I have PiAware 3.5.3 installed under Debian on a Pi3 connected via Ethernet and running on a TeckNet Portable Charger.
Antenna is in a poor location as TNT have not delivered my mast yet.
I experience random crashes most days.
From what I can make out the Pi is loosing connection to the server.
Is this correct?
I’m on FTTC at about 7Mb/s upload, so don’t think it could be that.
A new Ethernet cable is now in use, so I will see if that makes any difference.
Jul 13 10:50:17 raspberrypi piaware[455]: 46198 msgs recv’d from dump1090-fa (381 in last 5m); 46042 msgs sent to FlightAware
Jul 13 10:55:16 raspberrypi piaware[455]: 46605 msgs recv’d from dump1090-fa (407 in last 5m); 46449 msgs sent to FlightAware
Jul 13 10:56:25 raspberrypi piaware[455]: mlat-client(1694): Receiver status: connected
Jul 13 10:56:25 raspberrypi piaware[455]: mlat-client(1694): Server status: synchronized with 203 nearby receivers
Jul 13 10:56:25 raspberrypi piaware[455]: mlat-client(1694): Receiver: 108.2 msg/s received 22.0 msg/s processed (20%)
Jul 13 10:56:25 raspberrypi piaware[455]: mlat-client(1694): Server: 0.1 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
Jul 13 10:56:25 raspberrypi piaware[455]: mlat-client(1694): Results: 25.2 positions/minute
Jul 13 10:56:25 raspberrypi piaware[455]: mlat-client(1694): Aircraft: 4 of 8 Mode S, 13 of 14 ADS-B used
Jul 13 11:00:17 raspberrypi piaware[455]: 47046 msgs recv’d from dump1090-fa (441 in last 5m); 46890 msgs sent to FlightAware
Jul 13 11:05:17 raspberrypi piaware[455]: 47448 msgs recv’d from dump1090-fa (402 in last 5m); 47292 msgs sent to FlightAware
Jul 13 11:10:18 raspberrypi piaware[455]: 47891 msgs recv’d from dump1090-fa (443 in last 5m); 47735 msgs sent to FlightAware
Jul 13 11:11:30 raspberrypi piaware[455]: mlat-client(1694): Receiver status: connected
Jul 13 11:11:30 raspberrypi piaware[455]: mlat-client(1694): Server status: synchronized with 224 nearby receivers
Jul 13 11:11:31 raspberrypi piaware[455]: mlat-client(1694): Receiver: 118.8 msg/s received 25.1 msg/s processed (21%)
Jul 13 11:11:33 raspberrypi piaware[455]: mlat-client(1694): Server: 0.1 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
Jul 13 11:11:34 raspberrypi piaware[455]: mlat-client(1694): Results: 22.3 positions/minute
Jul 13 11:11:35 raspberrypi piaware[455]: mlat-client(1694): Aircraft: 5 of 8 Mode S, 13 of 14 ADS-B used
Jul 13 11:15:18 raspberrypi piaware[455]: 48246 msgs recv’d from dump1090-fa (355 in last 5m); 48090 msgs sent to FlightAware
Jul 13 11:20:18 raspberrypi piaware[455]: 48673 msgs recv’d from dump1090-fa (427 in last 5m); 48517 msgs sent to FlightAware
Jul 13 11:25:19 raspberrypi piaware[455]: 48883 msgs recv’d from dump1090-fa (210 in last 5m); 48727 msgs sent to FlightAware
Jul 13 11:26:30 raspberrypi piaware[455]: mlat-client(1694): Receiver status: connected
Jul 13 11:26:30 raspberrypi piaware[455]: mlat-client(1694): Server status: synchronized with 73 nearby receivers
Jul 13 11:26:32 raspberrypi piaware[455]: mlat-client(1694): Receiver: 64.2 msg/s received 15.5 msg/s processed (24%)
Jul 13 11:26:33 raspberrypi piaware[455]: mlat-client(1694): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
Jul 13 11:26:35 raspberrypi piaware[455]: mlat-client(1694): Results: 11.7 positions/minute
Jul 13 11:26:36 raspberrypi piaware[455]: mlat-client(1694): Aircraft: 7 of 9 Mode S, 6 of 7 ADS-B used
Jul 13 11:30:18 raspberrypi piaware[455]: 49165 msgs recv’d from dump1090-fa (282 in last 5m); 49009 msgs sent to FlightAware
Jul 13 11:35:19 raspberrypi piaware[455]: 49483 msgs recv’d from dump1090-fa (318 in last 5m); 49327 msgs sent to FlightAware
Jul 13 11:35:54 raspberrypi piaware[455]: NOTICE from adept server: 13% of multilateration messages (UDP) are not reaching the server - check your network?
