Ive had 2 receivers working off a splitter on my 1090 antenna for… 6 months or so.
yesterday I got a notice there was no data coming on 30005. Checked status and both receivers were down. So I rebooted. nothing
rtl_test -t no receivers. weird. unplugged everything and rebooted. finally I was able to plug in 1 receiver and get dump1090-fa /piaware working. whew, streak saved!
but since then Im unable to get my other receiver working.
Status output:
● dump1090-fa2.service - dump1090 ADS-B receiver (FlightAware customization)
Loaded: loaded (/lib/systemd/system/dump1090-fa2.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Mon 2023-07-17 12:25:49 EDT; 2s ago
Process: 8181 ExecStart=/usr/share/dump1090-fa/start-dump1090-fa2 --write-json /run/dump1090-fa2 --quiet (code=exited, status=1/FAILURE)
Main PID: 8181 (code=exited, status=1/FAILURE)
Jul 17 12:25:49 raspberrypi systemd[1]: dump1090-fa2.service: Unit entered failed state.
Jul 17 12:25:49 raspberrypi systemd[1]: dump1090-fa2.service: Failed with result ‘exit-code’.
rte_test :
0: Realtek, RTL2832U, SN: 00010902
1: Realtek, RTL2832U, SN: 00010908
/etc/default/dump1090-fa2
dump1090-fa2 won’t automatically start unless ENABLED=yes
ENABLED=yes
RECEIVER_OPTIONS2=“–device-index 00010902 --gain 48 --ppm 0 --net-bo-port 31005”
DECODER_OPTIONS2=“–max-range 360”
NET_OPTIONS2=“–net --net-heartbeat 60 --net-ro-size 1000 --net-ro-interval 1 --net-ri-port 0 --net-ro-port 31002 --net-sbs-port 31003 --net-bi-port 31004,31104 --net-bo-port 31005”
JSON_OPTIONS2=“–json-location-accuracy 1”
dump1090-fa: status
Active: active (running) since Mon 2023-07-17 12:28:51 EDT; 7s ago
Main PID: 10614 (dump1090-fa)
Tasks: 3 (limit: 4915)
└─10614 /usr/bin/dump1090-fa --quiet --device-type rtlsdr --device-index 00010908 --gain 20.7 --adaptive-range-target 48 --lat 40.73875 --lon -74.45491 --max-range 360 --net-ro-port 30002 --net-sbs-port 30003 --net-bi-port 30004,30104 --net-bo-port 30005 --json-location-accuracy
any ideas or tests I can run?
I checked both receivers on a 2nd PI running piaware and both run without issue so hardware is ok.
