The graphs you are after come with Joe Prochazka’s dump1090-mutability.
for an easy setup follow the steps at
this by user @abcd567
HTH
HTH
Thanks for posting the FR24 forum link, but it is for installing dump1090-mutability ver 1.15~dev.
The link for Performance Graph installation is:
Automated Installation of Dump1090-Mutability, Data Feeders, and Performance Graphs.
Ok. I decided to use ADSB Receiver Project git clone method and it worked! Thanks.
Initially Ayadex has started Performance Graphs project, but after a while he stopped its further development. Then Joe Prochazka started “ADS-B Receiver Project” which included not only Performance Graphs, but optional items for installation of decoders and feeders as well.
If you want only performance graphs, run Joe’s script, say NO to all options, till you see option for “Web Portal”. Say OK to it and it will be installed. The “Web Portal” is actually the performance graphs & monitors you want to install.
EDIT:
While I was typing, you posted that you already installed it
Yes… this is the best option and it worked… thanks alot… http://rodyeo.dyndns.org/
Ok. Nice… will do that… raspimonitor… thanks…
you know I was sure was on this site too. checked your ‘tweaks’ but could not find it.
I am sure I 've seen it here somewhere… (last year before he forum change maybe ?)
can’t use easily the current ‘search feature’.
The “Performance Graphs” was never posted by me in FlightAware forums as J Prochazka’s “ADSB Receiver Project” thread is already in place here.
I think you got it mixed up with the manual install of dump1090-mutability ver 1.15~dev which I have posted in this forum. This is not in Tweaks thread. It is in thread Bake a Pi >> OPTION-3.
However I have posted Joe Prochazka’s script in FlightRadar24 and PlaneFinder forums so that members there can also benefit from Joe Prochazka’s work.
yes ! bake-a-pi that’s what I had in mind…
I’m wondering why i’m receiving so many messages per plane (at least at night):
I guess when it’s busier the stronger message win out so less messages/s per plane on average?
Not unusal, I guess. It is the same here.
Edit: Here meaning Germany, relatively close to an international airport, EDDL.
How about this one?
Definitely different.
I guess it depends, apart from other things, on how close you are to an airport and which restrictions are put on nightime flights.
Toronto hasn’t that many international flight crossing over top does it huh?
Also seems aircraft send fewer messages. I guess it’s all the extra crap interrogation with extended squitter and the like going on.
ADS-B extended squitter itself has a specification-mandated limit of 6.2 messages/second/aircraft (and typically is less than that). The rest will be Mode S responses, acquisition squitter, and TCAS. Europe has an extremely high SSR interrogation rate which probably explains the difference.
Ive installed system monitoring using JP’s script on dump1090-mutability v 1.15 on stretch. However, 4 of the graphs don’t show up. On clicking the graph’s name I am sent to a “not found” page. The graphs I am missing are: Message Rate (trailing), Signal Level, Message Rate and Aircraft Message Rate. What could I be missing? Dump1090 is running in net-only mode.
(1) Give this command
sudo ~/adsb-receiver/build/portal/graphs/make-collectd-graphs.sh 24h
(2) Open graphs page, clear browser cache (Ctrl+Shift+Delete), then Reload (Ctrl+F5)
(Ctrl+F5 reminds me @Dxista )
@abcd567
Ran this…no luck. Got 4 errors:
The -10 and now the CTRL+F5 guy.
