ADS-B Receiver Project Setup Scripts
It is hard for me to troubleshoot or test dump978 due to the fact I do not have an antenna up in the air receiving much as far as UAT data is concerned. That and the fact I did not write it and have very little experience actually running it besides as an after thought in the background collecting no data makes it hard for me to support dump978 on an application level. However it is my understanding uat2esnt is used to convert UAT messages to Mode S messages. These messages are then in turn sent to dump1090 via port 30001 which listen for AVR format input using Netcat. That being said there are a couple things you can check.
Lets make sure it’s not a configuration issue.
First off as mentioned earlier confirm the file /var/log/dump978.log exists and check there are no errors reported there.
Confirm the uat2esnt process is running and a Netcat process which looks like ā€œ/bin/nc -q1 127.0.0.1 30001ā€ is running. (ā€œps -aux | grep uat2esntā€ and ā€œps -aux | grep ncā€)
Make sure the setting RAW_INPUT_PORT located in the file /etc/default/dump1090-mutability is set to 30001.
You might want to make sure you did not assign port 30001 to another application such as PiAware as well which will cause dump1090 to be unable to use port 30001.
You could also comment out the line in /etc/rc.local that executes the file dump978-maint.sh then reboot so dump978 is not running and manually startup dump978 using the directions Obj has made available in the dump978 GitHub repository located at github.com/mutability/dump978 to see if any more information can been seen regarding a possible issue. (BTW be sure to add -d <YOUR_RTL-SDR_DEVICE_ID> to the line used to execute dump978 if you are using two dongles.)
Any information or errors would be helpful. If you see any errors reported in the dump978 log or even syslog would be helpful. It’s hard to blindly troubleshoot an issue hence the reason I am offering some basics to go over first. Let me know how it goes and if you find anything.
Thanks, I’m working on it.
  1. The file /var/log/dump978.log does exists and there are no errors reported there, just the usual data strings.
  2. ps -aux | grep uat2esnt shows:
    root 505 0.0 0.0 2324 396 ? S Feb02 0:00 /home/pi/adsb-feeder/build/dump978/uat2esnt
    pi 14684 0.0 0.2 4280 1944 pts/0 S+ 22:40 0:00 grep --color=auto uat2esnt
  3. ps -aux | grep nc Shows:
    dump1090 383 22.2 1.3 31404 12524 ? S<l Feb02 691:03 /usr/bin/dump1090-mutability --measure-noise --net --gain -10 --ppm 92 --oversample --fix --phase-enhance --lat xx.xxxx --lon -xx.xxxx --max-range 350 --net-http-port 0 --net-ri-port 30001 --net-ro-port 30002 --net-bi-port 30104 --net-bo-port 30005 --net-sbs-port 30003 --net-heartbeat 60 --net-ro-size 500 --net-ro-interval 1 --net-buffer 2 --net-bind-address 127.0.0.1 --stats-every 3600 --write-json /run/dump1090-mutability --write-json-every 1 --json-location-accuracy 1 --quiet
    root 506 0.0 0.1 2464 1428 ? S Feb02 0:00 /bin/nc -q1 127.0.0.1 30001
    pi 660 0.0 0.0 3696 220 ? Ss Feb02 0:01 /usr/bin/ssh-agent /usr/bin/dbus-launch --exit-with-session x-session-manager
    pi 663 0.0 0.1 3692 1632 ? S Feb02 0:00 /usr/bin/dbus-launch --exit-with-session x-session-manager
    pi 14694 0.0 0.2 4280 1956 pts/0 S+ 22:41 0:00 grep --color=auto nc
    (xxxxxxx’s were mine)
  4. RAW_INPUT_PORT located in the file /etc/default/dump1090-mutability is set to 30001.
  5. I did not assign port 30001 to another application. All ports are set to the defaults in your script.
  6. Started it manually according to Obj’s GitHub repository and all appeared normal, although I didn’t have any 978 traffic in the area at the time.
    See:
    sudo rtl_sdr -d1 -f 978000000 -s 2083334 -g 48 - | ./dump978 | ./uat2esnt | nc -q1 localhost 30001
    Found 2 device(s):
    0: Realtek, RTL2838UHIDIR, SN: 00000001
    1: Realtek, RTL2838UHIDIR, SN: 00000002
Using device 1: Generic RTL2832U OEM
Exact sample rate is: 2083334.141630 Hz
Sampling at 2083334 S/s.
