I have setup a Raspberry Pi3 with a FA Pro Stick, FA ADS-B filter and the FA 1090Mhz antenna. I installed PIAware and setup my FlightAware feed and then added my FlightRadar24 feed after. The issue I am having is that my feeds keep losing connection, they could be live for 12-18 hours and then drop, I then have to pull the plug and reboot. My Wi-Fi is strong and has no issues.
I also notice that the red power LED goes out once that it has rebooted even though the feeds are live, I thought the red led should remain on?
The LEDs are software-controllable but in the default configuration the red LED is driven by a voltage monitor that monitors the 5V line.
If the red LED is off (or blinks off), you have power problems - the 5V line has dropped below the monitor’s trigger level (I can’t remember exactly what the trigger level is, 4.something…)
The power supply is a PiHut psu but it is only 2amp and not 2.5amps. I have another psu on order that should be delivered tomorrow so I’ll see how that goes.
New power supply arrived yesterday, the power light remains constantly red but I still have the same issue. The system ran from 5pm yesterday and went offline at 8am this morning
this issue has been happening to me too and the problem is that the makers of piaware software have a bug in there with the pi 3 that needs to be ironed out.
I went through all the scenarios with power supply not being enough so I got a 5 volt 5 amp supply and same problem
I changed dongles from the pro stick to a regular dongle and same problem
yet i put the pro stick on a pi 2 using the latest software and it runs forever …
So you’re saying that you ran identical software on two different bits of hardwre, and only one of them had problems, and therefore the problem must be in the software?
Umm…
That said, if you want to send me a detailed bug report I can certainly take a look, but so far I have nothing concrete to go on. My own Pi 3 has been running for a couple of months with no issues: flightaware.com/adsb/stats/user/obj#stats-20523
It should remain on. I bought 2 new Pi3’s and set them both up, neither one had a red light lit but they were still mostly working, so I switched them to a better power source (an Anker phone charger seems to do fairly ok but I don’t plan on this being a long term solution as I still see the red LED go off once in a while)
I decided to put a power meter on it and see how much power it’s pulling.
The entire set up (Pi 3, SD card, ethernet active (bt and wifi not touched from the FA stock image file) with PiAware running is pulling just under 900mA
The RTL-SDR dongle alone is pulling about 500mA
I don’t have one handy (I may be able to borrow one from a friend tomorrow) but I believe the Pi 2 operating current is a decent amount lower.
