Aircraft Seen and Reports Received are increasing as normal, but no flights are being displayed, only the message 'no flights found".
Maybe a server issue ?
Not sure – but when I check the log via my statistics page, it gives the following error:
Sorry, the log appears to be empty at the moment. Please try again later.
So maybe something’s wonky on their end.
FlightAware Support here.
Do you see the Dump1090 map and aircraft list when you select “View Live Data”?
I run two Piaware setups
One uses Ip 192.168.1.83:8080. It will not load (did at onetime but always hit and miss)
Others uses 192.168.1.84:8080 works 100% of the time
Both use same network for Internet connection
Any ideas ?