Jul 13 11:40:18 raspberrypi piaware[455]: 49900 msgs recv’d from dump1090-fa (417 in last 5m); 49744 msgs sent to FlightAware
Jul 13 11:41:29 raspberrypi piaware[455]: mlat-client(1694): Receiver status: connected
Jul 13 11:41:32 raspberrypi piaware[455]: mlat-client(1694): Server status: synchronized with 110 nearby receivers
Jul 13 11:41:33 raspberrypi piaware[455]: mlat-client(1694): Receiver: 99.8 msg/s received 20.9 msg/s processed (21%)
Jul 13 11:41:35 raspberrypi piaware[455]: mlat-client(1694): Server: 0.1 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
Jul 13 11:41:36 raspberrypi piaware[455]: mlat-client(1694): Results: 25.8 positions/minute
Jul 13 11:41:38 raspberrypi piaware[455]: mlat-client(1694): Aircraft: 6 of 12 Mode S, 12 of 13 ADS-B used
Jul 13 11:45:19 raspberrypi piaware[455]: 50353 msgs recv’d from dump1090-fa (453 in last 5m); 50197 msgs sent to FlightAware
Jul 13 11:50:21 raspberrypi piaware[455]: 50810 msgs recv’d from dump1090-fa (457 in last 5m); 50654 msgs sent to FlightAware
Jul 13 11:55:19 raspberrypi piaware[455]: 51223 msgs recv’d from dump1090-fa (413 in last 5m); 51067 msgs sent to FlightAware
Jul 13 11:56:28 raspberrypi piaware[455]: mlat-client(1694): Receiver status: connected
Jul 13 11:56:28 raspberrypi piaware[455]: mlat-client(1694): Server status: synchronized with 223 nearby receivers
Jul 13 11:56:28 raspberrypi piaware[455]: mlat-client(1694): Receiver: 114.1 msg/s received 24.4 msg/s processed (21%)
Jul 13 11:56:28 raspberrypi piaware[455]: mlat-client(1694): Server: 0.1 kB/s from server 0.0kB/s TCP to server 0.3kB/s UDP to server
Jul 13 11:56:28 raspberrypi piaware[455]: mlat-client(1694): Results: 19.9 positions/minute
Jul 13 11:56:28 raspberrypi piaware[455]: mlat-client(1694): Aircraft: 8 of 10 Mode S, 13 of 15 ADS-B used
Jul 13 12:00:20 raspberrypi piaware[455]: 51671 msgs recv’d from dump1090-fa (448 in last 5m); 51515 msgs sent to FlightAware
Jul 13 12:05:21 raspberrypi piaware[455]: 52136 msgs recv’d from dump1090-fa (465 in last 5m); 51980 msgs sent to FlightAware
Jul 13 12:06:00 raspberrypi piaware[455]: NOTICE from adept server: 17% of multilateration messages (UDP) are not reaching the server - check your network?
