I have a headless Zero feeding data to Flightaware and FR24 and previously adsbX. My system also has Pi-Hole running.
Checking Pi-Hole today I noticed my Zero was sending data to adsbX that I thought I had cancelled. There is no security issue with this, the cancellation was due to a program setup problem I was experiencing but I am now curious,
MRTG or PRTG are good network traffic analyzers that use SNMP. Both are no cost for small networks. If you don’t want to upload to adsbX the easiest method is to block them in your router.
Or it could be that they are actually in /home instead of being in “his home directory” … notice the difference.
Anyhow those old scripts were usually started from /etc/rc.local, if you delete the according lines from there and reboot it should no longer start them.
The current adsbexchange feed scripts and are thus a bit more easy to disable. Also for convenience there is an uninstall included.
Paradoxically to get rid of the old scripts being started you’d have to install then uninstall the new scripts because the installer actually wants to make sure no old scripts are running.
Damn, why didn’t I think of that. Yes, both those scripts are in the /home directory and not the default home directory of /home/pi
So, looks like data is being submitted then. There used to be a ‘custom port’ option on the web page that enabled contributors of data to see their own data on a map but cannot find that.
