Hello,
One week ago I installed my first Piaware with a Prostick Plus dongle on a PiZero. Everything worked fine for a week.
Yesterday I noticed (without making any change in my system, that MLAT was no longer working and reporting “Clock Unstable” or “MLAT disabled/not synked/Lat Long not configured”.
My coordinates are configured and precise (with a GPS) and were working for the first week. MLAT is enabled.
I just disconnected and reconnected everything and it worked for 2-3 minutes, even reporting a few positions, but went down again. ADSB is working fine, so I assume it’s not a USB/Dongle problem.
My location (Mexico City) does not have a lot of other stations.(9 within 10 miles according to my stats page, 6 of which show the green check under the MLAT column). Sometimes (very few) I’ve seen a message in the “not synchronized with any nearby receivers” in the log.
Any suggestions?
PD Here is my last hor log:
Sep 4 07:01:45 piaware piaware[525]: mlat-client(32356): Receiver status: connected
Sep 4 07:01:45 piaware piaware[525]: mlat-client(32356): Server status: clock unstable
Sep 4 07:01:45 piaware piaware[525]: mlat-client(32356): Receiver: 39.9 msg/s received 28.7 msg/s processed (72%)
Sep 4 07:01:45 piaware piaware[525]: mlat-client(32356): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
Sep 4 07:01:45 piaware piaware[525]: mlat-client(32356): Aircraft: 0 of 3 Mode S, 6 of 8 ADS-B used
Sep 4 07:05:09 piaware piaware[525]: 49464 msgs recv’d from dump1090-fa (332 in last 5m); 49464 msgs sent to FlightAware
Sep 4 07:10:09 piaware piaware[525]: 49866 msgs recv’d from dump1090-fa (402 in last 5m); 49866 msgs sent to FlightAware
Sep 4 07:15:09 piaware piaware[525]: 50198 msgs recv’d from dump1090-fa (332 in last 5m); 50198 msgs sent to FlightAware
Sep 4 07:16:46 piaware piaware[525]: mlat-client(32356): Receiver status: connected
Sep 4 07:16:46 piaware piaware[525]: mlat-client(32356): Server status: clock unstable
Sep 4 07:16:46 piaware piaware[525]: mlat-client(32356): Receiver: 45.5 msg/s received 32.8 msg/s processed (72%)
Sep 4 07:16:46 piaware piaware[525]: mlat-client(32356): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
Sep 4 07:16:46 piaware piaware[525]: mlat-client(32356): Aircraft: 1 of 1 Mode S, 4 of 12 ADS-B used
Sep 4 07:20:09 piaware piaware[525]: 50545 msgs recv’d from dump1090-fa (347 in last 5m); 50545 msgs sent to FlightAware
Sep 4 07:25:09 piaware piaware[525]: 50884 msgs recv’d from dump1090-fa (339 in last 5m); 50884 msgs sent to FlightAware
Sep 4 07:30:09 piaware piaware[525]: 51179 msgs recv’d from dump1090-fa (295 in last 5m); 51179 msgs sent to FlightAware
Sep 4 07:31:46 piaware piaware[525]: mlat-client(32356): Receiver status: connected
Sep 4 07:31:46 piaware piaware[525]: mlat-client(32356): Server status: clock unstable
Sep 4 07:31:46 piaware piaware[525]: mlat-client(32356): Receiver: 41.3 msg/s received 29.0 msg/s processed (70%)
Sep 4 07:31:46 piaware piaware[525]: mlat-client(32356): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
Sep 4 07:31:46 piaware piaware[525]: mlat-client(32356): Aircraft: 1 of 4 Mode S, 9 of 10 ADS-B used
Sep 4 07:35:09 piaware piaware[525]: 51461 msgs recv’d from dump1090-fa (282 in last 5m); 51461 msgs sent to FlightAware
Sep 4 07:40:09 piaware piaware[525]: 51731 msgs recv’d from dump1090-fa (270 in last 5m); 51731 msgs sent to FlightAware
Sep 4 07:42:47 piaware piaware[525]: NOTICE adept server is shutting down. reason: reconnection request received
