RTL 1090 indoor antenna - Optimum length
Hi,
How about the best length for an indoor antenna ?
50mm, 100mm, 300mm or anything else ?
For 1090 MHz:
From feed point (i.e. point where coax connects to antenna) to tip of antenna
= 1/4 wavelength = 67mm
(1) WHIP CUT TO 52mm
(2) USING COOKIE CAN AS GROUND PLANE
Do not want to cut the whip? No problem, replace whip by THIN steel or copper wire as shown below:
(1) WHIP REPLACED BY 52mm STEEL TIE WIRE
(2) USING FOOD CAN AS GROUND PLANE
HI, @abcd567
I’m going to whip cut and see if I got some extra gain.
Thanks a lot
PS: Very interesting the cookie and food can as bases for the antenna.
Using steel/iron base plate gives two advantages
  1. The base of of whip does provide the essential part of antenna, i.e. ground-plane, but it is too small (one inch dia), and is grossly insufficient. The metallic cookie can or food-can sufficiently enlarges this ground plane and improves performance substantially compared to if the antenna is placed on wooden or other non-metallic surface.
  2. The magnetic base clings to steel/iron plate, keeping whip vertical and prevents it from falling.
Better do NOT cut the supplied whip.
First try without cutting whip. Just place antenna over a metallic can. This alone will give substantial improvement.
Next, keeping base on metallic food-can, un-screw the whip, and use a thin wire as whip. You can use a wire longer than 52mm (say 70mm) and trim in steps of say 3mm and observe message rate/plane count/max range for say 10 minutes after each trimming. Continue till you reach 52mm.
I’ve tried with a spare whip, used for tv and, indeed more planes showed. Later on I’ll make a trial with a metalic base.
the little antenna with replaced whip by a wire was my first antenna.
And it performed surprisingly well.
Indeed! I’m having best results, compared to the 170mm antenna that comes with the Flightaware blue dongle.
That’s a generic antenna. Can work, but not with the optimum
