Usb_interface_claim error on 978
My UAT978 receiver quit working. It’s the FA orange dongle and it worked well until the latest update. I’ve serialized according to instruction here.
Log shows the 1090 active but 978 shows the usb_interface_claim_error
dump978-fa.service:Unit entered failed state
dump978-fa.service: failed with result ‘exit-code’.
Post a longer log, preferably on pastebin and link it here.
Debug commands · wiedehopf/adsb-wiki Wiki · GitHub
Also check the command
sudo piaware-config
to see if the serials are configured correctly.
Then check if the dongles are still showing the right serial:
sudo systemctl stop piaware dump1090-fa dump978-fa
sudo rtl_test
You can either restart the services or just reboot.
  1. pi@piaware:~ $ sudo piaware-config
  2. allow-auto-updates yes # value set at /bo ot/piaware-config.txt:67
  3. allow-manual-updates yes # value set at /bo ot/piaware-config.txt:71
  4. allow-mlat yes # value set at /bo ot/piaware-config.txt:75
  5. allow-modeac yes # value set at /bo ot/piaware-config.txt:79
  6. feeder-id 7f8a6959-18dd-4458-a614-c55f346ddc7e # value set at /boot/piaware-config.txt:84
  7. image-type piaware # value set at /us r/share/piaware-support/piaware-image-config.txt:5
  8. manage-config yes # value set at /us r/share/piaware-support/piaware-image-config.txt:4
  9. rtlsdr-gain max # value set at /bo ot/piaware-config.txt:60
  10. uat-receiver-type sdr # value set at /bo ot/piaware-config.txt:85
  11. uat-sdr-device driver=rtlsdr,serial=00000978 # value set at /bo ot/piaware-config.txt:86
  12. wired-network yes # value set at /bo ot/piaware-config.txt:27
  13. wireless-network yes # value set at /bo ot/piaware-config.txt:33
  14. wireless-password # value set at /bo ot/piaware-config.txt:49
  15. wireless-ssid MyWifiNetwork # value set at /bo ot/piaware-config.txt:48
  16. pi@piaware:~ $
  17. pi@piaware:~ $ pi@piaware:~ $ sudo piaware-config
  18. -bash: pi@piaware:~: command not found
  19. pi@piaware:~ $ allow-auto-updates yes # v alue set at /boot/piaware-config.txt:67
  20. -bash: allow-auto-updates: command not found
  21. pi@piaware:~ $ allow-manual-updates yes # v alue set at /boot/piaware-config.txt:71
  22. -bash: allow-manual-updates: command not found
  23. pi@piaware:~ $ allow-mlat yes # v alue set at /boot/piaware-config.txt:75
  24. -bash: allow-mlat: command not found
  25. pi@piaware:~ $ allow-modeac yes # v alue set at /boot/piaware-config.txt:79
  26. -bash: allow-modeac: command not found
  27. pi@piaware:~ $ feeder-id 7f8a6959-18dd-4458-a614-c55f346ddc 7e # value set at /boot/piaware-config.txt:84
  28. -bash: feeder-id: command not found
  29. pi@piaware:~ $ image-type piaware # v alue set at /usr/share/piaware-support/piaware-image-config.txt:5
  30. -bash: image-type: command not found
  31. pi@piaware:~ $ manage-config yes # v alue set at /usr/share/piaware-support/piaware-image-config.txt:4
  32. -bash: manage-config: command not found
  33. pi@piaware:~ $ rtlsdr-gain max # v alue set at /boot/piaware-config.txt:60
  34. -bash: rtlsdr-gain: command not found
  35. pi@piaware:~ $ uat-receiver-type sdr # v alue set at /boot/piaware-config.txt:85
  36. -bash: uat-receiver-type: command not found
  37. pi@piaware:~ $ uat-sdr-device driver=rtlsdr,serial=00000978 # v alue set at /boot/piaware-config.txt:86
  38. -bash: uat-sdr-device: command not found
  39. pi@piaware:~ $ wired-network yes # v alue set at /boot/piaware-config.txt:27
  40. -bash: wired-network: command not found
  41. pi@piaware:~ $ wireless-network yes # v alue set at /boot/piaware-config.txt:33
