DVB-T RTL 820 as 1090 Mhz Signal Generator
Following is copy of today’s post, addressed to me on eham.net forum, from Martin - G8JNJ (g8jnj.net). I have not yet tried his proposal, but it sounds very promising, and if found successful, will prove a low-cost valuable tool for testing antennas & filters.
*"Anyway here’s (yet) another suggestion. You could use a spare RTL 820 dongle as a low power signal test source transmitting on 1090MHz to build a crude antenna test range.
Connect the RF input of the spare dongle to your dipole antenna, and set up the dongle with SDR sharp set to ‘center tuning’ mode, set the AGC off and set the RF gain to approx 12.5dB (this gives maximum LO leakage).
To produce an output near to 1090MHz tune SDR Sharp to either 268.93MHz for a plain vanilla RTL820 dongle or 266.5MHz for a RTL820T2 dongle (LO divided by four, minus the low first IF frequency which is usually either 3.57MHz for the 820T or 6MHz for the 820T2, depending on the exact tuning commands sent by SDR Sharp. This formula is valid from approx 220MHz to 880MHz which equates to an output frequency of 904MHz to 3544MHz). e.g. 1090MHz / 4 = 272.5MHz subtract 3.57MHz (for 820T) = 268.93MHz
This will bring the local oscillator up on a frequency very close to 1090MHz and produce an output level (at the dongle RF input connector) of about -80dBm.
This should be a high enough level for short range testing, but you could always ‘pep’ it up a bit further by using one of your satellite TV amps (if required).
Placing the test source antenna some distance away from your ‘antenna under test’ would allow you to make simple gain comparisons from a stable signal source, which should be repeatable on a day to day basis."*
Ooooooh I like it :laughing: :laughing:
I’ve just ordered 2 RTL820T2s from Hong Kong. As soon as they turn up I’ll give it a go.
Looks interesting – I’ll try it out on the spectrum analyzer over the weekend (that’s when I should have some time) and report on results.
–bob
This looks amazing!! Has anyone tried it yet? I may give it a shot after the honey-do list is completed :slight_smile:
…now back to building fence.
From where can we achieve that using piaware?
Bob, did you try this? Any results? We have a rainy weekend here in the UK and I’ve finished the honey-do list 8)
Really? My honey-do list never finishes. When I am near finishing one, a new list pops up. Are there any pop-up blockers available for honey-do lists? :slight_smile:
There are, but most involve severe adverse economic outcomes or lengthy incarcarations :open_mouth:
would like to see the command line that could be used to configure the dongle (in lieu of running sdrsharp)
A bit late to the party, but has anyone seen this: Adf4350 Rf Signal Source Frequency Synthesizer Development Board Locking Loop Frequency Synthesizer 137m-4.4ghz Logic Analyzer - Reactive Power Controllers - AliExpress ?
It’s a $15 “137M-4.4GHz RF Signal Source Phase Locking Loop Frequency Synthesizer ADF4350 Development Board”. It could presumably be controlled by an Arduino. It has RFout + and - (don’t know how that relates to an antenna. Signal strength is +5dBm (programmable).
Haven’t played with one (have other sig gens that go to 8GHz), but for antenna work, a noise source is more useful.
(even a cheap one)
Made my S53MV filter ( Practical cavity filters for the frequency range 1GHz...4GHz ) for 1090 Mhz. First used this option with the DVB-T dongle to adjust the filter. After a some weeks adjusted the filter with a BG7 noisesource. Just a little finetuning for the bandwidth was needed. Very good and simply option. Also used RSP-Spectrum Analyzer with RSPdx.