Tuned to 978000000 Hz.
Tuner gain set to 48.00 dB.
Reading samples in async mode…
I don’t see anything obvious in /var/log/messages although I’m not sure what I looking for. I can’t understand why it would work fine at first after installation and then just quit forwarding to dump1090 while still showing traffic on the 978 map. Also can’t believe I’m the only one with this problem. Maybe that would partially explain the lack of 978 traffic! Most people don’t sit around staring at their 978 map waiting for traffic.
Where else can I look for errors? Thank you so much for taking time to try and help me!
Here’s the output from the above command:
2861 (process ID) old priority 0, new priority 5
ERROR: opening ā€˜/var/lib/collectd/rrd/localhost/dump1090-localhost/dump1090_aircraft-recent.rrd’: No such file or directory
ERROR: opening ā€˜/var/lib/collectd/rrd/localhost/dump1090-localhost/dump1090_cpu-demod.rrd’: No such file or directory
ERROR: opening ā€˜/var/lib/collectd/rrd/localhost/dump1090-localhost/dump1090_tracks-all.rrd’: No such file or directory
1107x284
577x298
577x298
577x298
577x298
577x298
577x298
577x298
577x298
ERROR: opening ā€˜/var/lib/collectd/rrd/localhost/dump1090-localhost/dump1090_messages-local_accepted.rrd’: No such file or directory
ERROR: opening ā€˜/var/lib/collectd/rrd/localhost/dump1090-localhost/dump1090_range-max_range.rrd’: No such file or directory
ERROR: opening ā€˜/var/lib/collectd/rrd/localhost/dump1090-localhost/dump1090_dbfs-signal.rrd’: No such file or directory
Much of it related to collectd:
Feb 4 06:30:01 amelia1 CRON[14962]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 4 06:30:01 amelia1 CRON[14963]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 4 06:30:05 amelia1 CRON[14949]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:30:05 amelia1 CRON[14948]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:32:01 amelia1 CRON[15055]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 4 06:32:04 amelia1 CRON[15048]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:35:01 amelia1 CRON[15117]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 4 06:35:05 amelia1 CRON[15110]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:39:01 amelia1 CRON[15182]: (root) CMD ( -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean)
Feb 4 06:40:01 amelia1 CRON[15225]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 4 06:40:01 amelia1 CRON[15226]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 4 06:40:04 amelia1 CRON[15212]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:40:05 amelia1 CRON[15211]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:42:01 amelia1 CRON[15317]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 4 06:42:04 amelia1 CRON[15310]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:44:01 amelia1 CRON[15375]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 4 06:44:05 amelia1 CRON[15368]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:45:01 amelia1 CRON[15425]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 4 06:45:04 amelia1 CRON[15418]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:50:01 amelia1 CRON[15501]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 4 06:50:01 amelia1 CRON[15502]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 4 06:50:05 amelia1 CRON[15488]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:50:05 amelia1 CRON[15487]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:52:01 amelia1 CRON[15592]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 4 06:52:04 amelia1 CRON[15585]: (CRON) info (No MTA installed, discarding output)
Feb 4 06:55:01 amelia1 CRON[15655]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 4 06:55:05 amelia1 CRON[15648]: (CRON) info (No MTA installed, discarding output)
Feb 4 07:00:01 amelia1 CRON[15730]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 4 07:00:01 amelia1 CRON[15731]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 4 07:00:04 amelia1 CRON[15717]: (CRON) info (No MTA installed, discarding output)
Feb 4 07:00:04 amelia1 CRON[15716]: (CRON) info (No MTA installed, discarding output)
Feb 4 07:02:01 amelia1 CRON[15822]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 4 07:02:05 amelia1 CRON[15815]: (CRON) info (No MTA installed, discarding output)
Feb 4 07:03:16 amelia1 wpa_supplicant[654]: wlan0: WPA: Group rekeying completed with 98:fc:11:74:27:12 [GTK=CCMP]
Feb 4 07:04:01 amelia1 CRON[15880]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 4 07:04:04 amelia1 CRON[15873]: (CRON) info (No MTA installed, discarding output)
Feb 4 07:05:01 amelia1 CRON[15930]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 4 07:05:05 amelia1 CRON[15923]: (CRON) info (No MTA installed, discarding output)
Thanks.
