Hi everyone- I recently moved my PiAware setup to a new location- unfortunately, it is in a slightly wooded area, so I get only about a 50 mile radius (open to thoughts on improving that as well, but that’s not the reason for the post). Looking at the logs, I noticed the receiver is having issues maintaining synchronization for MLAT. For example:
Sep 13 17:51:04 flightaware piaware[395]: mlat-client(468): Server status: synchronized with 249 nearby receivers
Sep 13 17:51:04 flightaware piaware[395]: mlat-client(468): Receiver: 16.5 msg/s received 6.5 msg/s processed (39%)
Sep 13 17:51:04 flightaware piaware[395]: mlat-client(468): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
Sep 13 17:51:04 flightaware piaware[395]: mlat-client(468): Results: 2.0 positions/minute
Sep 13 17:51:04 flightaware piaware[395]: mlat-client(468): Aircraft: 4 of 4 Mode S, 2 of 2 ADS-B used
Sep 13 17:55:54 flightaware piaware[395]: 19743 msgs recv'd from dump1090-fa (128 in last 5m); 19743 msgs sent to FlightAware
Sep 13 18:00:54 flightaware piaware[395]: 19861 msgs recv'd from dump1090-fa (118 in last 5m); 19861 msgs sent to FlightAware
Sep 13 18:05:54 flightaware piaware[395]: 20003 msgs recv'd from dump1090-fa (142 in last 5m); 20003 msgs sent to FlightAware
Sep 13 18:06:04 flightaware piaware[395]: mlat-client(468): Receiver status: connected
Sep 13 18:06:04 flightaware piaware[395]: mlat-client(468): Server status: synchronized with 197 nearby receivers
Sep 13 18:06:04 flightaware piaware[395]: mlat-client(468): Receiver: 15.0 msg/s received 5.4 msg/s processed (36%)
Sep 13 18:06:04 flightaware piaware[395]: mlat-client(468): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
Sep 13 18:06:05 flightaware piaware[395]: mlat-client(468): Results: 1.0 positions/minute
Sep 13 18:06:05 flightaware piaware[395]: mlat-client(468): Aircraft: 6 of 6 Mode S, 2 of 2 ADS-B used
Sep 13 18:10:54 flightaware piaware[395]: 20185 msgs recv'd from dump1090-fa (182 in last 5m); 20185 msgs sent to FlightAware
Sep 13 18:15:54 flightaware piaware[395]: 20250 msgs recv'd from dump1090-fa (65 in last 5m); 20250 msgs sent to FlightAware
Sep 13 18:20:54 flightaware piaware[395]: 20331 msgs recv'd from dump1090-fa (81 in last 5m); 20331 msgs sent to FlightAware
Sep 13 18:21:05 flightaware piaware[395]: mlat-client(468): Receiver status: connected
Sep 13 18:21:05 flightaware piaware[395]: mlat-client(468): Server status: not synchronized with any nearby receivers
Sep 13 18:21:05 flightaware piaware[395]: mlat-client(468): Receiver: 12.1 msg/s received 4.6 msg/s processed (38%)
Sep 13 18:21:05 flightaware piaware[395]: mlat-client(468): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
Sep 13 18:21:05 flightaware piaware[395]: mlat-client(468): Results: 2.7 positions/minute
Sep 13 18:21:05 flightaware piaware[395]: mlat-client(468): Aircraft: 3 of 3 Mode S, 3 of 3 ADS-B used
Sep 13 18:25:54 flightaware piaware[395]: 20506 msgs recv'd from dump1090-fa (175 in last 5m); 20506 msgs sent to FlightAware
Sep 13 18:30:54 flightaware piaware[395]: 20625 msgs recv'd from dump1090-fa (119 in last 5m); 20625 msgs sent to FlightAware
Sep 13 18:35:54 flightaware piaware[395]: 20683 msgs recv'd from dump1090-fa (58 in last 5m); 20683 msgs sent to FlightAware
Sep 13 18:36:05 flightaware piaware[395]: mlat-client(468): Receiver status: connected
Sep 13 18:36:05 flightaware piaware[395]: mlat-client(468): Server status: synchronized with 8 nearby receivers
Sep 13 18:36:05 flightaware piaware[395]: mlat-client(468): Receiver: 11.7 msg/s received 4.7 msg/s processed (40%)
Sep 13 18:36:05 flightaware piaware[395]: mlat-client(468): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.1kB/s UDP to server
Sep 13 18:36:05 flightaware piaware[395]: mlat-client(468): Results: 2.9 positions/minute
Sep 13 18:36:05 flightaware piaware[395]: mlat-client(468): Aircraft: 2 of 2 Mode S, 1 of 1 ADS-B used
Sep 13 18:40:54 flightaware piaware[395]: 20767 msgs recv'd from dump1090-fa (84 in last 5m); 20767 msgs sent to FlightAware
Sep 13 18:45:54 flightaware piaware[395]: 20865 msgs recv'd from dump1090-fa (98 in last 5m); 20865 msgs sent to FlightAware
Sep 13 18:50:54 flightaware piaware[395]: 20907 msgs recv'd from dump1090-fa (42 in last 5m); 20907 msgs sent to FlightAware
Sep 13 18:51:06 flightaware piaware[395]: mlat-client(468): Receiver status: connected
Sep 13 18:51:06 flightaware piaware[395]: mlat-client(468): Server status: not synchronized with any nearby receivers
Sep 13 18:51:06 flightaware piaware[395]: mlat-client(468): Receiver: 7.8 msg/s received 3.0 msg/s processed (39%)
Sep 13 18:51:06 flightaware piaware[395]: mlat-client(468): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.0kB/s UDP to server
Sep 13 18:51:06 flightaware piaware[395]: mlat-client(468): Results: 1.5 positions/minute
Sep 13 18:51:06 flightaware piaware[395]: mlat-client(468): Aircraft: 5 of 5 Mode S, 1 of 1 ADS-B used
It can go for hours at a time without being synchronized, but you can see here how it falls in and out of synch. While not that many, and maybe not related, I did also find a few
Sep 13 20:21:08 flightaware piaware[395]: mlat-client(468): Out-of-order timestamps: 1
lines as well, but they are in no way prevalent (somewhere around 5 instances a day), but I’m including that just in case there could be a relation. One last piece of info, I’ve run the gain at 12, 22db and 49db just to see if that affected anything, but it all seems pretty consistent across those values.
Is the MLAT desynch normal? Maybe I’m not seeing enough beacons with the limited line of sight? Any thoughts you can provide on that matter (or thoughts on how to boost reception in a forest
) would be much appreciated, thank you!
