This script should be run on a freshly written Raspbian Buster or Stretch image.
The script first installs piaware and dump1090-fa.
Next it creates files needed to run 2nd instance of piaware and dump1090-fa
(1) Serialize dongles as follows
Plug-in both dongles and give following commands:
1 - Reboot Pi 2. Add piaware feeder-id for 2 stations
As at the first run, the piaware and piaware2 did not find any feeder-id, they acquired brand-new feeder-ids from Flightaware servers and stored in their cache. You can read these by following commands:
If you have feeder-id for 1st station, but dont have for 2nd station
. 1st Station: sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
(replace xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx by actual feeder id of 1st feeder)
. sudo systemctl restart piaware
. 2nd Station:
Go to Flightaware Claim page and claim your new Station 2 https://flightaware.com/adsb/piaware/claim
If you already have both feeder-ids
. 1st station: sudo piaware-config feeder-id xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx sudo systemctl restart piaware
. 2nd station: sudo nano /etc/piaware2.conf
Copy-paste following line at the end feeder-id yyyyyyyy-yyyy-yyyy-yyyy-yyyyyyyyyyyy
(replace yyyyyyyy-yyyy-yyyy-yyyy-yyyyyyyyyyyy by actual feeder id of 2nd feeder)
Save file (Ctrl+o) and close file (Ctrl+x)
. sudo systemctl restart piaware2
Checks
To see two skyview maps, go to following address:
IP-of-Pi/dump1090-fa/
IP-of-Pi/dump1090-fa2/
To check Status sudo systemctl status dump1090-fa sudo systemctl status dump1090-fa2
sudo systemctl status piaware sudo systemctl status piaware2
To Restart sudo systemctl restart dump1090-fa sudo systemctl restart dump1090-fa2
AUTOMATED INSTALL BY BASH SCRIPT (dump1090-mutability ver 1.15~dev)
This script:
(1) Builds (from source code) and installs dump1090-mutability ver 1.15~dev
(2) Installs piaware data feeder (package from Flightaware)
(3) Creates files needed to run 2nd instances of dump1090-mutability and piaware.
. STEPS: (1) Serialize dongles as follows
. 2nd Station:
Checks
IP-of-Pi/dump1090/
IP-of-Pi/dump1090-2/
To check Status sudo systemctl status dump1090-mutability sudo systemctl status dump1090-mutability2
To Restart sudo systemctl restart dump1090-mutability sudo systemctl restart dump1090-mutability2
@wiedehopf
I have one set of graphs running for the 1st instance of dump1090 (fa or mutab).
How to run 2nd set of graphs for the 2nd instance of dump1090 (fa or mutab)?
This is a setup where each dongle will be linked with a unique feeder ID. Wat about combining a high gain receiver and a low gain receiver (no dropouts at short range) into just 1 feed (like VRS does), is that also possible or would it be better to wait for a FA-compatible receiver with a wider dynamic range?
Can this script be used after flashing a card with your handy script that installs and sets up multiple feeders on a single RPi? The script is a phenomenal time saver for a noob.
If you mean real manual, then download these files in your Pi, and issue the commands contained in these files manually in the same sequence as in the files:
2 x dump1090-fa wget https://raw.githubusercontent.com/abcd567a/two-receivers/master/2-receivers-dump-fa.sh
. 2 x dump1090-mutability wget https://raw.githubusercontent.com/abcd567a/two-receivers/master/2-receivers-dump-mutab.sh
I noticed that Radarcape has a dual antenna (diversity) receiver, I guess that this (pricey) device can have 2 antenna’s and still use MLAT? Maybe it even outperforms the FA-dongle with 1 antenna if it has a higher dynamic range…
A radarcape is a great device. I have one. It GPS timestamps the signals within the FPGA.
It is maybe 1-5% better than a good FA dongle setup for most locations. It is much better in busy locations as it can decode overlapping signals.
Now that the RPI4 is out(Better ethernet, USB and CPU), an Airspy is the next best thing(unless you want a completely stand alone package that just requires power, ethernet and an antenna connection(actually two, one for the GPS and one for 1090Mhz).
Radarcape and the ModeS Beast it’s based on both outperform the FA or any other rtl-sdr dongles.
The Airspy is close to their performance as far as i know.
And yes you can use multiple antennas with that device and still have MLAT.
