Hi
I have a SBS-3 which I use via basestation software to feed my local setup, and use the IQ feature for DSD.
I used the very helpful scripts to install all the flightaware components on some debian based (ubuntu) distributions - as I do not have a PI available at this location.
I used modesmixer2 to create a server listening on port 30005 & fatv 10001 so that the FA executables can connect.
I then used modesmixxer2 to connect to my basestation on a remote windows machine and pull the SBS data.
I am getting ADSB data and pushing to FA as witnessed in my webstats. However, i an not getting sync with other local receivers.
03/12/2016 08:23:40 mlat(12864): Receiver status: connected
03/12/2016 08:23:40 mlat(12864): Server status: not synchronized with any nearby receivers
03/12/2016 08:23:40 mlat(12864): Receiver: 0.0 msg/s received 0.0kB/s from receiver
03/12/2016 08:23:40 mlat(12864): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
03/12/2016 08:23:40 mlat(12864): Aircraft: 0 of 0 Mode S, 0 of 0 ADS-B used
03/12/2016 08:26:16 23540 msgs recv’d from modesmixer2 (331 in last 5m); 7274 msgs sent to FlightAware
03/12/2016 08:31:16 25867 msgs recv’d from modesmixer2 (2327 in last 5m); 9601 msgs sent to FlightAware
Are there any special options needed for modesmixer to allow MLAT entries?
Do i have any other options to connect my SBS-3 with basesataion to FA and give mlat? (the basestation software SBS machine is obviously windows)
It should be noted that i have another fully functioing RTL dongle (with massively reduced range) based FA instance using MLAT without issue - on the same external public IP address - would that have a part?
Regards all
Mike
