PlanePlotter connection to PiAware
Hi, How do I setup Planeplotter on my PC (192.168.1.51) to get the data from my PiAware (192.168.1.86 port 8080)?
Thanks,
In PP, select options/Input Output
Check Mode S/ADSB and select RTL>Rpi+dump1090
allow auto mlats
allow raw data fro mlats
Check udp/ip from net
UDP/IP local port 9742
In PP select options/Mode S Receiver
Select RTL dongle Rpi dump1090 and configure client 192.168.1.86:30005
At least that is how mine is set up as a PP ground station - I took your IP address from your note. If you are going to be a ground station you will need to enable port forwarding on your router for port 9742 to forward to 192.168.1.51
Good luck
Wow, Thanks you, I am not sure I would have find at out by trial and errors. I’ll gave you a feedback as soon as it is setup.
Many Thanks.
Once again, thanks, it’s working. I need to get to know the program, but for the time being it’s receiving data and I am sharing wtih FlightAware.
If you become more involved in PlanePlotter, you might try look into joining the planeplogger forum at planeplotterforum.co.uk/ and the planeplotter group at yahoo.com
Ok, for the group and Yahoo.
This method worked! THANK YOU!!!
Very helpful, thank you!
