On the tinkerboard I had the airspy and I want to move to the lightaware stick, sorry forgot to mention. piaware-config receiver type … I need the exact command.
The Flightaware Pro Stick is a RTL-SDR Device.
Piaware by default is set to receiver-type rtlsdr.
If you have changed it, you can reset it by following command:
sudo piaware-config receiver-type rtlsdr
Setting name
Possible values
Default value
Description
receiver-type
rtlsdr, beast, radarcape, relay, other
rtlsdr
configures how PiAware attempts to talk to the ADS-B receiver
Set “receiver-type” to “rtlsdr”. This is the traditional setup with a RTL-SDR dongle directly connected to the Pi. PiAware will connect to localhost:30005 for ADS-B data.
sudo apt-get update
E: The method driver /usr/lib/apt/methods/https could not be found.
N: Is the package apt-transport-https installed?
I’ve tried to to remove any https URLs within /etc/apt/sources.list and /etc/apt/sources.list.d/* in order to perform an apt-get update but it seems that I don’t have enough permissions…
It is a good idea to run “sudo apt-get update” to grab the package index. You can then try to install the package again and see if it was just missing the index. However, you might have the problem that the apt repo you are using doesn’t have the package.
This is set in piaware-config and you can see the current settings with the command:
piaware-config -showall
Here is a list of the different options. You want to have allow-auto-updates and allow-manual-updates set to yes.
pi@piaware:~$ sudo apt-get update
Hit http://flightaware.com jessie InRelease
Get:1 http://archive.raspberrypi.org jessie InRelease [22.9 kB]
pi@piaware:~$ piaware-config -showall #adept-serverhosts “piaware.flightaware.compiaware.flightaware.com {70.42.6.197 70.42.6.198 70.42.6.191 70.42.6.225 70.42.6.224 70.42.6.156}” # usi ng default value #adept-serverport 1200 # using default value #allow-auto-updates no # using default value #allow-dhcp-duid yes # using default value #allow-manual-updates no # using default value #allow-mlat yes # using default value #allow-modeac yes # using default value #beast-baudrate # no value set and no default value #feeder-id # no value set and no default value #flightaware-password # no value set and no default value #flightaware-user # no value set and no default value #force-macaddress # no value set and no default value #http-proxy-host # no value set and no default value #http-proxy-password # no value set and no default value #http-proxy-port # no value set and no default value #http-proxy-user # no value set and no default value
image-type piaware # value set at /us r/share/piaware-support/piaware-image-config.txt:5
manage-config yes # value set at /us r/share/piaware-support/piaware-image-config.txt:4 #mlat-results yes # using default va lue #mlat-results-anon yes # using default va lue #mlat-results-format “beast,connect,localhost:30104 beast,listen,30105 ext_basestation,listen,30106” # using default value #priority # no value set and no default value #radarcape-host # no value set and no default value #receiver-host # no value set and no default value #receiver-port 30005 # using default va lue #receiver-type rtlsdr # using default va lue #rfkill no # using default va lue #rtlsdr-device-index 0 # using default va lue
rtlsdr-gain 28.0 # value set at /bo ot/piaware-config.txt:1 #rtlsdr-ppm 0 # using default va lue #wired-address # no value set and no default value #wired-broadcast # no value set and no default value #wired-gateway # no value set and no default value #wired-nameservers “8.8.8.8 8.8.4.4” # using default va lue #wired-netmask # no value set and no default value #wired-network yes # using default va lue #wired-type dhcp # using default va lue #wireless-address # no value set and no default value #wireless-broadcast # no value set and no default value #wireless-gateway # no value set and no default value #wireless-nameservers “8.8.8.8 8.8.4.4” # using default va lue #wireless-netmask # no value set and no default value #wireless-network no # using default va lue #wireless-password # no value set and no default value #wireless-ssid # no value set and no default value #wireless-type dhcp # using default va lue
pi@piaware:~$ sudo -i
root@piaware:~# sudo apt-get install apt-transport-https
Reading package lists… Done
Building dependency tree
E: Unable to locate package apt-transport-https
root@piaware:~# sudo apt-get update
Hit http://archive.raspberrypi.org jessie InRelease
root@piaware:~#
in /etc/apt/conf.list commend everything with # except the line deb http://mirrordirector.raspbian.org/raspbian/ jessie main contrib non-free rpi
reboot the device
try sudo aptitude update see if it works.
if nothing happens
sudo find /usr/share/doc/apt-* ```
this is where apt-transport-https is. it could be missing in which case you have to re-install
package apt (not so difficult to download and install from web, provided you have the full and
not the lite jessie version, if not, it gets more complicated, need to download the package on PC
use filezilla to transfer it to pi, extract and install using tar and dpkg. )
have a look at
[https://packages.debian.org/jessie/apt-transport-https](https://packages.debian.org/jessie/apt-transport-https)
and
[https://community.c9.io/t/installing-apt-transport-https-issue/10994](https://community.c9.io/t/installing-apt-transport-https-issue/10994)
HTH
You have mentioned that: “I’ve tried to to remove any https URLs within /etc/apt/sources.list and /etc/apt/sources.list.d/* in order to perform an apt-get update but it seems that I don’t have enough permissions…”
I suggested switching to root to resolve the permission problem.
After switching to root, did you try to remove references to https in /etc/apt/sources.list, and /etc/apt/sources.list.d/*?
