starttime and startdate difference, AirlineFlightSchedules()
Please.
using the AirlineFlightSchedules() method
Another worry, please, **whats the diff btn the startdate and enddate. **
I have read the documentation but not seem to understand clearly.
**Which should be greater than the other? **
And also, i get error that start date is too far from the past. want to get flight info as far as 2005.
Isn’t is possible with this API?
For example, i have only this information set.
TCX2995
departed 06/10/2014
I know that
flightno = 2995 and airline = TCX .
What values does the stardate and enddate take.
Am using php, soap.
Convert my time to epoch like this
$d = new DateTIme('06/10/2014');
$epochTim = $d->format('U');
Am not a travelling type, just a programmer and will really appreciate help as explainatory as possible.
I get this error
[faultstring] => startDate is too far in the past (3 months)
Can’t i search flights far in the past, as far as 2005? if not, whats the min date i can search flight info
AirlineFlightSchedules only allows searching of flight schedules 3 months in the past and 12 months in the future.
Picking up this thread again …
I’m trying to use your AirlineFlightSchedules API. The documentation says the date range available is 3-months-prior until 1-year-out (or presumably, as far as out is published through OAG/Innovata). However I’m getting a result of -1 even when querying for a time range even just three or four weeks ago.
Hi,
Are you still having problems retrieving past schedules?
It could be that you were asking for a flight that did not have any schedules in the time interval you wanted.
My query here does retrieve schedules for TCX:
https://flightxml.flightaware.com/json/FlightXML2/AirlineFlightSchedules?airline=TCX&startDate=1451606400&endDate=1453248000&howMany=100
Notice this is for past schedules between 1451606400 = Fri, 01 Jan 2016 00:00:00 UTC and 1453248000 = Wed, 20 Jan 2016 00:00:00 GMT.
startDate and endDate have to be epoch seconds since 1970
You can also search for a specific flight number using flightno :
https://flightxml.flightaware.com/json/FlightXML2/AirlineFlightSchedules?airline=TCX&flightno=2229&startDate=1451606400&endDate=1453248000&howMany=50
