Hello everyone,
my english is not the best so please excuse that…
i´m trying to recieve some ADS-B messages for a few day´s now and i know that my position is not the best at the moment but i can mount the reciver+ antenna on top of a 120m “tower” (windturbine…) but before i start bringing the stuff up that thing i try to build a “good” working" antenna.
Because of the very differnt results of the DIY Coax Collinears i thought i would stick to the “easyer” wire antennas… but every desing is totaly differnt?!
Design 1( Sprut/ abload.de/img/1z5rzj.jpg ) uses 1/2Wv Ground and 1/2Wv elements +1/2Wv coils…
Design 2(G7RGQ/ abload.de/img/20ppbn.jpg ) uses 196mm Ground(?!?) 1/2Wv bottom only 1/4 wv Coils 3/4 top and middle
Design 3 ( abload.de/img/3ouqu3.jpg ) ist almost the same as G7RGQ´s but shorter Ground (1/2Wv) strange bottom at 187mm 1/4Wv coils…
all 3 are better performing than the 1/4Wv Gp and the stock/shortend stock antenna. But if i hook the RTL Dongle to roof gutter i will see some planes also…
My Question is why is everyone using a differnt type (lenght mostly) of the coil? From what i have found is that the coil is doing a phaseshift so that all parts of the antenna are delivering the right signal at the right moment (bad explanation i know…) but how can it be that someone uses 1/2 Wv for a coil and the next one is using only 1/4wv?
i´ve found some *pdf document ( abload.de/img/buchb1pb0.jpg ) from a german site and it states that a 1/2 Wv bottom element needs a transformer at the bottom because of the high impedance but with a 1/4Wv bottom this is not necessary( seems logic because of the well known 1/4Gp). After that 1/4Wv element you can add a phasing coil (how long should it be?!?) and another 1/2 Wv whip…
at the moment i´m trying a 1/4wv bottom +1/2wv coil+ 1/2wv whip and it seems that this thing is better than G7RGQ desing.
