Hi,
I am using an RPi3B with the FA pro stick Plus. I get pretty good reception from my garage but would like to improve it by moving my setup. Ideally I would like to use a USB extension cable.
I purchased this one: monoprice 32 ft 2 port active usb cable When I use it, I see a tremendous loss in range and aircraft counts. I even bought a power adapter for the extension end to eliminate power drop issues over the cable. (i also tested it on some other rtl-sdr’s on my pc and had the same sort of issues)
I agree. USB cables are the worst to extend.
Either move all the contraption away (Pi+dongle) and remotely fed it, or move just the antenna and use a long coax cable.
Personally I have moved the antenna, and used a preamp/filter at that end with power over the coax cable. To be cheaper, I have used RG6 cable with SMA-F adapters at each end.
@geckoVN
I am not the one who used it. I have quoted someone else from another forum. To see details, please click the two Click here in my above post.
I had success with a 5m passive USB extension cable with no discernible loss. That is only a 50% success rate.
I have had 100% success with PoE (Power over Ethernet) out of three installations. One of these was for power only with the data still communicated over Wi-Fi.
