Unable to Feed
I have been able to feed to FA for several years without issue. As of 2 days ago the feed stopped. I had no issues running the feed for 570 days. I thought that either the Pi went down or the ProStick. I changed out the both the Pi and the ProStick with new ones. Same issue. No feed, but FA sees the Pi w 7.2 installed. I guess the last resort would be to flash the miniSD card or try a new miniSD card. Although I would presume I would not be able to see the 7.2 image on my monitor if the miniSD was the issue.
Any ideas?
Try a new PSU.
I’ve currently got a site showing the same symptoms - connected to FA (most of the time), but not receiving/sending any data. (it is regularly reporting low voltage)
Indeed. After rethinking everything I felt the power supply and found it hot and smelled burnt. I went to the trusty box of goodies (the one that your wife wants to throw out) and found a new power supply. Refreshed the feed and it is now working fine.
No question is a bad one. Now someone else can find this and solve their PSU issue as well.
Good result!
Not only is it a common problem, it’s really easy to test / fix.
btw, welcome!
