: 0.0
[2025-01-26 09:11:47.151][readsb] 30152: API output port
[2025-01-26 09:11:47.152][readsb] 30002: Raw TCP output port
[2025-01-26 09:11:47.152][readsb] 30005: Beast TCP output port
[2025-01-26 09:11:47.153][readsb] 30006: BeastReduce TCP output port
[2025-01-26 09:11:47.160][readsb] 30047: Position json output port
[2025-01-26 09:11:47.162][readsb] 30003: SBS TCP output ALL port
[2025-01-26 09:11:47.162][readsb] 32006: SBS TCP input MAIN port
[2025-01-26 09:11:47.162][readsb] 32007: SBS TCP input MLAT port
[2025-01-26 09:11:47.162][readsb] 32008: SBS TCP input PRIO port
[2025-01-26 09:11:47.163][readsb] 32009: SBS TCP input JAERO port
[2025-01-26 09:11:47.163][readsb] 30001: Raw TCP input port
[2025-01-26 09:11:47.164][readsb] 30004: Beast TCP input port
[2025-01-26 09:11:47.165][readsb] 30104: Beast TCP input port
[2025-01-26 09:11:47.200][graphs1090] Generating all graphs
[2025-01-26 09:11:47.236][readsb] rtlsdr: using device #0: Dexatek DK DVB-T Dongle (Logilink VG0002A) (Realtek, DVB-T Dongle, SN 00000991)
[2025-01-26 09:11:47.308][readsb] Detached kernel driver
[2025-01-26 09:11:47.327][readsb] BeastReduce TCP output: Connection established: feed.adsb.fi (65.109.2.208) port 30004
[2025-01-26 09:11:47.557][readsb] Found Fitipower FC0013 tuner
[2025-01-26 09:11:47.623][readsb] rtlsdr: tuner gain set to 5.8 dB
[2025-01-26 09:11:48.605][readsb] Database update in progress!
[2025-01-26 09:11:48.981][readsb] Database update first part took 1.241 seconds!
[2025-01-26 09:11:48.982][readsb] Database update done! (critical part took 0.000 seconds)
[2025-01-26 09:11:51.606][tar1090-update] tar1090 version: 3.14.1702 tar1090-db version: 3.14.1634
[2025-01-26 09:11:51.745][tar1090-update] Using cached HeyWhatsThat Range Outlines for these altitudes (in meters): 499,2999,9999,19998,29998
[2025-01-26 09:11:51.842][tar1090] 1139 (process ID) old priority 0, new priority 19
[2025-01-26 09:11:56.053][collectd] [2025-01-26 09:11:56] plugin_load: plugin "logfile" successfully loaded.
[2025-01-26 09:12:47.245][graphs1090] Done with initial graph generation
[2025-01-26 09:12:03.696][telegraf] 2025-01-26T08:12:03Z I! Loading config: /etc/telegraf/telegraf.d/output.conf
[2025-01-26 09:12:03.703][telegraf] 2025-01-26T08:12:03Z I! Loading config: /etc/telegraf/telegraf.d/readsb_aircraft_json.conf
[2025-01-26 09:12:03.706][telegraf] 2025-01-26T08:12:03Z I! Loading config: /etc/telegraf/telegraf.d/readsb_receiver_json.conf
[2025-01-26 09:12:03.709][telegraf] 2025-01-26T08:12:03Z I! Loading config: /etc/telegraf/telegraf.d/readsb_stats_json.conf
[2025-01-26 09:12:03.712][telegraf] 2025-01-26T08:12:03Z I! Starting Telegraf 1.26.3
[2025-01-26 09:12:03.712][telegraf] 2025-01-26T08:12:03Z I! Available plugins: 235 inputs, 9 aggregators, 27 processors, 22 parsers, 57 outputs, 2 secret-stores
[2025-01-26 09:12:03.712][telegraf] 2025-01-26T08:12:03Z I! Loaded inputs: file (3x)
[2025-01-26 09:12:03.712][telegraf] 2025-01-26T08:12:03Z I! Loaded aggregators:
[2025-01-26 09:12:03.712][telegraf] 2025-01-26T08:12:03Z I! Loaded processors: converter strings
[2025-01-26 09:12:03.712][telegraf] 2025-01-26T08:12:03Z I! Loaded secretstores:
[2025-01-26 09:12:03.712][telegraf] 2025-01-26T08:12:03Z I! Loaded outputs: influxdb_v2
[2025-01-26 09:12:03.712][telegraf] 2025-01-26T08:12:03Z I! Tags enabled: host=ultrafeeder
[2025-01-26 09:12:03.712][telegraf] 2025-01-26T08:12:03Z I! [agent] Config: Interval:10s, Quiet:false, Hostname:"ultrafeeder", Flush Interval:10s
# ... from here, the following is repeating thousands times, because of a failure in telegraph's certificate store setup:
# this hat nothing to do with the signal problem. Telegraph is using an outdated certificate, somehow.
# When I open https://planes.##redacted##.kg in Firefox and download the certificate, is is indeed for the right A record and with no CNAME.
[2025-01-26 09:12:14.283][telegraf] 2025-01-26T08:12:14Z E! [outputs.influxdb_v2] When writing to [https://planes.##redacted##.kg:46086]: Post "https://planes.##redacted##.kg:46086/api/v2/write?bucket=ads-b&org=Laerm": tls: failed to verify certificate: x509: certificate is valid for megaleise.##redacted##.com, influx.megaleise.##redacted##.com, not planes.##redacted##.kg
[2025-01-26 09:12:14.283][telegraf] 2025-01-26T08:12:14Z E! [agent] Error writing to outputs.influxdb_v2: failed to send metrics to any configured server(s)
[2025-01-26 09:12:23.858][telegraf] 2025-01-26T08:12:23Z E! [outputs.influxdb_v2] When writing to [https://planes.##redacted##.kg:46086]: Post "https://planes.##redacted##.kg:46086/api/v2/write?bucket=ads-b&org=Laerm": tls: failed to verify certificate: x509: certificate is valid for megaleise.##redacted##.com, influx.megaleise.##redacted##.com, not planes.##redacted##.kg
[2025-01-26 09:12:23.858][telegraf] 2025-01-26T08:12:23Z E! [agent] Error writing to outputs.influxdb_v2: failed to send metrics to any configured server(s)
(sorry for redacting the DNS names, my security setup is not done so far, it is planned for this night)
I also wondering a little about log entry
because this setting:
fluglotse@flightradar:/opt/adsb $ grep ADSB .env
ADSB_SDR_SERIAL=00000991
ADSB_SDR_PPM=33
#ADSB_SDR_GAIN=autogain
ADSB_SDR_GAIN=5.9