  42. -bash: wireless-network: command not found
  43. pi@piaware:~ $ wireless-password # v alue set at /boot/piaware-config.txt:49
  44. -bash: syntax error near unexpected token `newline’
  45. pi@piaware:~ $ wireless-ssid MyWifiNetwork # v alue set at /boot/piaware-config.txt:48
  46. -bash: wireless-ssid: command not found
  47. pi@piaware:~ $ allow-auto-updates yes # v alue set at /boot/piaware-config.txt:67
  48. -bash: allow-auto-updates: command not found
  49. pi@piaware:~ $ allow-manual-updates yes # v alue set at /boot/piaware-config.txt:71
  50. -bash: allow-manual-updates: command not found
  51. pi@piaware:~ $ allow-mlat yes # v alue set at /boot/piaware-config.txt:75
  52. -bash: allow-mlat: command not found
  53. pi@piaware:~ $ allow-modeac yes # v alue set at /boot/piaware-config.txt:79
  54. -bash: allow-modeac: command not found
  55. pi@piaware:~ $ feeder-id 7f8a6959-18dd-4458-a614-c55f346ddc 7e # value set at /boot/piaware-config.txt:84
  56. -bash: feeder-id: command not found
  57. pi@piaware:~ $ image-type piaware # v alue set at /usr/share/piaware-support/piaware-image-config.txt:5
  58. -bash: image-type: command not found
  59. pi@piaware:~ $ manage-config yes # v alue set at /usr/share/piaware-support/piaware-image-config.txt:4
  60. -bash: manage-config: command not found
  61. pi@piaware:~ $ rtlsdr-gain max # v alue set at /boot/piaware-config.txt:60
  62. -bash: rtlsdr-gain: command not found
  63. pi@piaware:~ $ uat-receiver-type sdr # v alue set at /boot/piaware-config.txt:85
  64. -bash: uat-receiver-type: command not found
  65. pi@piaware:~ $ uat-sdr-device driver=rtlsdr,serial=00000978 # v alue set at /boot/piaware-config.txt:86
  66. -bash: uat-sdr-device: command not found
  67. pi@piaware:~ $ wired-network yes # v alue set at /boot/piaware-config.txt:27
  68. -bash: wired-network: command not found
  69. pi@piaware:~ $ wireless-network yes # v alue set at /boot/piaware-config.txt:33
  70. -bash: wireless-network: command not found
  71. pi@piaware:~ $ wireless-password # v alue set at /boot/piaware-config.txt:49
  72. -bash: syntax error near unexpected token `newline’
  73. pi@piaware:~ $ wireless-ssid MyWifiNetwork # v alue set at /boot/piaware-config.txt:48
  74. -bash: wireless-ssid: command not found
  75. pi@piaware:~ $ pi@piaware:~ $
  76. -bash: pi@piaware:~: command not found
  77. pi@piaware:~ $ pi@piaware:~ $ pi@piaware:~ $ sudo piaware-config
  78. -bash: pi@piaware:~: command not found
  79. pi@piaware:~ $ -bash: pi@piaware:~: command not found
  80. -bash: -bash:: command not found
  81. pi@piaware:~ $ pi@piaware:~ $ allow-auto-updates yes # value set at /boot/piaware-config.txt:67
  82. -bash: pi@piaware:~: command not found
  83. pi@piaware:~ $ -bash: allow-auto-updates: command not found
  84. -bash: -bash:: command not found
  85. pi@piaware:~ $ pi@piaware:~ $ allow-manual-updates yes # value set at /boot/piaware-config.txt:71
  86. -bash: pi@piaware:~: command not found
  87. pi@piaware:~ $ -bash: allow-manual-updates: command not found
  88. -bash: -bash:: command not found
  89. pi@piaware:~ $ pi@piaware:~ $ allow-mlat yes # value set at /boot/piaware-config.txt:75
  90. -bash: pi@piaware:~: command not found
  91. pi@piaware:~ $ -bash: allow-mlat: command not found
  92. -bash: -bash:: command not found
  93. pi@piaware:~ $ pi@piaware:~ $ allow-modeac yes # value set at /boot/piaware-config.txt:79
  94. -bash: pi@piaware:~: command not found
  95. pi@piaware:~ $ -bash: allow-modeac: command not found
