As I am mainly interested in military flights (I don’t think FlightAware tracks military flights does it?) I started by installing the ADBS Exchange image on a Raspberry Pi - it has been running for a few days now with no problem.
I have now added PiAware via the command line as a second feed. All seem fine until I try to access local date via the http://raspberry-pi-local-ip:8080
I get a server not found. I know ADSB Exchange uses port 80 and port 3000 for its local data.
Is there any way to access the FlightAware local data??
The local interface presented by dump1090-fa can’t be installed standalone and you shouldn’t try to replace the existing decoder. (which installing dump1090-fa would do)
But tar1090 is not too dissimilar from the dump1090-fa interface so not sure you really need it … some might even say tar1090 is nicer
In regards to MLAT by default you will see adsbexhange and FA MLAT results in your local interface.