To me this looks like the dump1090-related rrd files are not created (or not created in the expected locations). rdd files contain the actual performance data that collectd creates. So it looks like something between dump1090-mutability and collectd is not working as it should.
Can you try once more:
cd ~/adsb-feeder
git fetch --all
git reset --hard origin/master
./install.sh
And select to re-install dump1090-mutability and the portal?
Thanks for your help here. I reinstalled dump1090-mutability and the web portal; however, the 404 errors persist.
The problem appears to be with the creation of the rrd files (a function of dump1090-mutability and/or collectd; I don’t know exactly how it works). Do you have anything here?
Without the rrd files, it is impossible to create graphs.
I ran into the same problem: github.com/jprochazka/adsb-feeder/issues/77 - fixed by installing the libpython2.7 dependency
Another possibility is that
/etc/collectd/collectd.conf
somehow does not have all required entries. Can you post it here so that we can compare with known good versions?
@thomsmith
Everything looked good from what I can tell the uat2esnt process is running and netcat is running feeding to 127.0.0.1 30001…
Let it run for a few using the command you used from Obj’s dump978 repository. Report back if using the commands found there display any data in dump1090.
(Basically why I am having you run them is to see if the logging is causing an issue.)
@schueler412
Honestly the error looks a lot like what ewansteel ran into. I would check that the libpython2.7 package is installed. It would appear some distro’s might not have this package made available by default especially those made to be ā€œLiteā€ except for Raspbian Jessie Lite from the RPi site which does contain this package by default. If that don’t work if you could post the contents of /etc/collectd/collectd.conf that may help.
sudo apt-get install libpython2.7
(BTW: The libpython2.7 package is now required and being checked for and installed if missing by the scripts.)
The /var/lib/collectd/rrd/localhost/dump1090-localhost/ directory doesn’t exist. /var/lib/collectd/rrd/localhost/ does, but the ā€œdump1090-localhostā€ subdirectory isn’t there.
I ran the install command below and found that the libpython2.7 package was already installed (the image that I initially installed was Jessie (not lite) from the RPi site).
Here’s /etc/collectd/collectd.conf:
Config file for collectd(1).
Global
Hostname ā€œlocalhostā€
Added types for dump1090.
Make sure the path to dump1090.db is correct.
TypesDB ā€œ/home/pi/adsb-feeder/build/portal/graphs/dump1090.dbā€ ā€œ/usr/share/collectd/types.dbā€
Interval at which to query values. This may be overwritten on a per-plugin
base by using the ā€˜Interval’ option of the LoadPlugin block:
Interval 60
Interval 60
Timeout 2
ReadThreads 5
WriteThreads 1
Logging
LoadPlugin syslog
LogLevel info
LoadPlugin section
Specify what features to activate.
LoadPlugin rrdtool
LoadPlugin table
LoadPlugin interface
LoadPlugin memory
LoadPlugin cpu
LoadPlugin aggregation
LoadPlugin match_regex
LoadPlugin df
LoadPlugin disk
Globals true
Plugin configuration
DataDir ā€œ/var/lib/collectd/rrdā€
Configure the dump1090 python module.
Each Instance block collects statistics from a separate named dump1090.
The URL should be the base URL of the webmap, i.e. in the examples below,
statistics will be loaded from localhost/dump1090/data/stats.json
ModulePath ā€œ/home/pi/adsb-feeder/build/portal/graphsā€
LogTraces true
Import ā€œdump1090ā€
URL ā€œhttp://localhost/dump1090ā€
Instance localhost Separator " " Type gauge InstancePrefix "cpu_temp" ValuesFrom 0
<Plugin ā€œinterfaceā€>
Interface ā€œeth0ā€
Interface ā€œwlan0ā€
<Plugin ā€œaggregationā€>
Plugin ā€œcpuā€
Type ā€œcpuā€
GroupBy ā€œHostā€
GroupBy ā€œTypeInstanceā€
CalculateAverage true
<Plugin ā€œdfā€>
MountPoint ā€œ/ā€
IgnoreSelected false
ReportReserved true
ReportInodes true
<Plugin ā€œdiskā€>
Disk ā€œmmcblk0ā€
<Chain ā€œPostCacheā€>
Plugin ā€œ^cpu$ā€
PluginInstance ā€œ[1]+$ā€
Target stop
Target ā€œwriteā€
Thanks again to you and everyone for the assistance.
  1. 0-9 ā†©ļøŽ
@chueler412
Have you modified the port for the graphs/dump1090 web site (i.e. are you using localhost:8080/dump1090)?
Check if you have:
ls -l /home/pi/adsb-feeder/build/portal/graphs/dump1090.db
Try to restart collectd service:
sudo service collectd restart
And check messages related to collectd and dump1090:
cat /var/log/syslog | grep collectd | grep dump1090
This may give us further clues what is going on.
I don’t think so. It’s port 8080 on the Pi’s IP address.
I do have it:
-rw-r–r-- 1 pi pi 268 Jan 31 20:38 /home/pi/adsb-feeder/build/portal/graphs/dump1090.db
Done with no errors reported.
collectd:
Feb 5 06:30:01 amelia1 CRON[23821]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 06:30:01 amelia1 CRON[23820]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 06:31:14 amelia1 collectd[729]: Exiting normally.
Feb 5 06:31:14 amelia1 collectd[729]: collectd: Stopping 5 read threads.
Feb 5 06:31:14 amelia1 collectd[729]: rrdtool plugin: Shutting down the queue thread.
Feb 5 06:31:14 amelia1 collectd[729]: collectd: Stopping 1 write threads.
Feb 5 06:31:14 amelia1 collectdmon[728]: Info: collectd terminated with exit status 0
Feb 5 06:31:14 amelia1 collectdmon[728]: Info: shutting down collectdmon
Feb 5 06:31:15 amelia1 collectd[24473]: Stopping statistics collection and monitoring daemon: collectd.
Feb 5 06:31:16 amelia1 collectd[24483]: Starting statistics collection and monitoring daemon: collectd.
Feb 5 06:31:16 amelia1 collectd[24491]: Initialization complete, entering read-loop.
Feb 5 06:31:16 amelia1 collectd[24491]: rrdtool plugin: Adjusting ā€œRandomTimeoutā€ to 0.000 seconds.
Feb 5 06:31:53 amelia1 collectd[514]: Starting statistics collection and monitoring daemon: collectd.
Feb 5 06:31:53 amelia1 collectd[664]: Initialization complete, entering read-loop.
Feb 5 06:31:53 amelia1 collectd[664]: rrdtool plugin: Adjusting ā€œRandomTimeoutā€ to 0.000 seconds.
Feb 5 06:32:01 amelia1 CRON[704]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 06:35:01 amelia1 CRON[1251]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 06:40:01 amelia1 CRON[1374]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 06:40:01 amelia1 CRON[1375]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 06:42:01 amelia1 CRON[1466]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 06:44:01 amelia1 CRON[1524]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 06:45:01 amelia1 CRON[1574]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 06:50:01 amelia1 CRON[1654]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 06:50:01 amelia1 CRON[1653]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 06:52:01 amelia1 CRON[1745]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 06:55:01 amelia1 CRON[1808]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:00:01 amelia1 CRON[1884]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 07:00:01 amelia1 CRON[1888]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:02:01 amelia1 CRON[1977]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 07:04:01 amelia1 CRON[2035]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 07:05:01 amelia1 CRON[2085]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:06:01 amelia1 CRON[2135]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 30d >/dev/null)
Feb 5 07:10:01 amelia1 CRON[2243]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:10:01 amelia1 CRON[2242]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 07:12:01 amelia1 CRON[2333]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 07:15:02 amelia1 CRON[2397]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:20:01 amelia1 CRON[2493]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 07:20:01 amelia1 CRON[2494]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:22:01 amelia1 CRON[2587]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 07:24:01 amelia1 CRON[2645]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 07:25:01 amelia1 CRON[2694]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:30:01 amelia1 CRON[2771]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:30:01 amelia1 CRON[2773]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 07:32:01 amelia1 CRON[2863]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 07:35:01 amelia1 CRON[2925]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:40:01 amelia1 CRON[3036]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:40:01 amelia1 CRON[3035]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 07:42:01 amelia1 CRON[3127]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 07:44:01 amelia1 CRON[3186]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 07:45:01 amelia1 CRON[3236]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:50:01 amelia1 CRON[3311]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 07:50:01 amelia1 CRON[3312]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 07:52:01 amelia1 CRON[3404]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 07:55:01 amelia1 CRON[3466]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:00:02 amelia1 CRON[3541]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 08:00:02 amelia1 CRON[3542]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:02:01 amelia1 CRON[3634]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 08:04:01 amelia1 CRON[3692]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 08:05:01 amelia1 CRON[3741]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:06:01 amelia1 CRON[3790]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 30d >/dev/null)
