hi my blue prostick worked ok till recently
now it appears is not producing data.
tested the antenna was connected to with another receiver and no problems there.
the quoted messages below show current status.
any ideas please ? thx on adv, Evangel
Blockquote
root@debian:/home/deb# piaware-status
PiAware master process (piaware) is running with pid 7599.
PiAware ADS-B client (faup1090) is not running.
PiAware ADS-B UAT client (faup978) is not running.
Local ADS-B receiver (dump1090-fa) is running with pid 9198.
dump1090-fa (pid 9198) is listening for connections on port 30005.
no program appears to be listening for connections on port 30978.
faup978 is NOT connected to the ADS-B UAT receiver.
got ‘couldn’t open socket: connection refused’
^C
root@debian:/home/deb# killall dump1090-fa
root@debian:/home/deb# rtl_test -t
Found 1 device(s):
0: Realtek, RTL2832U, SN: 00001000
Sampling at 2048000 S/s.
==== MANUAL RUN ====
root@debian:/home/deb# dump1090-fa --gain 38.6 --net
Sun Jul 19 07:17:41 2020 EDT dump1090-fa 3.7.1 starting up.
rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 00001000)
rtlsdr: tuner gain set to 38.6 dB
=== THEN VIA SERVICE ====
root@debian:/home/deb# systemctl status dump1090-fa.service
Active: active (running) since Sun 2020-07-19 07:30:37 EDT; 30s ago
Main PID: 12239 (dump1090-fa)
Tasks: 3 (limit: 1138)
Memory: 5.0M
└─12239 /usr/bin/dump1090-fa --device-index 0 --gain 42.1 --ppm 62 --fix --dcfilter --net-bo-port 30005 --max-range 360 --net --net-heartbeat 60 --net-ro-size 1000 --net-ro-interval 1 --n
Jul 19 07:30:37 debian systemd[1]: Started dump1090 ADS-B receiver (FlightAware customization).
Jul 19 07:30:37 debian dump1090-fa[12239]: Sun Jul 19 07:30:37 2020 EDT dump1090-fa 3.7.1 starting up.
Jul 19 07:30:37 debian dump1090-fa[12239]: rtlsdr: using device #0: Generic RTL2832U (Realtek, RTL2832U, SN 00001000)
Jul 19 07:30:38 debian dump1090-fa[12239]: Found Rafael Micro R820T tuner
Jul 19 07:30:40 debian dump1090-fa[12239]: rtlsdr: tuner gain set to 42.1 dB
lines 1-15/15 (END)
Blockquote