Sep 4 07:42:49 piaware piaware[525]: Lost connection to adept server at piaware.flightaware.com/1200: server closed connection
Sep 4 07:42:49 piaware piaware[525]: multilateration data no longer required, disabling mlat client
Sep 4 07:42:50 piaware piaware[525]: fa-mlat-client exited normally
Sep 4 07:42:50 piaware piaware[525]: reconnecting in 5 seconds…
Sep 4 07:42:50 piaware piaware[525]: mlat-client(32356): Disconnecting from localhost:30005: Lost connection to multilateration server, no need for input data
Sep 4 07:42:50 piaware piaware[525]: mlat-client(32356): Exiting on connection loss
Sep 4 07:42:55 piaware piaware[525]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Sep 4 07:42:55 piaware piaware[525]: Connection with adept server at piaware.flightaware.com/1200 established
Sep 4 07:42:55 piaware piaware[525]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Sep 4 07:42:55 piaware piaware[525]: FlightAware server certificate validated
Sep 4 07:42:55 piaware piaware[525]: encrypted session established with FlightAware
Sep 4 07:42:58 piaware piaware[525]: logged in to FlightAware as user nospamprl
Sep 4 07:42:58 piaware piaware[525]: my feeder ID is 168b5d52-eacc-4f55-a9cf-a11261fb8094
Sep 4 07:42:58 piaware piaware[525]: site statistics URL: https://flightaware.com/adsb/stats/user/nospamprl#stats-134282
Sep 4 07:42:58 piaware piaware[525]: multilateration data requested
Sep 4 07:42:59 piaware piaware[525]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 70.42.6.198:18011:3988778853
Sep 4 07:43:02 piaware piaware[525]: mlat-client(24314): fa-mlat-client 0.2.11 starting up
Sep 4 07:43:02 piaware piaware[525]: mlat-client(24314): Using UDP transport to 70.42.6.198 port 18011
Sep 4 07:43:02 piaware piaware[525]: mlat-client(24314): Listening for Beast-format results connection on port 30105
Sep 4 07:43:02 piaware piaware[525]: mlat-client(24314): Listening for Extended Basestation-format results connection on port 30106
Sep 4 07:43:02 piaware piaware[525]: mlat-client(24314): Route MTU changed to 1500
Sep 4 07:43:02 piaware piaware[525]: mlat-client(24314): Input connected to localhost:30005
Sep 4 07:43:02 piaware piaware[525]: mlat-client(24314): Input format changed to BEAST, 12MHz clock
Sep 4 07:43:03 piaware piaware[525]: mlat-client(24314): Beast-format results connection with ::1:30104: connection established
Sep 4 07:45:09 piaware piaware[525]: 52012 msgs recv’d from dump1090-fa (281 in last 5m); 52006 msgs sent to FlightAware
Sep 4 07:50:09 piaware piaware[525]: 52329 msgs recv’d from dump1090-fa (317 in last 5m); 52323 msgs sent to FlightAware
Sep 4 07:55:09 piaware piaware[525]: 52697 msgs recv’d from dump1090-fa (368 in last 5m); 52691 msgs sent to FlightAware
Sep 4 08:04:18 piaware piaware[557]: creating pidfile /run/piaware/piaware.pid
Sep 4 08:04:18 piaware piaware[557]: ****************************************************
Sep 4 08:04:18 piaware piaware[557]: piaware version 3.8.1 is running, process ID 557
Sep 4 08:04:18 piaware piaware[557]: your system info is: Linux piaware 5.4.51+ #1333 Mon Aug 10 16:38:02 BST 2020 armv6l GNU/Linux
Sep 4 08:04:20 piaware piaware[557]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Sep 4 08:04:20 piaware piaware[557]: Connection with adept server at piaware.flightaware.com/1200 established
Sep 4 08:04:20 piaware piaware[557]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Sep 4 08:04:23 piaware piaware[557]: FlightAware server certificate validated
Sep 4 08:04:23 piaware piaware[557]: encrypted session established with FlightAware
