Why do you use dump1090-mutability?
Thanks, it was the direct feed from an Rpi I was referring to
Why would you do that?
Same reason as for feeding all other sites.
+1 dump1090-mutability in the case of use with OpenWrt/LEDE and with different linux distribution as ArchLinux.
@obj, as already mentioned in this thread the OpenWRT/LEDE build of dump1090 actually uses this as source.
The problem of switching to dump1090-fa is that the db folder is generally too big (>12Mb) for most of the router’s flash memory. Could be there any solution, as for example manually using a reduced version of the db?
Sure, it should run fine without the DB, you can probably just omit the whole db directory. Or there are scripts under tools/ that let you regenerate the DB with whatever data you want (I don’t know how you’d pick what to include though)
Hi abcde567
Thanks for your contributions. I provide data to FR24 and FA. Out of the reasons you list numbers 1, 2 and 4 apply to me. :slight_smile:
The steps you are providing for uninstall of dump1090-mutalibility and install of dump1090-fa, will that continue to provide data to FR24 as well as FA ? Can I safely do this will maintaining FR24 feed (http://192.168.86.251:8754/index.html)?
thx
@thespeedycab
First you have to tell us what is your software:
Pi24 image + installed FA feeder
OR
Raspbian image + installed FR24 and FA feeders
OR
Something else
@abcd567
Aha. Good point, if not a critical one.
I have RPI with Raspian image and dump1090-mutability v1.15 installed. Then I added the FR24 feeder and the FA feeder.
Yes, the method to replace dump1090-mutability by dump1090-fa is safe and wont break the feeds to FR24 and FA.
However when the method was posted, the current version for dump1090-fa was 3.6.2, while now it is 3.6.3. I am therefore repeating the method with latest version number 3.6.3 below:
1 - Uninstall dump1090-mutability
1.1 - Purge installed dump1090-mutability
sudo dpkg --purge dump1090-mutability
1.2 - The dpkg --purge command removes all files and configuration of dump1090-mutability, making system clean. However it fails to remove one folder (/usr/share/dump1090-mutability) because the folder is not empty. This is not a problem. Manually remove it by command below.
sudo rm -rf /usr/share/dump1090-mutability
2 - Install dump1090-fa
wget http://flightaware.com/adsb/piaware/files/packages/pool/piaware/p/piaware-support/piaware-repository_3.6.3_all.deb
sudo dpkg -i piaware-repository_3.6.3_all.deb
sudo apt-get update
sudo apt-get install dump1090-fa
sudo reboot
Does changing to dump1090-fa break statistics of The ADS-B Receiver Project?
I have tested this method long ago. Dont remember well about adsb-receiver project stats, but if I recall correctly, in one of configuration files of collectd, I had to change dump1090 to dump1090-fa.
EDIT: found it
@Randstad
Thanks to @GeorgLichtblau for finding this in August 2016
Open file collectd.conf for editing
sudo nano /etc/collectd/collectd.conf
Press ctrl+w and type
module dump1090
Press Enter key, the cursor will jump to line:
    <Module dump1090>
            <Instance localhost>
                    URL "http://localhost/dump1090"
            </Instance>
    </Module>
Add -fa after dump1090 as shown below
    <Module dump1090>
                    URL "http://localhost/dump1090-fa"
            </Instance>
    </Module>
Save the file, exit and restart collectd module
sudo service collectd restart
@abcd567
Great, thanks! Will give it a try :grinning:
Familiarity for me.
My receiver setup was running unchanged for a couple of years; Piaware 3.5.3, and dump1090-mutability in --net-only fed by Airspy. Piaware and dump1090 were on a Pi 2, and Airspy a Pi3. Last week I finally spent time moving everything to the Pi3. Not being involved for awhile I forgot many of the nuances. I went through several different builds: apt-get Piaware and dump1090-fa, Piaware SD, ADSBexchange scripts, then ADSB-receiver scripts.
Ultimately what worked for me was the familiarity with dump1090-mutability…in the little time I wanted to spend on this project it wasn’t clear to me how to tweak dump1090-fa in the same manner as dump1090-mutability (eg simply edit the config file or run thru sudo dpkg dump1090-reconfigure). That’s not to say it isn’t there, I just didn’t/don’t want to invest the time right now to figure it out…it all works and I’m satisfied.
At the FR24 forum you wrote a nice detailed install instructions for set up of the dump1090-mutability v1.15-dev. I am looking for something like that here, but can’t find it.
Is it just as simple as described on: https://flightaware.com/adsb/piaware/install ?
And then add the FR24 flightfeeder ?
Apologies for my ignorance or if I overlooked it
You can configure FR24 as described in the thread over at FR24 or here Bake a Pi
The installation of dump1090-fa and piaware you can just do as described on the install page you linked.
You will need to either deactivate or remove dump1090-mutability.
sudo apt-get remove dump1090-mutability
You might also need to run:
sudo lighty-disable-mod dump1090
Those two only apply if you had dump1090-mutability installed before.
If FR24 is already installed and configured to get data on port 30005 there is no need to change anything.
@wiedehopf Great. Thanks! As always
The sad demise of an old faithful… :sob:
github > mutability > dump1090 > branch master - 5 days ago:
https://github.com/mutability/dump1090/blob/master/README.md
Old dump1090-mutability fork
dump1090-mutability is no longer maintained; please don’t use it for new installs.
For new installs and ongoing development, try dump1090-fa, which is available at GitHub - flightaware/dump1090: Dump1090 is a simple Mode S decoder for RTLSDR devices
The historical master branch is available in the unmaintained branch.
Russians are still keen to use dump1090-mutability, and strangely prefer ver 1.14 over 1.15~dev or dump1090-fa.
Below is the translation (from Russian to English) of an interesting discussion on this topic dated yesterday:
Member Madlzz’spost:
My Reply to Madlzz:
Reply to my post by Senior Member ffa1978 :
