my son fell in love with airplanes and we live in north Colorado near small airport. He attempt to build piaware but we realized that we have a wrong dongle ( with FC0012 tuner ).
All the recommended dongles are out of stock so would you know if this dongle with RTL2832U+R820T2 would work for both simultaneous reception of 1090Mhz and 978Mhz?
Yes, this dongle will work for both 1090 and 978, but only one dongle will not work for both simutaneously.
For simultaneous reception, you will need 2 such dongles, connected to 2 antennas. One dongle+antenna will be used to receive1090 mhz, other dongle+antenna will be used to receive 978 mhz.
There are quite a few options.
What you linked are actually sometimes mislabeled FC tuners you’re trying to avoid.
I believe the green RB stick is currently the best option for the price, an antenna is needed though.
You would be much better off buying two RTL-SDR Blog brand dongles vs. those cheap TV receiver ones. They’re currently available on RTL-SDR.com’s official store on eBay for $29.95 each with free shipping. The TV tuners lack temperature compensated crystal oscillators (TCXOs) so they tend to drift off-frequency when they warm up from use. The better dongles like RTL-SDR, FlightAware, Nooelec, ADSBexchange etc. have been designed from the ground up to be radio receivers first and foremost and have TCXOs among other improvements.
@Slipstream232 You have 2 of the resident experts helping you out here, @abcd567 and @wiedehopf . It would be worth having a scroll through their previous posts for ideas on setup, programming and even making your own antenna that will be miles better than that little stock antenna in the picture. They are a fountain of knowledge and the information they have been kind enough to share will help you no end
More specifically, this is not a software limitation – the rtlsdr hardware is simply not capable of receiving both 978MHz and 1090MHz at the same time. You need two dongles (or a considerably more expensive SDR and a bunch of development work)
If you want “easy” you can buy the kit but the antennas are kinda junk.
Then I built this for the antenna:
If you buy that kit above, you can get started right away with so-so antennas. Then maybe upgrade them later for another project to see the difference with your son.
thank you, if we get the second dongle for 978MHz, would you know of any guide how to tell Flighaware OS on Raspberry to tune to 978MHz. I believe the 1090 is default.
1 - Serialize dongles if using UAT 978: (CLICK HERE)
If you want to recieve both ES1090 and UAT978, then two dongles are required, one for 1090 and other for 978. In this case you will have to serialize dongles so that correct dongle+antenna sets are used by dump1090-fa and dump978-fa.
For 1090 Mhz dongle: use 8-digit serial # 00001090
For 978 Mhz dongle : use 8-digit serial # 00000978
2 - Configure UAT 978
CASE-1:
If you are using Piaware SD Card image (downloaded from Flightaware site):
This requires using a thin wire so that it can be easily wrapped over brass stud of magnetic base of the antenna.
Thin steel tie wire, or one wire of a scrap network cable, will do the job. Both are about 0.5 mm dia. Please see photos below.
Do NOT use a thick or stiff wire as it will be hard to wrap around the brass screw of base, and applying force to wrap it may cause screw to break away from base. I have broken away one screw from base when trying to wrap TV Coax (RG6) core wire. This wire looks copper, but is actually made of steel of 1mm dia, coated with copper.
I have on of those antennas and they perform better than expected indoors. Tried other generic ones, even the lambda/2 one that @abcd567 shows and they are not better.
Of course, the real deal is the Flightaware antenna, installed outdoors.
That coiled antenna, from second story indoors, behind the window glass gets this results:
