I am new to this ads-b tracking, and recently got a receiver set up. While waiting for the hardware to get in, I read a bit about making your own antenna to extend the range of the receiver over the standard antenna that ships with the receiver (and which is supposed to be crap).
After a couple tries (one dipole, one colinear coaxial, and another I can’t name), all the antennas, while getting some signal are significantly worse that the original antenna. I am no electric/electronic engineer, so I am probably missing some essential point to antenna design that is so obvious that all the DIY site omit to tell about.
Thank you for the feed back. I will work on these a bit more, and see, if I can get better connections. Actually I was wondering, how accurate must the length be? when you say that each rod of the dipole must be 68mm, this gives a total length of 136mm, while the DIY cork antenna state a 137mm length including the gap between both sides. Does the 1 mm difference make a big deal, on the range?
In the same type of questions, how do I determine the speed attenuation factor of my coax for the coaxial colinear antenna? (short of using a scope, and a very long section of coax).
What kind of range improvement should I expect with a DIY antenna, over the stock antenna?
136/137 - I wouldn’t have thought it would make much difference - you can’t tell from a forum post just how much care people have put into what they’re doing.
Someone else here has written about the poor performance of their antenna … in their case the problem seems to be a 900mhz cell tower 200 meters away swamping the reciever.
all we can do is offer solutions.
A dipole should offer at least as good a signal as the supplied whip if in the same position - that would be a reasonable test to make sure assembly is ok.
I built a 3ft collinear with rg6. Cut the sections to 6in and cut off little under an inch on each end. Insulated and put inside a ovc pipe. Its connected with a 25ft rg6 cable directly to my receiver. I have tripled the amount of planes I saw with the small whip antenna
