10.2 wireless-type status not working?
Now that the SSID/password issue seems to have been fixed, can someone offer some assistance on this issue. I use STATIC IP addresses for many of my devices. My feeder has successfully used a static wireless IP for all previous versions of PiAware (including 10.1!). Now, the wireless-type static directive seems to be ignored.
The -config.txt file contents are:
This file configures the Piaware sdcard image
configuration. Whenever the system boots, this
file is read and its contents are used to
configure the system.
Lines beginning with a ‘#’ are comment lines
and are ignored. Blank lines are also ignored.
All other lines specify configuration settings.
For simplicity, this file only shows the most common options.
For a complete list of options, see
PiAware - Advanced Configuration Settings - FlightAware
NETWORK CONFIGURATION
By default, PiAware will use DHCP when connecting to your network.
For other configurations, see the Advanced Configuration page
linked at the top of this file.
Should piaware use the wired ethernet port
for network access?
wired-network no
Should piaware use a wifi adaptor for network access?
If you are using a Pi 3, this will use the built-in wifi.
Otherwise, you will need to attach a supported USB wifi adaptor.
wireless-network yes
Wifi SSID and password.
This should be changed to match your wireless
network SSID and, for networks that require
a passphrase, the passphrase.
If your SSID or password contains characters other than
numbers and letters, such as the # character or whitespace,
you should enclose the value in quotation marks. For example,
“pass word” or “pass#word”.
To include quotation marks (") in a quoted value, use "
To include a backslash () in a quoted value, use \
wireless-ssid Xxxxxxxxxx
wireless-password xxxxxxxxxxxxxxxxxxxxxxxxxx
static IP configuration
wireless-address 192.168.1.105
wireless-netmask 255.255.255.0
wireless-broadcast 192.168.1.255
wireless-gateway 192.168.1.1
wireless-nameservers 192.168.1.1
1090MHZ RECEIVER CONFIGURATION
For a complete list of receiver types and their associated settings,
see the Advanced Configuration page linked at the top of this file.
For a receiver type of ‘rtlsdr’, this setting controls the dongle gain.
Use “max” for maximum gain. Other values are interpreted as a gain in dB.
rtlsdr-gain max
OTHER CONFIGURATION
Should automatic system updates (initiated by FlightAware) be allowed?
allow-auto-updates yes
Should manual system updates (initiated by you from the website control
panel) be allowed?
allow-manual-updates yes
Should PiAware enable multilateration where possible?
You may need to disable this if multilateration overloads your receiver.
allow-mlat yes
Should PiAware enable reception of Mode A/C messages when requested?
You may need to disable this if processing Mode A/C overloads your receiver.
allow-modeac yes
Additional settings can be added below.
feeder-id
I request wireless static ip of 105. Piaware ignores that and instead reverts to DHCP and assignes the next random IP available.
Anyone know why?
the OS used is Raspberry Bookworm
To set a static ip in Bookworm you will need to use the network manager
sudo nmtui
This will bring up the graphical user interface for the network manager
The steps below show how to set a static IP for a Wired connection but this can be done for a wireless connection as well.
Select OK
Select Edit to edit the wired connection
Edit the IPv4 parameter to the desired IP adress, Netmask (the /24 behind the IP address), Gateway and DNS server.
When done scroll to the bottom and select OK
Select Quit and hit enter
Sudo reboot to let the new settings take effect.
Thanks Tom, I should have thought about this approach.
On reflection, I should NOT have had to think about this, given the directions Flightware provides for the installation/upgrade of 10.2. Their Step 3 (optional Enable WiFi) explicitly gives the steps to enable wireless static IP.
The conclusion is that the documentation is in error. It seems to me that Flightaware has 2 options: a) give the explicit steps, as you have outlined, a user needs to follow to enable static IPs, or b) fix the issue in the image.
I wasted several hours this afternoon on this issue because, as of Jan 2026, the documentation still has not been updated for Raspi Bookworm. In my case, the wireless would not come up at all until I figured out I needed “wireless-country US” in piawareconfig.txt which is also no longer in the root of /boot.
Once I got that, then I ran into the static IP settings in piaware-config.txt being ignored and nmtui configuration required instead.
The country code should relate to the country you are in. For me it is GB but I agree however the documentation is outdated.
