I guess there was smoke in the cockpit. Being reported by CNN among others. Apparently you were able to catch a view of the Emirates A380 landing after the brief emergency delay.
I remember reading something about an AA 757 pilot who didn’t think those planes were perfectly safe because of the frequent occurences of smoke in the cockpit. I think it had something to do with the windshield too, you guys remember… I just found it…
From the Los Angeles Times
FAA to review failure of oxygen masks on American flight at LAX
The agency is reviewing why passenger masks failed either to deploy or to deliver oxygen. The American Airlines Boeing 757 was forced to make an emergency landing after smoke appeared in the cabin.
By Dan Weikel
Los Angeles Times Staff Writer
12:24 PM PDT, August 11, 2008
The Federal Aviation Administration is reviewing the widespread failure of passenger oxygen masks aboard an American Airlines flight that made an emergency landing last week at Los Angeles International Airport.
Initial reports indicate that almost half the masks either did not deploy or failed to provide oxygen once passengers pulled the pin to activate the flow of air.
American Flight 31, a Honolulu-bound Boeing 757, had taken off from LAX last Tuesday morning but turned back about an hour into the trip when the pilot reported smoke in the cabin, airport officials said.
The plane’s 188 passengers and seven crew members evacuated by sliding down emergency chutes. Eight people sustained minor injuries. The incident also caused airport officials to temporarily close both of the busy airport’s south runways.
American Airlines officials said the incident was caused by oil spilled on a compressor in one of the jet’s engines. This caused a strong smell and a haze in the cabin, they said.
The FAA has been concerned about oxygen mask failures aboard certain types of commercial aircraft, including Boeing 757s and 737s. In May 2007, the agency issued an air-worthiness directive ordering airlines to correct oxygen mask problems by 2012.
If there is smoke in the cabin, one has to assume that it is of a toxic nature and should not be breathed. The concentrated oxygen is better for the immediate responsiveness of the passengers as well as their long term health and well-being
Before asking questions you need to first ascertain the design conditions of the O2 generators on board a commercial airliner and when they are intended to be used - which will answer your question. Google is your friend.
When an AA flight made an emergency landing due to a cracked windshield( I made a post about it) The first officer was rather eager to criticize AA’s maintenance…