Jul 13 12:10:24 raspberrypi piaware[455]: 52585 msgs recv’d from dump1090-fa (449 in last 5m); 52429 msgs sent to FlightAware
Jul 13 12:11:35 raspberrypi piaware[455]: mlat-client(1694): Receiver status: connected
Jul 13 12:11:36 raspberrypi piaware[455]: mlat-client(1694): Server status: synchronized with 112 nearby receivers
Jul 13 12:11:36 raspberrypi piaware[455]: mlat-client(1694): Receiver: 103.0 msg/s received 24.4 msg/s processed (24%)
Jul 13 12:11:36 raspberrypi piaware[455]: mlat-client(1694): Server: 0.0 kB/s from server 0.0kB/s TCP to server 0.2kB/s UDP to server
Jul 13 12:11:36 raspberrypi piaware[455]: mlat-client(1694): Results: 15.7 positions/minute
Jul 13 12:11:36 raspberrypi piaware[455]: mlat-client(1694): Aircraft: 8 of 11 Mode S, 8 of 10 ADS-B used
Jul 13 12:15:23 raspberrypi piaware[455]: 52909 msgs recv’d from dump1090-fa (324 in last 5m); 52753 msgs sent to FlightAware
Jul 13 12:18:19 raspberrypi piaware[455]: timed out waiting for alive message from FlightAware, reconnecting…
Jul 13 12:18:24 raspberrypi piaware[455]: multilateration data no longer required, disabling mlat client
Jul 13 12:18:41 raspberrypi piaware[455]: fa-mlat-client exited with
Jul 13 12:18:41 raspberrypi piaware[455]: reconnecting in 54 seconds…
Jul 13 12:18:41 raspberrypi piaware[455]: mlat-client(1694): Disconnecting from localhost:30005: Lost connection to multilateration server, no need for input data
Jul 13 12:18:41 raspberrypi piaware[455]: mlat-client(1694): Exiting on connection loss
Jul 13 12:19:35 raspberrypi piaware[455]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Jul 13 12:19:36 raspberrypi piaware[455]: Connection with adept server at piaware.flightaware.com/1200 established
Jul 13 12:19:40 raspberrypi piaware[455]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Jul 13 12:19:41 raspberrypi piaware[455]: FlightAware server certificate validated
Jul 13 12:19:41 raspberrypi piaware[455]: encrypted session established with FlightAware
Jul 13 12:20:15 raspberrypi piaware[455]: data isn’t making it to FlightAware, reconnecting…
Jul 13 12:20:16 raspberrypi piaware[455]: reconnecting in 72 seconds…
Jul 13 12:20:45 raspberrypi piaware[455]: 53324 msgs recv’d from dump1090-fa (415 in last 5m); 52944 msgs sent to FlightAware
Jul 13 12:21:29 raspberrypi piaware[455]: Connecting to FlightAware adept server at piaware.flightaware.com/1200
Jul 13 12:21:31 raspberrypi piaware[455]: Connection with adept server at piaware.flightaware.com/1200 established
Jul 13 12:21:41 raspberrypi piaware[455]: TLS handshake with adept server at piaware.flightaware.com/1200 completed
Jul 13 12:21:42 raspberrypi piaware[455]: FlightAware server certificate validated
Jul 13 12:21:42 raspberrypi piaware[455]: encrypted session established with FlightAware
Jul 13 12:22:21 raspberrypi piaware[455]: data isn’t making it to FlightAware, reconnecting…
Jul 13 12:22:22 raspberrypi piaware[455]: reconnecting in 62 seconds…
Jul 13 12:23:24 raspberrypi piaware[455]: Connecting to FlightAware adept server at 70.42.6.198/1200
Jul 13 12:23:25 raspberrypi piaware[455]: Connection with adept server at 70.42.6.198/1200 established
Jul 13 12:23:28 raspberrypi piaware[455]: TLS handshake with adept server at 70.42.6.198/1200 completed
Jul 13 12:23:28 raspberrypi piaware[455]: FlightAware server certificate validated
Jul 13 12:23:28 raspberrypi piaware[455]: encrypted session established with FlightAware
Jul 13 12:24:04 raspberrypi piaware[455]: Login attempt with adept server at 70.42.6.198/1200 timed out
Jul 13 12:24:06 raspberrypi piaware[455]: reconnecting in 68 seconds…
Jul 13 12:25:14 raspberrypi piaware[455]: Connecting to FlightAware adept server at 70.42.6.191/1200
Jul 13 12:25:14 raspberrypi piaware[455]: Connection with adept server at 70.42.6.191/1200 established
Jul 13 12:25:20 raspberrypi piaware[455]: TLS handshake with adept server at 70.42.6.191/1200 completed
Jul 13 12:25:20 raspberrypi piaware[455]: FlightAware server certificate validated
Jul 13 12:25:20 raspberrypi piaware[455]: encrypted session established with FlightAware
Jul 13 12:25:58 raspberrypi piaware[455]: data isn’t making it to FlightAware, reconnecting…
Jul 13 12:25:59 raspberrypi piaware[455]: reconnecting in 57 seconds…
