I have uploaded a number of photos that do not appear when I type in the tail number of the particular airplane. In fact, probably nothing I’ve uploaded for the last several months appears. However, if I go to the photo’s I’ve uploaded, they’re all in my library, or whatever you want to call it, and quite a number of them show they have been viewed, many quite a number of times. Who is looking at these and how are they seeing them if I can’t see them? Why are they not being posted after I upload them?
Many of your photos aren’t associated with the aircraft’s N number, e.g. 1080J isn’t identified by N number in the photo’s description so it won’t show up when you search for the aircraft.
So how do I correct that? Am I doing the upload incorrectly? In most cases, I enter an N number with the photo?
See discussions.flightaware.com/view … 0145#80145 for possible solution.
There’s your problem right there. If you don’t enter an N number when you upload the photo, it’s therefore not possible to search for the photo by entering an N number.
But on most of them, I have entered an N number. Why aren’t those showing up. It’s a small minority that I’ve forgotten. 99% have the N number. Basically, nothing seems to be showing up since the upload system was changed.
Hmmmmmm… I just tried searching for several of your photos by N number with no results found, even though I can see the photos individually on your photo page and see that they are correctly identified by N number in the description. Very strange.
I placed a vote on the picture uploaded for flightaware.com/live/flight/N2209R and it did not show up… (I did a shift - refresh in MSIE 7 and F5 to force a refresh)
The vote does show up on 216.52.171.100/photos/view/photo … ywisch;o=5 as there was no votes before my casting one so what Mark posted in the link I provided above may not be working??
Yeah, clearly there are some issues. I’ve got about 700 or so that do show up, and then after the change, nothing. Not sure what I could do differently
Photo needs to be tagged N2209R, no short hand or lower case.
Could it possibly be set up on the back end to convert lower case to upper case on submission or have instructions clearly marked at 216.52.171.100/photos/upload.rvt to type in upper case?
Is there any way I can go back and edit the ones that aren’t showing up?
Yes, the uploader can click on any photo to edit the tag.
It should be validating any input to a proper registration at some point, but I don’t remember where.
something happened recently that when you “track” a certain N#, the photo box says ‘upload a photo now’ even though photos have been posted of that aircraft
There’s definitely a problem as of today. Aircraft that I’m very familiar with, that fly in & out of KFDK frequently have been showing on the tracking page for weeks … but as of today the blank place holder is there instead.
This is true of most of my photos, including those that have numerous votes. (All of my photos have N-numbers).
The problem still exists today, though it is inconsistent. Some photos associate correctly and others (many) do not.
Add N1943L to the list… It used to display so as others are experiencing, something broke.
I did run it through both the discussion forums and live site as well as use Firefox and MSIE 8.0 to see if maybe something behaved differently from different access points but everything was consistent.
I went to the original photo upload page that you put in the registration, aircraft type, description, airport, etc; I clicked “Submit Query” and the small “preview” pic that is on the flight tracker page re-appeared. I did to several photos that I uploaded and I know were there at one point, but then said “upload photo now”. If you have just a few pics, its not that bad but if you have alot of pics, it takes too long. Something has messed up?
N427BC is another.
Of my 400+ photos, about 70% are not showing up. The others appear as they should, which only makes the problem more of a mystery.
Votes, number of views and number of photos do not seem to have any effect on the problem. It’s inconsistent.
For the record, here are the N-numbers of my photos that do not appear on the tracking page:
N119W
N14935
N156SL
N158GJ
N159HR
N1602G
N161SL
N169GT
N176SL
N1810R
N188WQ
N1929Y
N1975T
N19783
N1978D
N208JW
N20LV
N20WL
N2138N
N213UV
N2152T
N2172D
N219DS
N21KM
N22591
N2334J
N238PR
N246TW
N24702
N2473G
N2584F
N25VH
N26499
N271J
N272MC
N2743G
N275BM
N28199
N28638
N28665
N287CS
N2891X
N2971Q
N300FS
N301ML
N305LM
N3073W
N329M
N37NY
N38VV
N392MA
N399CB
N400WK
N403MC
N40BZ
N411GC
N411JS
N41343
N418CS
N421G
N424MW
N4418C
N441S
N44441
N448ST
N44GW
N46GA
N4GA
N503W
N5097C
N509QS
N520LR
N52265
N525RB
N5271T
N531
N5383N
N539XJ
N54PE
N5734
N5QN
N606PM
N646VN
N666K
N6670H
N675MC
N6830L
N6840G
N6MF
N6TH
N6VB
N70PH
N711ER
N717HB
N7189W
N724TB
N724TX
N739CN
N740EV
N741BD
N744P
N7455D
N74JD
N75229
N757XJ
N77312
N7765N
N790K
N7913B
N802TJ
N80426
N8042B
N8144L
N900CP
N9075G
N912BG
N913CK
N9154H
N9251S
N932QS
N935FA
N9439K
N954CA
N95620
N9656X
N9809P
N980CD
N984ME
N987QS
N9WR
