I’ve had PiAware set up for about 3 weeks now. The setup is far from optimal, in that I’m using the antenna that came with the dongle, and it’s sitting on a second-floor apartment balcony (with a third-floor balcony above it), so I’m not expecting that I’d be getting huge numbers of aircraft or great range. I would expect, though, the results to be fairly consistent–and they aren’t. In the last week, my high has been 164, and my low has been 12. Nothing in the setup has changed–the antenna’s in exactly the same place, the pi is the same, etc.
I’m able to connect using ssh, but most of the time the web page (LAN IP:8080) times out. piaware-status reports:
pi@piaware ~ $ sudo piaware-status
dump1090 is running.
faup1090 is not running.
piaware is running.
dump1090 is listening for connections on port 30005.
dump1090 is listening for connections on port 10001.
piaware is connected to port 10001.
dump1090 is NOT producing data on port 30005.
dump1090 is NOT producing data on port 10001.
If the results were low but consistent, that would be one thing, but the inconsistency suggests to me that something isn’t working quite right. What should I be looking at?