  96. -bash: -bash:: command not found
  97. pi@piaware:~ $ pi@piaware:~ $ feeder-id 7f8a6959-18dd-4458- a614-c55f346ddc7e # value set at /boot/piaware-config.txt:84
  98. -bash: pi@piaware:~: command not found
  99. pi@piaware:~ $ -bash: feeder-id: command not found
  100. -bash: -bash:: command not found
  101. pi@piaware:~ $ pi@piaware:~ $ image-type piaware # value set at /usr/share/piaware-support/piaware-image-config.txt:5
  102. -bash: pi@piaware:~: command not found
  103. pi@piaware:~ $ -bash: image-type: command not found
  104. -bash: -bash:: command not found
  105. pi@piaware:~ $ pi@piaware:~ $ manage-config yes # value set at /usr/share/piaware-support/piaware-image-config.txt:4
  106. -bash: pi@piaware:~: command not found
  107. pi@piaware:~ $ -bash: manage-config: command not found
  108. -bash: -bash:: command not found
  109. pi@piaware:~ $ pi@piaware:~ $ rtlsdr-gain max # value set at /boot/piaware-config.txt:60
  110. -bash: pi@piaware:~: command not found
  111. pi@piaware:~ $ -bash: rtlsdr-gain: command not found
  112. -bash: -bash:: command not found
  113. pi@piaware:~ $ pi@piaware:~ $ uat-receiver-type sdr # value set at /boot/piaware-config.txt:85
  114. -bash: pi@piaware:~: command not found
  115. pi@piaware:~ $ -bash: uat-receiver-type: command not found
  116. -bash: -bash:: command not found
  117. pi@piaware:~ $ pi@piaware:~ $ uat-sdr-device driver=rtlsdr,seria l=00000978 # value set at /boot/piaware-config.txt:86
  118. -bash: pi@piaware:~: command not found
  119. pi@piaware:~ $ -bash: uat-sdr-device: command not found
  120. -bash: -bash:: command not found
  121. pi@piaware:~ $ pi@piaware:~ $ wired-network yes # value set at /boot/piaware-config.txt:27
  122. -bash: pi@piaware:~: command not found
  123. pi@piaware:~ $ -bash: wired-network: command not found
  124. -bash: -bash:: command not found
  125. pi@piaware:~ $ pi@piaware:~ $ wireless-network yes # value set at /boot/piaware-config.txt:33
  126. -bash: pi@piaware:~: command not found
  127. pi@piaware:~ $ -bash: wireless-network: command not found
  128. -bash: -bash:: command not found
  129. pi@piaware:~ $ pi@piaware:~ $ wireless-password # value set at /boot/piaware-config.txt:49
  130. -bash: syntax error near unexpected token `newline’
  131. pi@piaware:~ $ -bash: syntax error near unexpected token `newline’
  132. pi@piaware:~ $ wireless-ssid MyWifiNetwork # value set at /boot/piaware-config.txt:48
pi@piaware:~ $ sudo systemctl stop piaware dump1090-fa dump978-fa
pi@piaware:~ $ sudo rtl_test
Found 1 device(s):
0: Realtek, RTL2832U, SN: 00000978
Detached kernel driver
[R82XX] PLL not locked!
Sampling at 2048000 S/s.
Info: This tool will continuously read from the device, and report if
samples get lost. If you observe no further output, everything is fine.
Reading samples in async mode…
Found 1 device(s):
RAW Paste Data
Found 1 device(s):
Found 1 device(s):
So you see, one of the dongles isn’t working anymore.
Hmm or maybe you need to specify a device with rtl_test?
sudo rtl_test -d 1
Anyway the output of
sudo piaware-config
Is the other interesting part of the puzzle.
Unplug both dongles, then after 30 seconds replug both dongles, and run the test:
rtl_test -t
I’m running this as a single dongle UAT978.
I added the 978 dongle but didn’t add the 1090 device. Seems you need to add both as it looks for both dongles.
Then you need to disable 1090 MHz reception.
sudo piaware-config uat-receiver-type sdr
sudo piaware-config receiver-type none
Piaware SD card image 3.7.1 Quickstart Guide
