Folks,
If I have two different PiAware sites in different Countries how will that show up on MyADSB?
Geffers
Folks,
Geffers
I see only one under send2gl.
There is a drop down menu that allows you to choose which one you want to view.
I have 5 and can choose which one I want to view.
Thanks for prompt reply, haven’t set 2nd one up yet.
Currently have my original device with me on holiday, may leave it here in US and set up new device in UK.
Geffers.
What actually differentiates them? Do they have a different Unique Identifier?
Assuming it can’t be the MAC address as one can switch SD cards to a different Pi
Geffers
Yes, it is the Unique Identifier which is saved in piaware config in microSD card. That is why if you remove the card from one Pi and slip into another PI you will still get the same station number.
Each site has its own Unique Identifier, which is shown on flightaware stats page.
You can check Unique Identifier saved in microSD card by following command
sudo piaware-config -show feeder-id
To save a Unique identifier in piaware config
sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxx-xxxxxxxxxx
(Replace xxxxxxxx-xxxx-xxxx-xxxx-xxxx-xxxxxxxxxx by actual Unique Identifier of the station copied from the Flightaware stats site)
