Hello,
I would like to modify the default PiAware web interface to include a Temperature reading. I have a DS18B20 and short Python3 script which runs and outputs the current temperature to a text file. I would like setup the PiAware web service to read the temperature text file and then write the contents of the file to the default PiAware page; next to the Date and Time stamps.
Has anybody done this already or know of any how to guides I could look at?
Have your script write to /usr/share/skyaware/html/temperature.txt with whatever you’d like to display. Change the 1000 in the JS to how often you want the temperature to refresh, 1000 is 1 second. Change the temperature.txt to whatever path you’d like to use relative to /usr/share/skyaware/html/
This will be wiped out and need to be redone if you upgrade PiAware or whatever. The above example looks like this with 94c written to the temperature.txt file.
