I’m trying to set up my piaware for the first time. I flashed the drive and edited the wired settings. My network is on 10.0.0.* not 192.168.0.* So I’m assuming I need to supply the static IP addresses to connect to.
wired-network yes
Wired network configuration:
Most networks will use DHCP
wired-type static
Alternatively, a static address configuration
can be provided; set “wired-type” to static to use this.
You can set it up either way. If you have a DHCP server, Piaware will pickup an IP.
Static obviously works too, just be careful to pick an IP outside the DHCP range.