Feb 5 08:10:01 amelia1 CRON[3896]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:10:01 amelia1 CRON[3895]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 08:12:01 amelia1 CRON[3987]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 08:15:01 amelia1 CRON[4050]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:20:01 amelia1 CRON[4148]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 08:20:01 amelia1 CRON[4150]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:22:01 amelia1 CRON[4239]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 08:24:01 amelia1 CRON[4299]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 08:25:01 amelia1 CRON[4349]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:30:01 amelia1 CRON[4426]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 08:30:01 amelia1 CRON[4427]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:32:01 amelia1 CRON[4517]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 08:35:01 amelia1 CRON[4580]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:40:01 amelia1 CRON[4688]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 08:40:01 amelia1 CRON[4692]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:42:01 amelia1 CRON[4781]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 08:44:01 amelia1 CRON[4839]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 08:45:01 amelia1 CRON[4890]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:50:01 amelia1 CRON[4965]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 08:50:01 amelia1 CRON[4969]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 08:52:01 amelia1 CRON[5059]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 08:55:01 amelia1 CRON[5121]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:00:01 amelia1 CRON[5198]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 09:00:01 amelia1 CRON[5199]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:02:01 amelia1 CRON[5290]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 09:04:01 amelia1 CRON[5348]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 09:05:01 amelia1 CRON[5397]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:06:01 amelia1 CRON[5446]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 30d >/dev/null)
Feb 5 09:10:01 amelia1 CRON[5553]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:10:01 amelia1 CRON[5552]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 09:12:01 amelia1 CRON[5644]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 09:15:01 amelia1 CRON[5706]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:20:01 amelia1 CRON[5805]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:20:01 amelia1 CRON[5807]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 09:22:01 amelia1 CRON[5896]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 09:24:01 amelia1 CRON[5955]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 09:25:01 amelia1 CRON[6006]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:30:01 amelia1 CRON[6082]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:30:01 amelia1 CRON[6083]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 09:32:01 amelia1 CRON[6175]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 09:35:01 amelia1 CRON[6236]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:40:01 amelia1 CRON[6346]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:40:01 amelia1 CRON[6347]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 09:42:01 amelia1 CRON[6439]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 09:44:01 amelia1 CRON[6497]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 09:45:01 amelia1 CRON[6546]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:50:01 amelia1 CRON[6622]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 09:50:01 amelia1 CRON[6624]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 09:52:01 amelia1 CRON[6714]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 09:55:01 amelia1 CRON[6776]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:00:01 amelia1 CRON[6855]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 10:00:01 amelia1 CRON[6854]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:02:01 amelia1 CRON[6946]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 10:04:01 amelia1 CRON[7004]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 10:05:01 amelia1 CRON[7054]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:06:01 amelia1 CRON[7103]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 30d >/dev/null)
Feb 5 10:10:01 amelia1 CRON[7210]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:10:01 amelia1 CRON[7211]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 10:12:01 amelia1 CRON[7301]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 10:15:01 amelia1 CRON[7365]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:20:01 amelia1 CRON[7464]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 10:20:01 amelia1 CRON[7465]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:22:01 amelia1 CRON[7555]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 10:24:01 amelia1 CRON[7615]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 10:25:01 amelia1 CRON[7664]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:30:01 amelia1 CRON[7741]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 10:30:01 amelia1 CRON[7742]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:32:01 amelia1 CRON[7832]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 10:35:01 amelia1 CRON[7894]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:40:01 amelia1 CRON[8004]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:40:01 amelia1 CRON[8006]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 10:42:01 amelia1 CRON[8097]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 10:44:01 amelia1 CRON[8157]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 10:45:01 amelia1 CRON[8207]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:50:01 amelia1 CRON[8284]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 10:50:01 amelia1 CRON[8285]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 10:52:01 amelia1 CRON[8375]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 10:55:01 amelia1 CRON[8438]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:00:01 amelia1 CRON[8513]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:00:01 amelia1 CRON[8514]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 11:02:01 amelia1 CRON[8605]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 11:04:01 amelia1 CRON[8663]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 11:05:01 amelia1 CRON[8712]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:06:01 amelia1 CRON[8765]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 30d >/dev/null)
Feb 5 11:10:01 amelia1 CRON[8869]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:10:01 amelia1 CRON[8870]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 11:12:01 amelia1 CRON[8964]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 11:15:01 amelia1 CRON[9025]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:20:01 amelia1 CRON[9123]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 11:20:01 amelia1 CRON[9124]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:22:01 amelia1 CRON[9215]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 11:24:01 amelia1 CRON[9274]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 11:25:01 amelia1 CRON[9323]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:30:01 amelia1 CRON[9399]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 11:30:01 amelia1 CRON[9403]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:32:01 amelia1 CRON[9492]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 11:35:01 amelia1 CRON[9556]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:40:01 amelia1 CRON[9665]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 11:40:01 amelia1 CRON[9666]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:42:01 amelia1 CRON[9757]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 11:44:01 amelia1 CRON[9816]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 11:45:01 amelia1 CRON[9865]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:50:01 amelia1 CRON[9941]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 11:50:01 amelia1 CRON[9942]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 11:52:01 amelia1 CRON[10034]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 11:55:01 amelia1 CRON[10095]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:00:01 amelia1 CRON[10173]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:00:01 amelia1 CRON[10172]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 12:02:01 amelia1 CRON[10264]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 12:04:01 amelia1 CRON[10323]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 12:05:02 amelia1 CRON[10372]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:06:01 amelia1 CRON[10421]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 30d >/dev/null)
Feb 5 12:08:01 amelia1 CRON[10479]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 365d >/dev/null)
Feb 5 12:10:01 amelia1 CRON[10572]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:10:01 amelia1 CRON[10573]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 12:12:01 amelia1 CRON[10663]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 12:15:01 amelia1 CRON[10725]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:20:01 amelia1 CRON[10824]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 12:20:01 amelia1 CRON[10825]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:22:01 amelia1 CRON[10915]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 12:24:01 amelia1 CRON[10974]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 12:25:01 amelia1 CRON[11024]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:30:01 amelia1 CRON[11097]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:30:01 amelia1 CRON[11100]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 12:32:02 amelia1 CRON[11192]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 12:35:01 amelia1 CRON[11254]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:40:01 amelia1 CRON[11412]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:40:01 amelia1 CRON[11413]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 12:42:01 amelia1 CRON[11540]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 12:44:01 amelia1 CRON[11654]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 12:45:01 amelia1 CRON[11717]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:50:01 amelia1 CRON[11818]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 12:50:01 amelia1 CRON[11819]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 12:52:01 amelia1 CRON[11925]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 12:55:01 amelia1 CRON[11988]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:00:01 amelia1 CRON[12061]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:00:01 amelia1 CRON[12065]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 13:02:01 amelia1 CRON[12155]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 13:04:01 amelia1 CRON[12214]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 13:05:01 amelia1 CRON[12263]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:06:01 amelia1 CRON[12313]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 30d >/dev/null)
Feb 5 13:10:01 amelia1 CRON[12420]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 13:10:01 amelia1 CRON[12421]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:12:01 amelia1 CRON[12511]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 13:15:01 amelia1 CRON[12574]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:20:01 amelia1 CRON[12671]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 13:20:01 amelia1 CRON[12672]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:22:01 amelia1 CRON[12763]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 13:24:01 amelia1 CRON[12822]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 13:25:01 amelia1 CRON[12872]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:30:01 amelia1 CRON[12947]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:30:01 amelia1 CRON[12948]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 13:32:01 amelia1 CRON[13040]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 13:35:01 amelia1 CRON[13102]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:40:01 amelia1 CRON[13213]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 13:40:01 amelia1 CRON[13214]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:42:01 amelia1 CRON[13306]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 13:44:01 amelia1 CRON[13364]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 13:45:01 amelia1 CRON[13414]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:50:02 amelia1 CRON[13490]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 13:50:02 amelia1 CRON[13491]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 13:52:01 amelia1 CRON[13582]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 13:55:01 amelia1 CRON[13644]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:00:01 amelia1 CRON[13718]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:00:01 amelia1 CRON[13722]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 14:02:01 amelia1 CRON[13813]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 14:04:01 amelia1 CRON[13872]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 14:05:01 amelia1 CRON[13921]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:06:01 amelia1 CRON[13970]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 30d >/dev/null)
