I got my pi setup with a small desktop antenna. I get probably 40nm range with it. This is with the blend FA USB stick.
I wantt to plan on a chimney mounted option to get it high. I found a combo antenna from adbsechange. Looks like I could use that, use an sma splitter and then use my blue stick plus an orange stick to get ads plus uat.
Anybody try this combo? It would cut down on antennas, wire, etc.
I would suggest a proper power splitter/combiner with decent isolation, not just a dumb splitter like you linked. The dongles are noisy and will interfere with each other without isolation.
I’m not gonna disagree with you, a proper splitter is better.
But it works remarkably well in quite a few installations i’ve seen.
I’d attribute it to the FA sticks being not that noisy because they have the LNA as the first component?
Just a guess.
Better splitters cost quite a few dollars …
1090 range of 200 nmi is no issue with this combo if the terrain isn’t in the way.
Depending on location and interference, placing the FA filter before the splitter can help if you’re having reduced reception due to interference.
As the filter isn’t too expensive, it’s a good thing to try if the reception isn’t as good as expected.
