I just got one of these and switched it with the antenna I got with my RTL-SDR and the range has gone right down.
Is there anything I can do/modify to get a better range?
I also bought those, and found that they had far worse reception than my home built antennas. I have made and tested quite a few, but two designs have stood out far above the rest.
not quite as easy to build (I ordered some semirigid coax off amazon)
spectacular range (I now consistently get 200nm+, and my messages per second were double what I got from the cantenna
super durable
inconspicuous
The cantenna is dead easy to build, and gets about 4x the messages per second that those junk rubber duck ones do. I can’t recommend the J-pole enough though. I was shocked at how well it performed. It gets another 2x messages per second than even the cantenna at my location.
I get great results from the telescopic antenna included in this bundle. I keep it fully retracted so that it is set at about 5.5" which is 1/2 wavelength for 1090 Mhz.
One other consideration: I believe that the stratux people claim you need a pretty good ground plane to get the rubber ducky antenna working well. My package included a big strip of copper tape to make the ground plane. you might try using it with yours to see if it improves the situation. I tried the copper tape, and then a 4x4 inch square of copper, and neither seemed to have any effect, but YMMV.
Just fell for the same trap, ordering directly from Nooelec’s website $6, +$4 for shipping. Reading this lets me know I wasted my money. Disappointing.