Sep 4 08:04:27 piaware piaware[557]: ADS-B data program ‘dump1090-fa’ is listening on port 30005, so far so good
Sep 4 08:04:27 piaware piaware[557]: Starting faup1090: /usr/lib/piaware/helpers/faup1090 --net-bo-ipaddr localhost --net-bo-port 30005 --stdout --lat 19.421 --lon -99.234
Sep 4 08:04:27 piaware piaware[557]: Started faup1090 (pid 732) to connect to dump1090-fa
Sep 4 08:04:27 piaware piaware[557]: UAT support disabled by local configuration setting: uat-receiver-type
Sep 4 08:04:28 piaware piaware[557]: adept reported location: 19.42072, -99.23367, 7764ft AMSL
Sep 4 08:04:28 piaware piaware[557]: logged in to FlightAware as user nospamprl
Sep 4 08:04:28 piaware piaware[557]: my feeder ID is 168b5d52-eacc-4f55-a9cf-a11261fb8094
Sep 4 08:04:28 piaware piaware[557]: site statistics URL: https://flightaware.com/adsb/stats/user/nospamprl#stats-134282
Sep 4 08:04:28 piaware piaware[557]: multilateration data requested
Sep 4 08:04:28 piaware piaware[557]: Starting multilateration client: /usr/lib/piaware/helpers/fa-mlat-client --input-connect localhost:30005 --input-type dump1090 --results beast,connect,localhost:30104 --results beast,listen,30105 --results ext_basestation,listen,30106 --udp-transport 70.42.6.232:10006:4229442807
Sep 4 08:04:29 piaware piaware[557]: piaware received a message from dump1090-fa!
Sep 4 08:04:29 piaware piaware[557]: piaware has successfully sent several msgs to FlightAware!
Sep 4 08:04:32 piaware piaware[557]: mlat-client(742): fa-mlat-client 0.2.11 starting up
Sep 4 08:04:32 piaware piaware[557]: mlat-client(742): Using UDP transport to 70.42.6.232 port 10006
Sep 4 08:04:32 piaware piaware[557]: mlat-client(742): Listening for Beast-format results connection on port 30105
Sep 4 08:04:32 piaware piaware[557]: mlat-client(742): Listening for Extended Basestation-format results connection on port 30106
Sep 4 08:04:32 piaware piaware[557]: mlat-client(742): Route MTU changed to 1500
Sep 4 08:04:32 piaware piaware[557]: mlat-client(742): Input connected to localhost:30005
Sep 4 08:04:32 piaware piaware[557]: mlat-client(742): Input format changed to BEAST, 12MHz clock
Sep 4 08:04:32 piaware piaware[557]: mlat-client(742): Beast-format results connection with ::1:30104: connection established
Sep 4 08:04:57 piaware piaware[557]: 57 msgs recv’d from dump1090-fa; 57 msgs sent to FlightAware
Sep 4 08:09:57 piaware piaware[557]: 472 msgs recv’d from dump1090-fa (415 in last 5m); 472 msgs sent to FlightAware
Sep 4 08:14:57 piaware piaware[557]: 825 msgs recv’d from dump1090-fa (353 in last 5m); 825 msgs sent to FlightAware
Sep 4 08:19:32 piaware piaware[557]: mlat-client(742): Receiver status: connected
Sep 4 08:19:32 piaware piaware[557]: mlat-client(742): Server status: clock unstable
Sep 4 08:19:32 piaware piaware[557]: mlat-client(742): Receiver: 48.9 msg/s received 33.3 msg/s processed (68%)
Sep 4 08:19:32 piaware piaware[557]: mlat-client(742): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
Sep 4 08:19:32 piaware piaware[557]: mlat-client(742): Results: 0.7 positions/minute
Sep 4 08:19:32 piaware piaware[557]: mlat-client(742): Aircraft: 0 of 5 Mode S, 8 of 13 ADS-B used
Sep 4 08:19:57 piaware piaware[557]: 1228 msgs recv’d from dump1090-fa (403 in last 5m); 1228 msgs sent to FlightAware
Sep 4 08:24:57 piaware piaware[557]: 1706 msgs recv’d from dump1090-fa (478 in last 5m); 1706 msgs sent to FlightAware
Sep 4 08:29:57 piaware piaware[557]: 2173 msgs recv’d from dump1090-fa (467 in last 5m); 2173 msgs sent to FlightAware
