Hello,
I have two stations on version 9.0 that are working as expected.
Logs and stats are displayed for both stations.
However, only one of the two stations flight data shows on the SkyAware Anywhere map. When I login locally on the stations’ dashboard, the planes are shown. What can be the problem?
I rebooted the devices and restarted the piaware service.
Are both stations connected to the same user account ?
Yes they under the same user account (kyis777).
Could it be possible that they receive the same amount of aircraft ?
Are these setups in the same location?
You could try this instead of skyaware anywhere, it will show you the data that you receive, Skyaware anywhere is generated from the FA server towards you, Mixer shows you the data prior to sending it to FA. I have it running and it shows more aircraft when compared to the Skyaware Anywhere page.
@tomvdhorst, to answer your questions the receivers are in different locations and the receivers have some overlap on the aircrafts captured. However, one of them captures more planes to the west. I installed the mixer on both Pis.
The difference in location can be a parameter why you are receiving more (or less) aircraft on a particular setup.
Did you also install Graphs1090 ?
That can tell you more about the behavior of your systems.