Feb 5 14:10:01 amelia1 CRON[14076]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 14:10:01 amelia1 CRON[14078]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:12:01 amelia1 CRON[14167]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 14:15:01 amelia1 CRON[14229]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:20:01 amelia1 CRON[14327]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 14:20:01 amelia1 CRON[14331]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:22:01 amelia1 CRON[14421]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 14:24:01 amelia1 CRON[14479]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 14:25:01 amelia1 CRON[14528]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:30:01 amelia1 CRON[14605]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:30:01 amelia1 CRON[14606]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 14:32:01 amelia1 CRON[14698]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 14:35:01 amelia1 CRON[14760]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:40:01 amelia1 CRON[14869]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 14:40:01 amelia1 CRON[14870]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:42:01 amelia1 CRON[14960]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 14:44:01 amelia1 CRON[15021]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 14:45:01 amelia1 CRON[15070]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:50:01 amelia1 CRON[15144]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 14:50:01 amelia1 CRON[15148]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 14:52:01 amelia1 CRON[15237]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 14:55:01 amelia1 CRON[15299]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:00:01 amelia1 CRON[15375]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 15:00:01 amelia1 CRON[15374]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:02:01 amelia1 CRON[15466]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 15:04:01 amelia1 CRON[15524]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 15:05:01 amelia1 CRON[15573]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:06:01 amelia1 CRON[15623]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 30d >/dev/null)
Feb 5 15:10:01 amelia1 CRON[15729]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 15:10:01 amelia1 CRON[15730]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:12:01 amelia1 CRON[15821]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 15:15:01 amelia1 CRON[15883]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:20:01 amelia1 CRON[15982]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 15:20:01 amelia1 CRON[15983]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:22:01 amelia1 CRON[16073]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 15:24:02 amelia1 CRON[16132]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 15:25:01 amelia1 CRON[16181]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:30:01 amelia1 CRON[16257]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:30:02 amelia1 CRON[16256]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 15:32:01 amelia1 CRON[16349]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 15:35:01 amelia1 CRON[16412]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:40:01 amelia1 CRON[16522]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:40:01 amelia1 CRON[16521]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 15:42:01 amelia1 CRON[16612]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 15:44:01 amelia1 CRON[16671]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 7d >/dev/null)
Feb 5 15:45:01 amelia1 CRON[16720]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:50:01 amelia1 CRON[16797]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
Feb 5 15:50:01 amelia1 CRON[16798]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 6h >/dev/null)
Feb 5 15:51:16 amelia1 collectd[664]: Exiting normally.
Feb 5 15:51:16 amelia1 collectd[664]: collectd: Stopping 5 read threads.
Feb 5 15:51:16 amelia1 collectd[664]: rrdtool plugin: Shutting down the queue thread.
Feb 5 15:51:16 amelia1 collectd[664]: collectd: Stopping 1 write threads.
Feb 5 15:51:16 amelia1 collectdmon[662]: Info: collectd terminated with exit status 0
Feb 5 15:51:16 amelia1 collectdmon[662]: Info: shutting down collectdmon
Feb 5 15:51:17 amelia1 collectd[16890]: Stopping statistics collection and monitoring daemon: collectd.
Feb 5 15:51:18 amelia1 collectd[16900]: Starting statistics collection and monitoring daemon: collectd.
Feb 5 15:51:18 amelia1 collectd[16907]: Initialization complete, entering read-loop.
Feb 5 15:51:18 amelia1 collectd[16907]: rrdtool plugin: Adjusting ā€œRandomTimeoutā€ to 0.000 seconds.
Feb 5 15:52:01 amelia1 CRON[16934]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 24h >/dev/null)
Feb 5 15:55:01 amelia1 CRON[17004]: (root) CMD (bash /home/pi/adsb-feeder/build/portal/graphs/make-collectd-graphs.sh 1h >/dev/null)
dump1090:
Feb 5 06:29:57 amelia1 systemd[1]: Stopping LSB: dump1090 daemon (mutability variant)…
Feb 5 06:29:58 amelia1 systemd[1]: Stopped LSB: dump1090 daemon (mutability variant).
