I had a blue nooelec with the stock antenna and a raspberry pi in my attic for a while, this is a plot of a few hours-
I had some time off from work and wanted to see if I could do better. So I bought a FlightAware Pro Stick and a FlightAware filter and made this setup-
And it worked like crap. It took all day to make this plot-
So I tried making a coco antenna with 4 segments and that worked worse of all. Then I cut the 2 zip ties that held the filter and Pro Stick and let them hang down so the pigtail was straight instead of having the loop in it. That made a huge difference. Here’s a plot from just a few hours. I made it to North Carolina
Ultimately I want to move whatever I find works best to the roof or maybe even on top of one of these very tall pine trees in my yard.
After the last few days I have a lot of questions.
Has anyone put one in a tree? I guess I have to consider mounting and heat and powering it. It will downlink via wifi. I’m either going to power it with solar and batteries or run a wire up there and have a 5 volt switching power supply and run it on 12 volts . I’m seeing about 4 watts total power consumption on average right now.
Does anyone have any tips for optimizing the FlightAware Pro Stick, FlightAware filter and spider antenna that I made?
3 And lastly, my friend found this on the curb and gave it to me. He brinmgs me old computers and whatnot and I give him all the scrap metal from my many projects (like the gas turbine in the minivan project). Can I use this to help figure out my antenna performance?
Thanks for your time.
Chris “turbochris” Krug
If you want to see my other projects here’s my youtube channel.
