Raspberry Pi dump1090 interactive terminal renewal
With an instance of dump1090 already running on a raspberry pi, how do you startup an interactive terminal session to view the flight data without restarting dump1090?
I’ve been re running dump1090 --interactive to get this, but I assume when doing this I am creating another running instance of dump1090. There must me a more efficient way to do this.
I’m viewing the terminal sessions via Putty on a PC.
Thanks in advance.
You can use view1090, which will connect to the already running dump1090 and give a similar output. I don’t know if it’s installed by default with the .deb release as I built dump1090 from git.
If you are connecting via a PC, you might as well use view1090.exe to connect directly.
Go here and search for “view1090.exe” to find the relevant section.
satsignal.eu/raspberry-pi/dump1090.html