Feb 5 06:30:05 amelia1 systemd[1]: Starting LSB: dump1090 daemon (mutability variant)…
Feb 5 06:30:06 amelia1 systemd[1]: Started LSB: dump1090 daemon (mutability variant).
Feb 5 06:31:02 amelia1 systemd[1]: Started LSB: dump1090 daemon (mutability variant).
Feb 5 06:31:12 amelia1 systemd[1]: Stopping LSB: dump1090 daemon (mutability variant)…
Feb 5 06:31:13 amelia1 systemd[1]: Starting LSB: dump1090 daemon (mutability variant)…
Feb 5 06:31:14 amelia1 systemd[1]: Started LSB: dump1090 daemon (mutability variant).
Feb 5 06:31:51 amelia1 systemd[1]: Starting LSB: dump1090 daemon (mutability variant)…
Feb 5 06:31:51 amelia1 systemd[1]: Started LSB: dump1090 daemon (mutability variant).
Apologies for the lengthy post.
So when accessing the web site you goto ](http://)<RPI_IP_ADDRES> correct?
If it is port 8080 and not 80 that Lighttpd is set to run off of you will need to change the following line in /etc/collectd/collectd.conf…
URL "http://localhost/dump1090"
to…
URL "http://localhost:8080/dump1090"
However by default the website should be accessible on port 80…
If it is accessible on port 8080 something had to have been changed somewhere.
Just curious you used a clean Rasbian image from say raspberrypi.org not the FlightAware PiAware image to install on correct?
I ran it using the command from Obj’s dump978 repository while I knew there was 978 traffic in range and it did show up on the dump1090 map. I then switched back to running as before with the script and the traffic disappeared from the 1090 map but was still shown on the 978 map.
I checked my dump978-maint.sh file and it shows:
#! /bin/sh
Start with logging.
rtl_sdr -d 1 -f 978000000 -s 2083334 -g 49.6 - | /home/pi/adsb-feeder/build/dump978/dump978 > /var/log/dump978.log &
while true; do
tail -n0 -f /var/log/dump978.log | /home/pi/adsb-feeder/build/dump978/uat2json /var/www/html/dump978/data | /home/pi/adsb-feeder/build/dump978/uat2esnt | /bin/nc -q1 127.0.0.1 30001
sleep 15
done
Does this look OK?
Thanks again.
The ADS-B Feeder Image February 5th, 2016 is now available.
This image was created using Raspbian Jessie Lite version November 2015 and includes all available updates available as of February 5th, 2016. The image comes with dump1090-mutability and the ADS-B Portal preinstalled. More features can be added by executing the file install.sh after configuring dump1090-mutability using the same command. A more detailed guide will be available shortly on how to setup and use the ADS-B Feeder Image and will be found at github.com/jprochazka/adsb-feed … eder-image once it has been completed. Until then use the following quick start instructions to get the image up and running.
Write the image to an SD card
Download the image from github.com/jprochazka/adsb-feed … 2016-02-05.
Use 7-Zip to extract the image from the archive. (7-zip.org/)
Write the image to your SD card using your favorite software.
Boot your device and login using the login ā€œpiā€ and the password ā€œadsbfeederā€.
Execute the following commands to configure dump1090-mutability.
cd ~/adsb-feeder/
./install.sh
To add additional features to your device execute install.sh again.
Make sure you change the password for the user pi using the command passwd.
Log Into The Portal Administration Area
To log into the portal administration area point your favorite browser to the address ](http://)<YOUR_DEVICES_IP_ADDRESS>/admin.
Login to the admin interface using the login ā€œadminā€ and the password ā€œadsbfeederā€.
You will be prompted to change your password the first time you login.
Known Issues
Forgot to disable the dump978 portal link by default.
Notes on this and future image releases…
This is the first image I created for public consumption so let me know if you run into any issues.
Images will be released in the future any time a major feature or change has been made to the project.
Minor changes made to the project in the mean time will need to be pulled from the GitHub repository and applied the same as in the past.
Everything looks OK.
Tomorrow, well actually later this evening, I will see what I can do to troubleshoot the issue starting things up while logging the output. Until then run dump978 with the command that worked for you. I would look into it now but the whole image creation, packaging and publishing process took longer than I thought…
The ā€œhow toā€ link appears incomplete on the download page for the Image file.
It just returns to github. Just FYI.
