@jaymot You can easily convert a headless unit and remotely connect to its desktop rather than the command line. Just enable VNC via raspi-config. If you deployed the LCD image you will get a rendering of the LCD status page and your mouse works like it would if you touched the screen. If you used a full image, the desktop is there even if you are running headless and will appear in the VNC window. You can then connect to skyview in the browser through the VNC window. If you deployed a lite disti without a desktop, one can be added. I can post some instructions if you need.
