I know this error is something that comes up a lot, and I have searched here, and Google, but I’m just getting no luck.
I’m on an Orange Pi (Regretting not getting another RPi), running Ubuntu 16.04. I have PiAware setup, and it’s communicated with FA, but I get the RTL driver issue;
Kernel driver is active, or device is claimed by second instance of librtlsdr.
In the first case, please either detach or blacklist the kernel module
(dvb_usb_rtl28xxu), or enable automatic detaching at compile time.
usb_claim_interface error -6
I have attempted to blacklist the drivers in /etc/modprobe.d/blacklist.conf to no avail, and I have followed another guide which rebuilds adding a flag of; -DDETACH_KERNEL_DRIVER=ON -DINSTA LL_UDEV_RULES=ON
This also hasn’t helped.
Is anyone able to help? I’ve been trying to get this myself for the past few hours, and I’m stuck now.
Note sure if this helps:
root@orangepipcplus:~# lsmod
Module Size Used by
dvb_usb_rtl2832u 351091 0
bmp085 3487 0
pcf8591 3363 0
dvb_usb 15734 1 dvb_usb_rtl2832u
dvb_core 68509 1 dvb_usb
rc_core 12727 1 dvb_usb
8189fs 1050451 0
btrfs 712409 0
#open file rtl-sdr-blacklist.conf for editing
sudo nano /etc/modprobe.d/rtl-sdr-blacklist.conf
#add the following 2 lines to above file:
blacklist dvb_usb_rtl2832u
blacklist dvb_usb
#save file, exit and reboot
sudo reboot
Ahhh, I’m an idiot. I just realised when I came back here that I didn’t have “dvb_usb_rtl2832u” anywhere.
I’m not seeing a funy issue (I’m not near the feeder, so it may not be an issue)
But I have;PiAware and MLAT showing green, but FlightAware coming up as red saying the Pi hasn’t checked in recently. This is odd to me as it all seems good.
Piaware has a log that can be viewed with
cat /var/log/piaware.log
If you can ping piaware.flightaware.com then piaware should be able to make the connection to flightaware.
